#11
Been using NIMH for 2 years in a N3DT with Xponder. Works great!
Bob |
What about Li Ion batteries like these? Is the fire risk sinificantly
less than Li Polymer? http://www.streckenflug.at//shop/pro...roducts_id=608 A bit pricey, and probably not approved in Europe, but might be a thought when a transponder has to be carried. John Galloway |
While charging a LiPo model airplane battery with a top-of-the-line charger
at the proper rate it burst into flame. I had carelessly left it out of the flame-proof charge bag and when I checked strange noises the room was filled with acrid smoke and a Mt Vesuvius mass of sputtering pyrotchnics was burning a hole in the work bench. Don't fly with you-do-it LiPos unless you have an ejection seat! Karl Striedieck "johngalloway" wrote in message ... What about Li Ion batteries like these? Is the fire risk sinificantly less than Li Polymer? http://www.streckenflug.at//shop/pro...roducts_id=608 A bit pricey, and probably not approved in Europe, but might be a thought when a transponder has to be carried. John Galloway |
On Feb 25, 9:03*am, "Karl Striedieck" wrote:
While charging a LiPo model airplane battery with a top-of-the-line charger at the proper rate it burst into flame. I had carelessly left it out of the flame-proof charge bag and when I checked strange noises the room was filled with acrid smoke and a Mt Vesuvius mass of sputtering pyrotchnics was burning a hole in the work bench. Don't fly with you-do-it LiPos unless you have an ejection seat! Karl Striedieck "johngalloway" wrote in message ... What about Li Ion batteries like these? *Is the fire risk sinificantly less than Li Polymer? http://www.streckenflug.at//shop/pro...roducts_id=608 A bit pricey, and probably not approved in Europe, *but might be a thought when a transponder has to be carried. John Galloway Karl, model gliding is DANGEROUS ! See ya, Dave |
On Feb 24, 8:50*pm, GM wrote:
Hi, it's still winter with lousy weather in the northern hemisphere, so it is time to warm up an old discussion. I searched the forum for threads reg. Lithium-Polymer Batteries and there have been none for a while. Here are the questions: - Does anyone have real life experience with LiPo's in a glider? (real gliders, that is - not models) - Can I combine two 7.4V packs in series to get a 14.8V unit or is there a risk with that? - How would one charge a combo like this? Each unit by itself and then hook them together or with one charger while hooked together? The prices have dropped to a very affordable level; so have the chargers/balancers. The weight savings are considerable. My 12V/7.5Ah standard sealed gel-cell weighs 2.35kg (5.17lbs) and it lasts a few days. *I found two 7.4V/5.0Ah units on e-bay that weigh in at 0.3kg each (0.6kg or 1.32 lbs in total) Any input is welcome. Uli Neumann 'GM' Most of the dire "explosion-fire" warning here are several years out of date. Chemistry's like LiFePo4 have no such dangers. Most 5AH and larger packs have internal PCB's for safety. Check out US manufacturers like Tenergy which offers a number of "heavy duty" Li-Po and LiFePo4 packs with internal PCB's which limit charge and discharge voltages and currents to safe levels. One problem not mentioned is that 4-cell Li-Po can deliver as much as 17V when fully charged which is more than some avionics allow. I would use a DC-DC converter to deliver a tightly regulated 13.8 V to the avionics bus. DC-DC converters allow a wider choice of battery voltages. |
This thread reminds me of the old saying: pioneers are the ones with
the arrows in their backs. SLA batteries are cheap, and their risks are known. Why mess around and take a chance on an in-flight fire? -John |
On Feb 25, 10:12*am, bildan wrote:
On Feb 24, 8:50*pm, GM wrote: Hi, it's still winter with lousy weather in the northern hemisphere, so it is time to warm up an old discussion. I searched the forum for threads reg. Lithium-Polymer Batteries and there have been none for a while. Here are the questions: - Does anyone have real life experience with LiPo's in a glider? (real gliders, that is - not models) - Can I combine two 7.4V packs in series to get a 14.8V unit or is there a risk with that? - How would one charge a combo like this? Each unit by itself and then hook them together or with one charger while hooked together? The prices have dropped to a very affordable level; so have the chargers/balancers. The weight savings are considerable. My 12V/7.5Ah standard sealed gel-cell weighs 2.35kg (5.17lbs) and it lasts a few days. *I found two 7.4V/5.0Ah units on e-bay that weigh in at 0.3kg each (0.6kg or 1.32 lbs in total) Any input is welcome. Uli Neumann 'GM' Most of the dire "explosion-fire" warning here are several years out of date. *Chemistry's like LiFePo4 have no such dangers. *Most 5AH and larger packs have internal PCB's for safety. Check out US manufacturers like Tenergy which offers a number of "heavy duty" Li-Po and LiFePo4 packs with internal PCB's which limit charge and discharge voltages and currents to safe levels. One problem not mentioned is that 4-cell Li-Po can deliver as much as 17V when fully charged which is more than some avionics allow. *I would use a DC-DC converter to deliver a tightly regulated 13.8 V to the avionics bus. *DC-DC converters allow a wider choice of battery voltages. Second the max voltage warning. ILEC has already seen some fried avionics from customers experimenting with these things... Be careful out there (check max voltage for pack and everything in your panel FIRST), Best Regards, Dave "YO electric" |
Years ago, a lab next to the one I worked in had experimental
batteries under development. All the high energy density ones utilize very reactive elements, of which lithium is one. However, nothing would beat the sodium-sulfur battery in its capacity to "go Vesuvius". It was colloquially referred to as "the fire and brimstone battery". The lab had a sulfurous smell that reminded one of the entrance to nether regions. I'm going to stick with lead-acid, thanks very much! Mike |
On Feb 25, 8:48*am, Mike the Strike wrote:
Years ago, a lab next to the one I worked in had experimental batteries under development. *All the high energy density ones utilize very reactive elements, of which lithium is one. *However, nothing would beat the sodium-sulfur battery in its capacity to "go Vesuvius". *It was colloquially referred to as "the fire and brimstone battery". *The lab had a sulfurous smell that reminded one of the entrance to nether regions. I'm going to stick with lead-acid, thanks very much! Mike If you think lead-acid gel-cells are safe, try a dead short on a fully charged one. Splattering hot gelled acid is pretty nasty stuff. |
Eric Greenwell wrote: GM wrote: The prices have dropped to a very affordable level; so have the chargers/balancers. The weight savings are considerable. My 12V/7.5Ah standard sealed gel-cell weighs 2.35kg (5.17lbs) and it lasts a few days. I found two 7.4V/5.0Ah units on e-bay that weigh in at 0.3kg each (0.6kg or 1.32 lbs in total) Why do you wish to save 1.75 kg/3.85 pounds? That small amount can not possibly affect your glider's performance. I mean, my drinking water weighs about 6 pounds. Libelle drivers understand very well why saving weight is important. Gliders often get heavier with age. Our venerable Libelles have accumulated repairs, more instruments, etc. so that we are often above the (unrealistically low) "official" weight, thus incurring a handicap penalty in sports/club class. Not really much of a competitiveness issue, but when one nudges the "all up" weight limit, contest officials get all serious and make unsettling noises. |
NIMH Batteries | K M | Soaring | 23 | December 9th 08 09:27 PM |
AGM Batteries | Dave Anderer | Owning | 13 | March 29th 08 07:38 PM |
2-Batteries | [email protected] | Soaring | 69 | January 4th 07 04:09 AM |
160 new batteries | Mal | Soaring | 0 | October 27th 06 11:36 AM |
Sealed Batteries | Gene Vignali | Owning | 5 | October 2nd 03 08:32 PM |
