Andrew Toppan wrote:
(3) Finally, there's the question of *which* aircraft will fill the MMA role. The 737 is *one* of several proposals. If you don't like the 737, pick one of the others. Actually, there is only one remaining alternative, after the last downselect. Lockheed Martin's Orion-21 is pretty much exactly what these folks say they want -- a rewinged P-3C AIP with some newer avionics and revised wing stations. The debate here is probably going to be speed vs cost. The P-3 rewing has to be the cheap option (they're even recycling the current engines). OTOH, the P-3 is slow, and has been handicappd by this in some recent operations. And the last couple fo P-3 life extensions have run into unexpected airframe issues, so new construction might be desirable. -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) |
On Thu, 11 Dec 2003 00:16:48 GMT, "Thomas Schoene"
wrote: And the last couple fo P-3 life extensions have run into unexpected airframe issues, so new construction might be desirable. I have a hard time seeing a life extension as being practical, considering the Navy is cutting the active P-3 force in half, and reducing the deployment cycle of the remainder, over fatigue issues. -- Andrew Toppan --- --- "I speak only for myself" "Haze Gray & Underway" - Naval History, DANFS, World Navies Today, Photo Features, Military FAQs, and more - http://www.hazegray.org/ |
"Thomas Schoene" wrote in message link.net...
JD wrote: I was checking out the new Naval Proceedings (I'm a new subscriber) and saw an advertisement for the 737 as a maritime patrol aircraft complete with hard points and weapons. It looks pretty cool, but I was surprised. Does anyone have it in their present inventory or is it merely a proposal to replace the aging P-3? It's one of two candiates for the Multi-Mission Maritime Aircraft. The other, from Lock-Mart, is yet another P-3 rebuild called Orion-21. The 737 MMA is based on the 737-800 but has a bunch of modifications, including a -900's wings, heavier gear, and a weapon bay forward of the wing carry-through. Indonesia uses (or at elats used to use) three older 737-200s for maritime surface patrol, with side-looking radar and a camera (plus maybe some SIGINT gear). Obviously MA is more elaborate. More Faux Warbird Mania. At least the Navy is showing the good sense to not expect the MMA to operate over hot battlefields like the ACS and MC2A are expected to...(AWST 10/13/03) "Navy officials also are refocusing the aircraft's role, after the P-3 community in recent years watched its mission migrate from anti-submarine warfare to overland targeting. MMA's core role will be anti-submarine warfare, stresses Rear Adm. Mark P. Fitzgerald, the service's air warfare director. Overland targeting will be taken up by UAVs, either a low-flying tactical system or the high-flying Broad Area Maritime Surveillance (BAMS) system the service hopes to buy soon. Although special operations forces have indicated they'd much rather work with a P-3-type aircraft than an unmanned system, Fitzgerald stressed that overland targeting "is not a core area" for the system." I really wonder what kind of climb/endurance performance the 737 MMA would have on 1 engine climbing off the deck as depicted and at the outer stretches of its mission radius with those doors stuck open? Also those low slung CFMs would be a limiting factor at any field where FOD would be problem...something that could happen in wartime at unimproved or damaged fields. The next time you are at an airport take a good look into the intakes on some of the 73s at the gates and notice how many have dings blended out of the fan blades |
On Wed, 10 Dec 2003 15:02:25 GMT, user wrote:
airborne surveillance mission will be. The arguement for 737 MMA and the cost involved just isn't convincing enough to a lot of us. I'd So what is your proposed alternative? Keep flying the P-3s forever, even when they start falling apart? -- Andrew Toppan --- --- "I speak only for myself" "Haze Gray & Underway" - Naval History, DANFS, World Navies Today, Photo Features, Military FAQs, and more - http://www.hazegray.org/ |
Andrew Toppan ) writes:
On Wed, 10 Dec 2003 15:02:25 GMT, user wrote: airborne surveillance mission will be. The arguement for 737 MMA and the cost involved just isn't convincing enough to a lot of us. I'd So what is your proposed alternative? Keep flying the P-3s forever, even when they start falling apart? That's what we do up here in Canada... |
Again Andy my friend, please reread the post from yesterday. I believe
an updated version of the P-7 LRAACA or the P-4 that were well into design stages in the 80's are perfect alternatives in my opinion. On Wed, 10 Dec 2003 18:52:51 -0500, Andrew Toppan wrote: On Wed, 10 Dec 2003 15:02:25 GMT, user wrote: airborne surveillance mission will be. The arguement for 737 MMA and the cost involved just isn't convincing enough to a lot of us. I'd So what is your proposed alternative? Keep flying the P-3s forever, even when they start falling apart? |
"Thomas Schoene" wrote in message news:KttBb.7541 It's one of two candiates for the Multi-Mission Maritime Aircraft. The
other, from Lock-Mart, is yet another P-3 rebuild called Orion-21. The 737 MMA is based on the 737-800 but has a bunch of modifications, including a -900's wings, heavier gear, and a weapon bay forward of the wing carry-through. One quibble Thomas. The Boeing offering is the 737-700 IGW. http://www.boeing.com/ids/allsystems...3/story09.html |
s.p.i. wrote:
"Thomas Schoene" wrote in message news:KttBb.7541 It's one of two candiates for the Multi-Mission Maritime Aircraft. The other, from Lock-Mart, is yet another P-3 rebuild called Orion-21. The 737 MMA is based on the 737-800 but has a bunch of modifications, including a -900's wings, heavier gear, and a weapon bay forward of the wing carry-through. One quibble Thomas. The Boeing offering is the 737-700 IGW. http://www.boeing.com/ids/allsystems...3/story09.html Old news. http://www.navyleague.org/sea_power/jun_03_28.php "Boeing is refining its MMA proposal for a design based on the Boeing 737 airliner, but has upgraded its entry from the 737-700 design--which would have the wings of the 737-800--to a 737-800 aircraft fitted with 737-900 wings." -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) |
The 737 MMA is based on the 737-800 but has a bunch of modifications, including a -900's wings, heavier gear, and a weapon bay forward of the wing carry-through. So I see that Boeing has old info on their website...Sorry about that Thom. http://www.navyleague.org/sea_power/jun_03_28.php Its gonna take some engineering to come up with that bomb bay. Also what about stores separation from the wings? Of course my favorite: combat vulnerability improvements? Sure it will have an altitude and transit/sprint speed advantage, but how will it behave down low? What will ice drag to fuel consumption below FL100? Low level characteristics seems to be a major issue with user. |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Boeing Boondoggle | Larry Dighera | Military Aviation | 77 | September 15th 04 02:39 AM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
