Another sailplane lost!
Old February 2nd 10, 02:59 PM posted to rec.aviation.soaring
Jim[_18_]
Default Another sailplane lost!
On Feb 1, 8:32*am, GARY BOGGS wrote:
When are we going to quit loosing sailplanes to poor tie downs?
http://bit.ly/cgioFc
Last year my super cub's left wing and struts were destroyed in a wind
storm,
the double tiedowns held the airplane in place for the wind to twist
the wing.
Would have been nice if it had been in the hangar but then a lot of
very nice
gliders were lost in the Barstow hangar fire a while ago.
Old February 2nd 10, 04:33 PM posted to rec.aviation.soaring
bildan
storm,
the wing.
very nice
There's a lot to be learned from the experience at Boulder, CO where
high-wind events often exceed 100 MPH for many hours.
The technique is 6 deeply buried concrete tie down anchors per glider
- nose, tail and two on each wing - one inboard and one outboard. On
flex-winged composite gliders, wing stands are used. The gliders are
oriented 90 degrees to the high-wind direction.
Ropes are at least 1/2" (13mm) high-strength climbing ropes or nylon
straps. The knots are multiple half hitches drawn up tight against
the glider. These knots are so simple anyone can tie them with one
demonstration - and they'll come loose when you want them to. As long
as there is no slack, they won't work loose on their own.
Old February 2nd 10, 04:40 PM posted to rec.aviation.soaring
Frank Whiteley
storm,
the wing.
very nice
- nose, tail and two on each wing - one inboard and one outboard. *On
flex-winged composite gliders, wing stands are used. *The gliders are
straps. *The knots are multiple half hitches drawn up tight against
the glider. *These knots are so simple anyone can tie them with one
demonstration - and they'll come loose when you want them to. *As long
I believe the slats inserted into the cyclone fencing surrounding the
Boulder parking bays has also paid an important part.
Old February 2nd 10, 04:56 PM posted to rec.aviation.soaring
Gary Boggs
I never saw any of the pictures taken of me in the wrecked 1-26. If
you have any could you email them to me?
Old February 2nd 10, 08:04 PM posted to rec.aviation.soaring
JS
Bugger. Was hoping you'd cough them up!
Another interesting short flight was a friend towing his 1-26 to the
hangar with the technique a lot of Schweizer pilots use:
A short rope attached to the tow release that has a T-handle on the
end.
Nothing much you can do once the glider tries to leave the ground but
let go and run upwind. In this case it did no damage to anything else.
The Tonopah launch out of the tiedowns was lucky, only putting a blue
stripe on Charlie Westerinen's winglet.
A close shave, as Martin Feeg would write in Soaring Australia.
On Feb 2, 8:56*am, GARY BOGGS wrote:
I never saw any of the pictures taken of me in the wrecked 1-26. *If
Old February 2nd 10, 05:44 PM posted to rec.aviation.soaring
bildan
storm,
the wing.
very nice
Yeah, the cyclone fencing helps a lot. They strain out flying debris
and slow the wind a bit. I've been out there when wind borne golf
ball sized rocks were hitting me at knee level.
Old February 3rd 10, 12:54 AM posted to rec.aviation.soaring
Tony V
......The knots are multiple half hitches drawn up tight against
the glider.
Always use a Truckers hitch, IMHO:
http://www.ehow.com/video_2355281_ti...itch-knot.html
Tony V LS6-b
Old February 3rd 10, 02:44 AM posted to rec.aviation.soaring
Darryl Ramm
the glider.
Always use a Truckers hitch, IMHO:http://www.ehow.com/video_2355281_ti...itch-knot.html
Tony V LS6-b
What if we don't have a piano?
Darryl
Old February 2nd 10, 07:34 PM posted to rec.aviation.soaring
John Smith
I'll never understand how somebody would tie down a plastic glider
outside rather than put it in the trailer. Rigging a modern glider is a
matter of 10 minutes but possibly worth a couple of thousand dollars.
Old February 2nd 10, 08:32 PM posted to rec.aviation.soaring
Uncle Fuzzy
I have to agree that putting it in the trailer would be the most
prudent thing to do. I'd like to be the kind of guy that would
actually do it, but I'm not. After a 5 - 8 hour flight, all I want is
a beer, something to eat, an access point to upload my flight, and
bed. The 1/2 hour required to pull the trailer to the glider, de-rig
and box it, then park the trailer and disconnect it from the truck
seems like a monumental task at the end of the day, especially when it
will be flown the next day, and the next.....
The FAA has just lost it HilldaBeast Piloting 1 November 15th 07 02:49 AM
Lost stories here Danny Deger Piloting 68 January 12th 07 12:43 AM
Lost stories here Larry Dighera Instrument Flight Rules 3 January 12th 07 12:43 AM
We lost in Nam. But not Rasimus Lisakbernacchia Military Aviation 12 June 12th 04 06:30 AM
fw-200 not "lost" old hoodoo Military Aviation 0 December 22nd 03 07:16 PM
