revised FAA Order 5190.6B
Old January 10th 10, 06:02 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Default revised FAA Order 5190.6B
This came in by email this evening.
Anybody heard anything about it?
R
Under new FAA rules, general aviation is about to undergo massive changes, none
for the good, apparently.
The FAA Airports Division issued a revised FAA Order 5190.6B, Airport Compliance
Manual recently, that, as EAA described it, caught "just about every one off guard."
Not only that it went from 94 to 691 pages of new rules and regulations, and it
makes major changes that will affect several aspects of general aviation. Here
are some of the more controversial ones:
1) No more autofuel may be used in aircraft.
2) Light Sport Aircraft that can be trailered, and owners/operators of
recreational aircraft such as powered parachutes, weight-shift- control and
gyroplanes will be denied access to airports.
3) Permanent or long-term living quarters on airports, part-time or secondary
residences, and developments known as residential hangars, hangar homes,
campgrounds, fly-in communities and airpark developments - even when collocated
with an aviation hangar or aeronautical facility, will not be permitted on
publically funded airports.
4) The new manual failed to clarify the issue of providing reduced fair-market
hangar rent for not-for-profit 501c(3) tax-exempt EAA chapters, whose community
activities provide positive tangible benefits to their airports.
AUTO GAS
The item banning auto gas, EAA said, will affect 100,000+ airplanes that use car
gas in their engines under FAA STC's.
"Autofuel was not recognized as an authorized aviation fuel, nor does it suggest
that airports take actions to install self-service, ethanol-free premium grade
autogas pumps to support the 100,000+ aircraft that use autogas as their
primary, FAA-approved aviation fuel," the EAA noted.
"EAA has successfully worked with the FAA Airports Division for several years in
resolving this issue," the organization said.
TRAILERABLE AIRCRAFT BAN
The banning of trailerable Light Sport Aircraft, powered parachutes,
weight-shift- control and gyroplanes was recognized as an activity not permitted
because of the FAA's through-the- fence (TTF) prohibitions, EAA said.
With the on-going development of special light-sport aircraft as recreational
aircraft, including the roadable aircraft, this issue needed to be resolved, but
wasn't, EAA said. It would seem to mean the new Terrafugia flying car wouldn't
be allowed to drive on the airport and fly off the runway.
AIRPORT PROPERTY
The FAA's regulation saying it considers permanent or long-term living quarters
on airport, part-time or secondary residences, and developments known as
residential hangars, hangar homes, campgrounds, fly-in communities and airpark
developments incompatible - when collocated with an aviation hangar or
aeronautical facility - may be one of the biggest changes of all.
There re dozens, perhaps hundreds, of such fly-in communities around the
country, most associated with publicly funded (meaning FAA money) airports.
The two leading general aviation organizations, EAA and AOPA, are examining the
new manual for areas that need to be improved or clarified, an EAA spokesman said.
"They will then work with the FAA Airports Division to address the problem
areas," the pilots' group said. When we put questions to EAA about their
response to the new regulations, this is the answer we got:
Live-In Airparks
"As for residential airparks and the like, the early answer is: depends.
Residential airparks on private airfields, or public airports that do not
receive FAA funding, are not affected by the policy.
"If it's a local public airport that receives FAA improvement funds, though,
such residential developments would be affected. Whether existing developments
are grandfathered in the policy is still a gray area.
"Many of the current arrangements are also under local jurisdiction and review
whether or not the FAA policy had changed. As it appears now, aircraft
parking/camping at aviation events such as Oshkosh is not covered by the new policy.
Camping
"The term 'campgrounds' indicates a permanently based campground at an airport
instead of a temporary parking situation, which one finds at Oshkosh and other
fly-ins." Permanent campgrounds on airports seemingly are banned.
Asked if there specific concerns, the EAA's public relations said definitely.
"Yes. In addition, one of EAA's biggest objections is that the FAA policy was
issued without public comment, and it did change the long-standing policy of
permitting residential uses after evaluating the use, the economic return to the
airport, and the management of unauthorized airport access/security issues. It
was, in effect, establishing a rule by policy without proper public comment and
input."
However, he cautioned, "let's not run screaming off the bridge quite yet. This
is why EAA is asking for feedback from pilots and people in through-the- fence
situations, so there is solid background and evidence to present to FAA."
My revised weather brief form Wizard of Draws Piloting 12 September 10th 04 03:25 AM
Old quotations, revised Bob McKellar Military Aviation 3 February 9th 04 04:29 AM
Pentagon "plane" crash revised Ben Full Military Aviation 26 January 1st 04 03:43 AM
New Revised Pilotv Library. $5.49 IczmK Pilot Pubs Products 0 July 26th 03 04:56 PM
New Revised Pilotv Library. $5.49 E7gAGI2 Pilot Pubs Aviation Marketplace 0 July 26th 03 04:56 PM
