Winter project - Udo rigger
Old February 28th 10, 07:17 PM posted to rec.aviation.soaring
Andy[_1_]
Default Winter project - Udo rigger
On Feb 28, 7:52*am, JJ Sinclair wrote:
Errrrr.........
When I went to A&P school (oh so many years ago) they told us that
aircraft cables should NOT be lubercated.
What did they say about lubricating sheathed/enclosed cables such as
throttle, carb heat, and mixture? My experience is that, unless they
have an integral nylon sheath, they do need to be lubricated but LPS-2
in not a good choice.
BTW a review of AC 43.13-1b found this:
7-150. CORROSION AND RUST PREVENTION.
To ensure a satisfactory service life
for aircraft control cables, use a cable lubricant to
reduce internal friction and prevent corrosion.
My poor experience with LPS-2 on aircraft control cables was with the
enclosed throttle cable of my PA28-180.
I have never lubricated open control cables that run over pulleys
although AC43.13-1b does seem to say that is appropriate in some
circumstances.
thanks
Andy
Old February 28th 10, 08:03 PM posted to rec.aviation.soaring
Darryl Ramm
On Feb 28, 10:46*am, AGL wrote:
Water soluble marine grease works great on the pins for the spars when
rigging. *It cleans up with a wet rag and saves a trip to the
clubhouse to get the grease off of your hands.
MS
Most "marine greases" are designed to be water insolvent, resist
washout etc. in bearings. Water soluble lubricants are most commonly
used in tooling/cutting applications. What exact grease are you using?
Most people would just use a common hardware store lithium soap
grease. It's white does not make much mess and cleans up well with a
dry towel. Lithium soap greases vary in their water resistance, but
I'd expect the "marine" variants to be at the more water resistant
end.
Darryl
FS: Cobra one man rigger- Devin Bargainnier Soaring 0 February 24th 10 05:09 AM
Wanted: One-man wing rigger Bastoune Soaring 4 February 21st 10 04:48 PM
Winter project, tow out gear - wing wheel bildan Soaring 39 November 14th 08 12:27 AM
Used Cobra Wing Rigger For Sale Jeremy Zawodny Soaring 2 May 8th 06 05:26 PM
Winter project [email protected] Soaring 10 January 2nd 05 01:11 PM
