george wrote:
/snip/ I found that I trimmed the aircraft to fly in what ever attitude I required at that time. I didn't make a point of examining where the pointer was . Better check the trim setting before applying power on the takeoff. As the Vital Actions used to be recited: (and are now read out, in some form...) Trim for takeoff Throttle nut tight Mixture rich Air cold Prop pitch fine Fuel on mains Flaps as required Harness and Hatches secure Instruments in limits and set Brian W |
On Apr 22, 11:10*pm, brian whatcott wrote:
george wrote: /snip/ I found that I trimmed the aircraft to fly in what ever attitude I required at that time. I didn't make a point of examining where the pointer was . Better check the trim setting before applying power on the takeoff. As the Vital Actions used to be recited: * (and are now read out, in some form...) Trim for takeoff Throttle nut tight Mixture rich Air cold Prop pitch fine Fuel on mains Flaps as required Harness and Hatches secure Instruments in limits and set Quoted from my original message I found that I trimmed the aircraft to fly in what ever attitude I required at that time. I used the TTMPFFIIHHC check list on powered aircraft CHICHAT or CBSITCB for sailplanes |
On Apr 22, 10:22*am, Mxsmanic wrote:
writes: Of course in simulators it will be the same. *He doesnt' fly a plane where weight and balance issues come to play that affect trim settings like in my real plane. Weight and balance issues are correctly simulated for the most part. And you know this by how?????? What tangible facts can you base this on your own experiences to know what you say above is true? My original question concerned the fact that I often find that my trim setting upon landing is also near the middle of the takeoff range, just as it was for takeoff. And this seems to happen even though I'm not looking at the trim indicator as I trim for my stabilized approach. I was just wondering if this is a coincidence, or something that is more or less to be expected. You would know the answer as I gave you the answer. Also read the answers others gave you as they gave you the answers too. WHY DID YOU ASK THE QUESTION IF YOU FELT MSFS SIMULATION WAS CORRECT for the most part??? Could it be it there is a high chance it doesn't reflect real flying?????? |
On Apr 20, 11:55*pm, Mxsmanic wrote:
Lately I have made a more stringent attempt to trim the aircraft on approach for landing, and I note that I often end up with a trim setting that is right inside the takeoff trim setting. Is this a coincidence, or something that is to be expected? Because you fly out at 65 kts and land at the same speed. The commonality is your airspeed. --- Mark |
Mark wrote
Because you fly out at 65 kts and land at the same speed. The commonality is your airspeed. Mark, you have failed to consider that in most lightplanes, the TO is made with FLAPS UP and landings are generally made with FULL FLAPS. Flaps require a really large trim adjustment, remember the GO-AROUND... the large trim change required immediately after applying power and raising the flaps? The difference between TO power and approach power also adds to this large trim change in propellor driven aircraft. Bob Moore ATP CFII PanAm (retired) |
On Apr 21, 9:08*am, Bob Moore wrote:
Mark wrote Because you fly out at 65 kts and land at the same speed. *The commonality is your airspeed. Mark, you have failed to consider that in most lightplanes, the TO is made with FLAPS UP and landings are generally made with FULL FLAPS. True, that's all I've ever experienced. Flaps require a really large trim adjustment, remember the GO-AROUND... the large trim change required immediately after applying power and raising the flaps? Yes. I'm also trimming on each leg including final. The difference between TO power and approach power also adds to this large trim change in propellor driven aircraft. I certainly defer to your greater experience. It's speculation that a coincidence of airspeed has his trim set at the same place with take-off and landing, but...if he's just playing computer games, then this is all probably irrelevant, as simulation doesn't really translate to the real world. Thanks. --- Mark Bob Moore ATP CFII PanAm (retired) |
On Apr 21, 9:32*am, Mark wrote:
Snippage as simulation doesn't really translate to the real world. Thanks. --- Mark Bob Moore ATP CFII PanAm (retired) To quote the bunyip: BWAHAHAHAHAHAHA!!! Yeah genius, tell that to Boeing, LockMart and nasa to name a few. Idiot. |
On Thu, 22 Apr 2010 04:35:23 -0700 (PDT), Richard wrote:
On Apr 21, 9:32*am, Mark wrote: Snippage as simulation doesn't really translate to the real world. --- Mark To quote the bunyip: BWAHAHAHAHAHAHA!!! Yeah genius, tell that to Boeing, LockMart and nasa to name a few. Idiot. Now, now , Richard, if you upset Mark(ie) he'll swear out *DEATH THREATS* on you, change his name three dozen times, and TROLL your ass off. He's really quite the bi-polar nazz that boi is. *snicker* -- A fireside chat not with Ari! http://tr.im/holj Motto: Live To Spooge It! |
| Thread Tools | |
| Display Modes | |
| interesting video of a takeoff and landing | John | Piloting | 7 | November 13th 07 02:19 AM |
| Please adjust your trim settings. | Montblack | Owning | 17 | April 11th 07 09:04 PM |
| Takeoff/Landing same direction? | Willie | Soaring | 24 | September 13th 06 05:47 AM |
| Stuck at work--need takeoff/landing distances for a 172 please | Yossarian | Piloting | 12 | July 14th 05 02:12 PM |
| Takeoff/Landing roll data | John Penta | Military Aviation | 4 | October 30th 03 05:18 AM |
