#11
VOR-DME writes:
Heady stuff! Looks like the FAA and the NextGen developers better start spending more time with USA Today, so they can be up to speed on all this stuff they never even tought of! USA Today is not the source of this information. And the FAA (or at least the NextGen groupies at the FAA) won't care until someone dies. After all, they look the other way when airlines violate regulations. |
VOR-DME writes:
I’m sure the FAA is relieved to know that you’re on the case ... The FAA has its head firmly buried in the sand. As far as the VOR’s are concerned, you’re barking up the wrong tree. ADS-B OUT is the first mandated item, but far from the last. ADS-B IN will follow shortly, CPLDC datalink and UAT transceivers as well. At this point we are one ARINC fiber cable away from full ground-based control of every airplane in the system (not that this is a stated goal, but to demonstrate that we are soon achieving far better system integration than your 1980’s instrument textbook lets on). So the VOR’s are really superfluous with a few exceptions, which will be retained along with the odd NDB. What takes over when GPS fails? Loran is gone. NDBs and VORs supposedly will be gone. What's left? A magnetic compass? It will be important to maintain a minimum structure of surveillance radar as a backup ... Radar should be permanently retained. It helps prevent spoofing, for example. Where the battle lines will be drawn is over the issue of cost per participating aircraft and equipment mandates that the AOPA is likely to see as overkill and overpriced for GA. The FAA seems to be much more a friend of airlines than a friend of GA. |
VOR-DME writes:
I just told you, and you didn't get it. None of the things you mention provides navigation capabilities. The aircraft and its crew still have to be able to determine where they are. They cannot do that with datalinks or other gadgets unrelated to navigation. Even remote ground control of aircraft would require some sort of on-board navigation system, unless the system relied on theoretical calculations and dead reckoning, which would be hopelessly inaccurate in practice. |
On May 30, 8:38*am, Mxsmanic wrote:
VOR-DME writes: I just told you, and you didn't get it. None of the things you mention provides navigation capabilities. The aircraft and its crew still have to be able to determine where they are. They cannot do that with datalinks or other gadgets unrelated to navigation. Even remote ground control of aircraft would require some sort of on-board navigation system, unless the system relied on theoretical calculations and dead reckoning, which would be hopelessly inaccurate in practice. Bloody hell but you're thick. Didn't you read what he wrote and assimilate/understand the information? |
On May 29, 3:06*pm, VOR-DME wrote:
I just told you, and you didn't get it. We are at MXMAX now - that's the threshold where MX cannot assimilate any more information Well VOR DME, you a better man then me going as far as you did. He has no clue what the real world is out here. As I stated in my first reply to him, why should he be concerned as he is not a user of the system for navigation. His reading comprehension seems be less then a 6 year old as I am not familiar with the next generation stuff but you did an outstanding job explaining it in user friendly terms for this pilot. |
george wrote:
On May 30, 8:38*am, Mxsmanic wrote: VOR-DME writes: I just told you, and you didn't get it. None of the things you mention provides navigation capabilities. The airc raft and its crew still have to be able to determine where they are. They cann ot do that with datalinks or other gadgets unrelated to navigation. Even remote ground control of aircraft would require some sort of on-board navigation system, unless the system relied on theoretical calculations and dead reckoning, which would be hopelessly inaccurate in practice. Bloody hell but you're thick. Didn't you read what he wrote and assimilate/understand the information? I read and assimilated the part where VOR-DME used the classical fallacy of appeal to authority: "... if you believe someone with your limited understanding of the system is going to dream up failure modes that the NextGen developers, in their haste, have not worked out to the tenth decimal place..." It is an assertion of competence on the part of the FAA that also happens to be historically inaccurate. The only legitimate goal that the FAA can reasonably seek by its rules, separation of commercial aircraft from all other airborne objects (including birds), could also be accomplished by requiring on-board radar and alert systems for those aircraft. This is a technical alternative to ADS-B that accomplishes that goal. It also manages to equitably match the burden with the benefit. It also permits non-commercial GA the freedom to choose their level of risk versus cost. The ADS-B out mandate doesn't accomplish either of the above. |
| Thread Tools | |
| Display Modes | |
| (USA) US/Mexico "airspace" (boundary) files available | Tuno | Soaring | 4 | March 27th 10 08:17 PM |
| some planes [11 of 11] "old-air-planes-crashed-underwater-photos-pictures.jpg" yEnc (1/1) | No Name | Aviation Photos | 0 | August 9th 09 10:36 PM |
| On Sharing airspace with "non-rated UAV "pilots" | vaughn | Piloting | 15 | March 15th 09 05:08 PM |
| "Fly Baby, you violated Class B Airspace" | Ron Wanttaja | Piloting | 27 | September 5th 07 09:30 PM |
| Aviation Conspiracy: Connecticut To Get "Creamed" By Airspace Redesign Change? | Free Speaker | General Aviation | 0 | August 8th 06 03:42 PM |
