Glider rides
Old December 14th 09, 01:29 PM posted to rec.aviation.soaring
BDS
Default Glider rides
Thanks to everyone who responded with information to help us sort through
this.
Yes, we are in the US and most of the information that has been floating
around the club with respect to this is apparently bad. That said, we have
been told by our insurer that giving what really amounts to rides under the
guise of an introductory flight or temporary club membership would be
treated as a commercial situation, and if something should happen it would
not be covered by our club level insurance. In other words, if it smells
commercial it is commercial regardless of what name you put on it.
As to the regs, my preliminary research tended to indicate that the club's
past understanding of many of the requirements involved were incorrect, but
I wanted to be certain that I wasn't overlooking something in between all
the exceptions and typical FAA wording, as well as the "intent" of the regs
which occasionally enters into these kinds of situations. It is good to
have the background on the involvement of the SSA in all of this.
Thanks again for the help.
Bruce
"CindyB" wrote in message
Bruce:
I am presuming you are writing from the US, since you reference
drug testing and LOAs in your questions. I am only aware of these
types of programs in the US.
You can contact your SSA regional director for some of these answers,
and they will also say many of the same things reported here.
Your insurance carrier can answer many questions directly
for you. A change in service, to allow more services by you to the
public, will likely change your rates for coverage, and tell you who
will be allowed to fly which machines. Insurance coverage of clubs
in the US is more restrictive to many of your actions than the FARs.
There is a big difference in risks, required pilot certificates and
premiums depending on whether you do only rides versus
introductory lesson flights. Passenger rides do not include
allowing the passenger to handle the flight controls, by most
insurance.
Towplanes typically do not carry passengers while towing.
What they drag behind them is not 'the tug carrying a passenger'.
SSA effected that formal interpretation from the FAA in about
1972. For climb performance and non-distractions while towing,
most towing operations will not carry anyone aboard that machine
except the towing staff. Hence that machine won't need 100-hr
inspections. Most insurance excludes having passengers aboard
a tug while towing.
Depending on your insurance coverage, you may or may not need
a commercial pilot for the tug. A minimum of a private certificate is
required for towing by the FARS, and an appropriate endorsement by
two different persons.
For a ride in the glider you need a commercial glider pilot, if
you are charging money for that service.
You will not need a drug testing program for the commercial
glider pilot, as this is another case of SSA success in regulatory
negotiations. When you read the drug testing regulations for
'scenic rides', please notice the difference between
aircraft and airplanes. This minor vocabulary difference is
deliberate.
Glider instructors are exempted from terrorist-threat identification
training, and random drug test training, by action of the SSA with the
FAA. Glider students are exempt from background checking and
nationality proof requirements, due to ???? yes, SSA.
There is a lot of support within SSA for organizational help to
Chapter clubs through the Chapter Committee. You can use the
link after you log in as an SSA member.
http://www.ssa.org/members/governanc...l.asp?group=36
The other responder who mentions balancing the allocation of flight
access
between established and potential members illuminates a tricky point.
Good business plans, models from other clubs, and advice from
several sources will allow your group to make informed decisions.
An attorney might be of help, but much of this can be accomplished
without forking over fees needlessly. Waivers are helpful mostly in
making folks believe they shouldn't pursue frivolous legal action, not
for their
actual legal weight or value. Good operational practices obviate the
majority of needs for legal defense.
Best wishes,
Cindy B
Region 12 SSA Director
On Dec 13, 9:27 am, "bds" wrote:
I belong to a glider club that is looking at the possibility of offering
rides to help us to defray our operating costs and keep our club healthy
financially. In order to evaluate the feasibility of this I am looking
into
the regulations that would apply to such an operation, as well as the
insurance impact.
Our present understanding is that both the tow plane and the glider would
need to have 100-hr inspections and that the pilots of the tow plane and
glider would need to have a commercial rating as well as a second class
medical for the towplane pilot.
However, we are uncertain as to some of the other regulations such as
compliance with drug testing and the requirement for an LOA for this type
of
operation, since it appears that there may be some exceptions when it
comes
to gliders.
Can someone with experience in this area help to shed some light on these
aspects as well as anything else that we should be aware of?
Thanks.
Bruce
BDS
this.
Bruce
Bruce:
insurance.
a tug while towing.
deliberate.
access
for their
Best wishes,
Cindy B
into
insurance impact.
of
comes
to gliders.
Thanks.
Bruce
Old December 14th 09, 04:08 PM posted to rec.aviation.soaring
Frank Whiteley
Your chapter is a 501c(7), which establishes a gross receipts
limitation of 15% of that amount which may be derived from the public
use of your facilities. For 2008, your IRS Form 990 shows gross
receipts of $162K. This is an anomaly, as 2006 was $98K and 2007 was
$106K. So a more representative year would be closer to $100K. Thus
you'd have a $15,000 limitation. At $100/ride, your chapter would be
capped at 150 rides. Just simple math, but your stated purpose was
raising revenue. This total would need to be reduced by the amount of
gross receipts from other public sources, like perhaps the tie-downs
and tenting fees if not derived from members.
In one case, an SSA chapter in your tax category was audited by the
IRS. One of the questions specifically asked was whether they were
giving rides to the public. In this case, the answer was no. The
interest was because there was a commercial operation on the same
airport providing glider ride services and a non-profit cannot compete
unfairly with a commercial entity. Whether this exclusion extends to
an airport 5, 10, or 20 miles distant is not clear. If someone knows
of such an exclusion or challenge, I'd like to hear about it. It does
not extend to training within the membership.
Some of the other comments have some validity, but are a result of
chapters operating in a manner inconsistent with their insurance or
status. That is, they are performing more like a commercial operator
than a chapter in the opinion of the underwriter, therefore they may
be be eligible for the chapter discount. One method of correcting
this and for limiting your exposure has been recently posted to the
SSA web site.
http://www.ssa.org/myhome.asp?mbr=67...w=blog&id=2027
Frank Whiteley
SSA Clubs & Chapters Committee
970-330-2050
Old December 14th 09, 04:11 PM posted to rec.aviation.soaring
Frank Whiteley
use of your facilities. *For 2008, your IRS Form 990 shows gross
receipts of $162K. *This is an anomaly, as 2006 was $98K and 2007 was
$106K. *So a more representative year would be closer to $100K. *Thus
you'd have a $15,000 limitation. *At $100/ride, your chapter would be
capped at 150 rides. *Just simple math, but your stated purpose was
raising revenue. *This total would need to be reduced by the amount of
IRS. *One of the questions specifically asked was whether they were
giving rides to the public. *In this case, the answer was no. *The
unfairly with a commercial entity. *Whether this exclusion extends to
an airport 5, 10, or 20 miles distant is not clear. *If someone knows
of such an exclusion or challenge, I'd like to hear about it. *It does
status. *That is, they are performing more like a commercial operator
be be eligible for the chapter discount. *One method of correcting
SSA web site.http://www.ssa.org/myhome.asp?mbr=67...w=blog&id=2027
Frank Whiteley
970-330-2050
That should say "not be eligible for the chapter discount".
Frank
Glider rides in NM? Mike Lindsay Soaring 6 January 2nd 06 03:12 PM
Glider Rides - Gift Michael Simulators 1 December 7th 04 10:46 AM
Glider rides? Kbh2u General Aviation 2 November 15th 03 06:52 AM
Glider rides? Kbh2u Piloting 1 November 7th 03 01:02 AM
How many Glider Rides in one day cloud nine Soaring 23 November 4th 03 04:49 PM
