Blue Angels F-18A Hornet on E-Bay
Old February 6th 04, 12:37 AM
ABH3
According to
http://home.att.net/~jbaugher/thirdseries21.html
The BuNo 161973 a Legit F/A-18 Hornet that at one time flew with the
Blue Angels Naval Flight Team... Also.. More pictures of Said Aircraft
is at this website...
http://www.blueangels.org/Aircraft/S...18/973/973.htm
Hope i was of some help...
-Damien
ABH3 US Navy (Active)
"Mr Smith" wrote in message ...
http://cgi.ebay.com/ws/eBayISAPI.dll...ategory=46 72
What do you guys think ??
Legit or bogus ?
ABH3
According to
-Damien
Legit or bogus ?
Old February 6th 04, 06:04 AM
Joe Delphi
From the photos it appears that the wings have been cut off and the canopy
removed. Also looks like nose landing gear is missing. It definitely
looks like it needs more than a "once over" to me.
JD
Old February 6th 04, 12:23 PM
Doug \Woody\ and Erin Beal
On 2/6/04 12:04 AM, in article
. net, "Joe Delphi"
JD
Lot 6... Probably needs a lot of work with regard to engineering support and
depot-level mods depending on when it flew last.
I've seen a few jets-turned-private... and the more complex the jet, the
more I wonder how these folks truly maintain them. In the case of the
F/A-18, it's a pretty complex game.
--Woody
Old February 6th 04, 12:35 PM
On 2/5/04 3:54 PM, in article , "Mr Smith"
I contacted the seller, he states the aircraft is not
airworthy at this time and he's not the actual owner,
just brokering the sale. It would need to be "gone
over" before it can fly.
He also stated it has not been de-mil'd. Were F-18A's
in the Blue Angel's mission capable (outside their PR
role) ? I can't see how it would be legal to sell an
untouched, strike capable aircraft.
One would presume export control laws would apply if
a buyer in say, Iran, wanted to bid on it.
The Buy-It-Now price does seem rather low.
It might reflect a "I-need-to-get-rid-of-this-because
I-can't-insure-it" dilemma the owner has.
All the Hornet drivers here, if I'm a Citation X pilot
with 4500+ hrs, how difficult is landing a Hornet ?
I imagine the ONLY place one can acquire training on
them is in the Navy (Marines included).
There are a couple of "gotchas" in just flying the thing, but nothing a few
flights wouldn't iron out.
If you've never experienced flight gear, that would be a new treat (helmet,
mask, torso harness, g-suit).
Since the motors are way in the back (35 or so feet behind you), you'd have
to get used to the "detached" sensation of flying the jet. There is no air
noise or airframe feedback with regard to airspeed or engine power setting
whatsoever. The airplane feels the same flying at 180 kts at 30000 feet as
it does at 550 kts at 500 feet. A good instrument scan is a must.
WRT landings, the HUD makes them pretty easy. On this Lot 6, you may find
single chamber struts which means CV type landing is probably not a good
idea (max trap for single chamber struts was 30,500 lbs vice the 33k UNR or
34K Restricted for the current F/A-18). Pretty simple stuff to flare a
landing in the Hornet though. I have taken guests into the simulator, and
the ones with some flight time do fairly well at getting it on the runway.
The biggest landing obstacle would be encouraging you NOT using a forward
slip as a crosswind correction--makes the airplane do the funky chicken on
the runway. OBTW, no localizer, ILS, VOR. Either fly TACAN approaches or
PAR in the weather (if you want a precision approach).
--Woody
Old February 6th 04, 01:49 PM
John Carrier
The F-18 has perhaps the most benign flying qualities of any high
performance jet aircraft. X-wind landings require a particular technique
(as Woody states). Otherwise, it's difficult to hurt yourself if you honor
its envelope, know your procedures, and have a well-maintained airframe.
The big issue with any high performance military jet is getting it airworthy
and keeping it airworthy. Warbirds can be had for ridiculously low prices
(particularly compared to small corporate jets), but getting them up and
keeping them up makes even Travolta's 707 toy look like a relative bargain.
Of course, 1300 gallons give-or-take of JP per sortie (often a particularly
SHORT sortie) makes it pricey as well.
I wonder how difficult it would be to retrofit a nice modern GPS-based nav
system and ILS (not many airports .... any? ... have an operational
TRN-28)?\
R / John
Old February 6th 04, 05:06 PM
Harry Andreas
In article , "John Carrier"
Not that hard at all, as long as you don't mind re-wiring parts of the aircraft.
The old 1553 bus on the A's won't handle the data rate of more modern
GPS/nav systems.
Harry Andreas
Engineering raconteur
Old February 6th 04, 09:46 PM
On 2/6/04 7:49 AM, in article , "John
TRN-28)?\
R / John
Well put.
There are a few rubs in the flight instruments and systems areas to owning
your own F/A-18.
All the black boxes (circa 14 IIRC from my China Lake days) in the Hornet
are integrated. Some are more important to flight safety than others. For
instance, I'm pretty sure you could remove the radar without significant
penalty and fly the thing around lead-nosed using TCAS for traffic
deconfliction, but if you decided to remove the INS (for cost), you'd
severely degrade your primary flight instrument (which is the HUD)--unless
you could refit a cheap substitute (optical gyros and a GPS? AHRS only?).
But the INS and the ADC both feed the HUD, so you'd definitely degrade the
info on it.
Brings up another point. What FCC PROM is the jet running? My guess is
pre-10.7, but if you're running PROM 10.7, then there's a definite need for
an INS. There'd be some definite engineering and support issues all over.
Better have very deep pockets and be willing to pay a fairly large $/hour
cost. Fuel is probably the least of your worries given the team of folks it
would take to keep it airworthy.
--Woody
Old February 6th 04, 11:00 PM
John Miller
for
it would take to keep it airworthy.
How many hours of ground maintenance per flight hour for the F-18?
I'd love to have it, but figure you can get 80% of its performance for about
20% of the operational cost. A4? MiG?
John Miller
My email address: domain, n4vu.com; username, jsm
The mosquito is the state bird of New Jersey.
-Andy Warhol
Old February 7th 04, 03:15 AM
Joe Delphi
The F/A-18s that the Blues fly are slightly different from Fleet F/A-18s.
I know that one difference is in the fuel system. The Blue Angel F/A-18s
have something in their fuel system that allows them to fly negative Gs
longer than the regular F/A-18. I guess its bad form to have your engine
conk out from fuel starvation in the middle of an airshow.
There are probably other mods to the BA F/A-18s that other people could
list.
JD
Blue Angels Show ramrod48 Military Aviation 6 September 7th 04 10:01 PM
Blue Angels star in air show Otis Willie Military Aviation 9 May 25th 04 05:41 PM
Once again-Threshold, The Blue Angels Experience Pechs1 Naval Aviation 28 February 8th 04 12:22 AM
Blue Angels Video - Is it a Fake? Ken Morano Military Aviation 4 November 18th 03 10:14 PM
Blue Angel's Gear Door Broken? Clay N4AOX Military Aviation 15 October 6th 03 08:01 AM
