Transponder article updated with Trig info
Old February 12th 10, 04:24 PM posted to rec.aviation.soaring
JJ Sinclair
Default Transponder article updated with Trig info
I tow with my transponder on and I'm hoping this will protect me and
my tow plane from a Boulder type scenario.
Your thoughts appreciated,
JJ
Errrrr, that is assuming the hitter has asked for flight following or
has some kind of collision avoidance equipment.
JJ
Old February 12th 10, 05:18 PM posted to rec.aviation.soaring
Frank Whiteley
On Feb 12, 8:10*am, Bob wrote:
Somehow we all need to get transponders in our gliders.
Bob
Lobby for stimulus money.
Old February 12th 10, 06:47 PM posted to rec.aviation.soaring
Darryl Ramm
JJ
JJ
Barging in on Eric's reply with another long winded post...
If the threat aircraft you are worried about are on flight following
(i.e. they have a transponder and can be seen on radar by ATC and have
bothered to actually contact ATC for flight following) then by
definition you are both likely to be in radar coverage and ATC should
be able to provide traffic advisories under flight following. Of
course that or anything else here is no guarantee of protection. Of
course, especially down low where tow planes often are, many aircraft
are not under flight following.
The other part of the question is "some kind of collision avoidance
equipment". So watcha thinking?
PCAS? - See my previous post for a warm up.
Mode S TIS? - requires both aircraft to be within coverage of a radar
with TIS support. Low level coverage (where many tow planes spend a
lot of time) may not be good depending on your proximity to the
terminal radar. e.g. out of where JJ and I fly NORCAL approach radar
out of Sacramanto has TIS support, Reno approach does not. Threat
aircraft with TIS should see us on those of us with transponders on
those long mountain tows but will have problems down low.
TCAD/TAS (e.g. L3 Skywatch or Garmin 800 series)/TCAS (jets airliners
etc.)? - should provide pretty good visibility of you, independent of
ground radar or any other ground infrastructure. Prices start $10k-
$20k for GA aircraft, so more something you find in newer aircraft.
Pretty impressive stuff but it still has limits.
ADS-B? - won't see you at all because there is no ADS-B ground
infrastructure where you fly yet (CA/NV) and few aircraft have ADS-B.
Once there is ADS-B ground infrastructure then ADS-R will relay your
SSR/transponder position to ADS-B receiver equipped aircraft. If the
radar can't see you the ADS-B equipped aircraft won't know about you.
The answer there is eventually you would add an ADS-B transmitter.
e.g. a Mode S transponder like the Trig TT21 with ADS-B over 1090ES or
in future a UAT transmitter/transceiver when suitable models become
available. The ADS-B part of the transponder operates independently of
ground Radar coverage. But one (USA unique) problem there is you will
need to be within coverage of an ADS-B ground station for ADS-R so
that your 1090ES ADS-B is retransmitted for folks with ADS-B UAT
receivers and visa-versa. But eventually that ground station coverage
is going to be pretty impressive, way more than SSR, but still it's an
issue to be aware of. ADS-B is also capable of ultimately offering
other advantages (much better long range traffic awareness/tracking,
much better tracking usable for SAR, possibly ground based monitoring
by FBOs, clubs, contest tracking etc.). This ADS-B future is one
reason that if I was buying a transponder today it would likely be a
Mode S capable of 1090ES. Which in the USA effectively currently means
it would be a Trig TT21.
FLARM? - won't see your transponder and effectively no GA aircraft in
the USA are FLARM equipped and I suspect relatively few ever would be.
If you are only concerned about glider-glider and towplane-glider
separation then FLARM is a wonderful approach but the USA never got
the start on FLARM when it should have and now ADS-B is coming which
is going to confuse this picture (and given what is happening adopting
FLARM instead of ADS-B in many places might be bad idea). But and it
is a big but -- products like PowerFLARM and TRX-1090 that combine a
FLARM transceiver, ADS-B 1090ES receiver and a PCAS receiver look very
impressive on paper and I expect/hope to see them being used in the
USA.
And to the above add some generic issues, like -
- Pilot training/knowledge (transponder turned on, in ALT mode?
traffic awareness system turned on and the pilot known how to use it,
etc.).
- Lots of gliders in gaggles etc. may confuse a traffic awareness
system and/or the pilot
- Other non-transponder equipped aircraft in close proximity may be in
somewhat increased danger if aircraft are avoiding the transponder
equipped targets,
- etc. etc.
So while the question was about transponders in the glider and traffic
awareness systems in the threat aircraft, overall the matter is
working out which technology amongst things like transponders, ADS-B
transmitters and/or receivers, PCAS, powerFLARM type devices, etc.
make most sense for a particular situation/risk assumptions.
Just a semantic niggle but I prefer to say things like "provide or
help with traffic awareness" vs. "provide protection". But I know I
slip on this all the time as well. Oh and I don't want anybody to get
the wrong impression that technology cannot provide a hugely important
help here and the limitations like I mentioned in this thread means it
is not worth using. Human eyesight is easily fooled, visibility of
threats is easily reduced or obstructed etc. These technologies are
really useful, I just want people to think about the different choices
and their benefits and limitations and select the best technology to
help improve their flight safety.
Darryl
Old February 12th 10, 07:01 PM posted to rec.aviation.soaring
Dave Nadler
If you are only concerned *about glider-glider and towplane-glider
USA.
Just to clarify Darryl's point: The FLARM unit to be offered in USA
is PowerFLARM, and they expect most people will opt for the ADS-B
receiver option. The ADS-B option listens to direct transponder
transmissions,
mode C or mode S, and also TIS-B ground-stations (which will
exist someday we hear).
Thanks Darryl !
Best Regards, Dave
Old February 12th 10, 08:05 PM posted to rec.aviation.soaring
Chris Reed[_2_]
There was a recent report in the UK press that UAVs will be permitted to
fly in Class G airspace once they are capable of autonomous collision
avoidance, and that the technology they were looking at was FLARM. I'm
sure we Brits (will) buy our UAVs from the US - might this mean that the
US military is also trialling FLARM?
USA.
transmissions,
Thanks Darryl !
Best Regards, Dave
Old February 12th 10, 08:17 PM posted to rec.aviation.soaring
Darryl Ramm
USA.
transmissions,
Thanks Darryl !
Best Regards, Dave
Unlikely. I think you will find that for the USA ADS-B UAT (and to a
lesser extend at the low-end 1090ES) is the twinkle in the eye of the
US military, defense/aerospace contractors, DHS and various police
forces excited about UAVs. ADS-B is much more capable of things like
extensive remote tracking, integration with ATC systems, etc. that
Flarm does not try to do. As for looking at Flarm as an interesting
early practical implementation of an automatic broadcast system I
expect many military/defense contractor types are aware of it.
Darryl
Old February 12th 10, 08:59 PM posted to rec.aviation.soaring
JJ Sinclair
JJ
JJ
USA.
etc.).
equipped targets,
- etc. etc.
Darryl
Well, that's comforting, I think? Guess I'll keep my mark-1 eyeball
greased up. You know I (we) almost hit a glider while on tow at
Montague at 1500 feet. I saw him and figured he was a good mile away
when suddenly he was right on us! The tow pilot kicked right rudder as
he passed and then he was headed straight for my left wing. I rolled
90 degrees left and he missed me by maybe 5 feet! The RC sailplane
guys were having their nationals and we almost hit a 12 foot white
sailpland model. Seems our tow route took us past their first turn
point about 5 miles north on Montague.
Turn on the radio and use it!
Turn on the Transponder and talk to center when necessary.........we
do that a lot around Reno.
Turn on the PCAS and monitor it.
Keep your head on a swivel..........outside the cockpit.
Cheers,
JJ
Old February 12th 10, 09:18 PM posted to rec.aviation.soaring
Eric Greenwell
JJ Sinclair wrote:
Eric,
JJ
It could help, if you are towing where radar can reach you, and the
other aircraft has a PCAS or has flight following from ATC. If radar
does reach you, then having your own PCAS will help, too.
It _will_ help if a TCAS equipped aircraft approaches, because they
don't need radar or ATC contact for TCAS to work.
It might be appropriate to inform the local Approach people when you
begin towing, so they can pass on the info to pilots they talk to.
Eric Greenwell - Washington State, USA (netto to net to email me)
- "Transponders in Sailplanes - Jan/2010" also ADS-B, PCAS, Flarm tinyurl.com/yg76qo9
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz
Old February 12th 10, 09:24 PM posted to rec.aviation.soaring
Eric Greenwell
Frank Whiteley wrote:
Bob
It worked for New Zealand. About 10 years ago, they got transponders in
every glider because the government bought them for the gliders. The
AOPA has made some proposals along that line for fitting ADS-B to GA
aircraft. I have no idea if it's worth pursuing.
NZ pilots, don't be bashful about correcting/adding details.
Old February 12th 10, 10:11 PM posted to rec.aviation.soaring
Frank Whiteley
Cheers,
JJ
I guess that means read the NOTAMs also. We have large amateur rocket
activity a few miles east of our glider port at times.
Frank Whiteley
New Trig TT22 Transponder Paul Remde Soaring 1 January 14th 10 07:27 PM
TRIG TT21NOW IN STOCK Tim Mara[_2_] Soaring 5 September 29th 09 10:29 PM
Trig TT21 Transponder receives FAA TSO approval Paul Remde Soaring 12 September 19th 09 02:47 PM
Trig TT21 Transponder Thoughts? jcarlyle Soaring 16 June 23rd 09 04:38 PM
Seeking KT-79 transponder install/operational info [email protected] Owning 7 July 26th 06 01:11 PM
