#11
On Jun 23, 11:45*am, Bob Kuykendall wrote:
On Jun 23, 8:17*am, Derek C wrote: Actually the maximum bending load on the wingspar during a winch is equivalent to about 3 g, due to the point loading on the fuselage and the lack of g unloading on the wings, but that still shouldn't cause a failure... I think that 3g equivalent load is a large enough percentage of the limit load to constitute a fatigue concern. If I were assessing service histories, I would definitely want to know the cycle count on activities likely to cause that kind of load. Thanks, Bob K. Actually, it's probably worth worrying about any old, high-time metal glider. Hard landings and turbulence flex the wings too. Blanik maintenance manuals expressly limit the airframe life if used with winch launch. AFAIK, no composite glider has exhibited a failure mode anything like this. |
![]() AFAIK, no composite glider has exhibited a failure mode anything like this. yet. everything wears out eventually. even my beloved wood gliders will probably eventually wear out. but at least the parts grow on trees. |
On Jun 23, 6:45*pm, Bob Kuykendall wrote:
On Jun 23, 8:17*am, Derek C wrote: Actually the maximum bending load on the wingspar during a winch is equivalent to about 3 g, due to the point loading on the fuselage and the lack of g unloading on the wings, but that still shouldn't cause a failure... I think that 3g equivalent load is a large enough percentage of the limit load to constitute a fatigue concern. If I were assessing service histories, I would definitely want to know the cycle count on activities likely to cause that kind of load. Thanks, Bob K. Most modern gliders are stressed to take at least +5.3/-2 g without damage. A winch launch comes nowhere near this as long as the correct weak link is fitted, which will break well before the glider does. I believe that the glider that failed had being doing aerobatics immediately before, which is a more likely cause of any overstressing. Derek C |
On Jun 23, 6:51*pm, Derek C wrote:
On Jun 23, 6:45*pm, Bob Kuykendall wrote: On Jun 23, 8:17*am, Derek C wrote: Actually the maximum bending load on the wingspar during a winch is equivalent to about 3 g, due to the point loading on the fuselage and the lack of g unloading on the wings, but that still shouldn't cause a failure... I think that 3g equivalent load is a large enough percentage of the limit load to constitute a fatigue concern. If I were assessing service histories, I would definitely want to know the cycle count on activities likely to cause that kind of load. Thanks, Bob K. Most modern gliders are stressed to take at least +5.3/-2 g without damage. A winch launch comes nowhere near this as long as the correct weak link is fitted, which will break well before the glider does. I believe that the glider that failed had being doing aerobatics immediately before, which is a more likely cause of any overstressing. Derek C If I recall correctly, the concern was with fatigue damage accumulating at loads below the limit load. If fatigue cracks do form, you could get a static failure below limit load - and not necessarily during a winch launch. How serious this concern should be in the case of the L-13 I couldn't say but given that they think it might have been a fatigue crack, the AD seems pretty reasonable. JM. |
On Jun 23, 3:51*pm, Derek C wrote:
Most modern gliders are stressed to take at least +5.3/-2 g without damage... It is true that operation within the limit load should not cause any damage in the sense of bent, stretched, or torn structure that precludes continued operation. However, at the same time every single load cycle causes the accumulation of fatigue that, given a long enough service life, will eventually cause failure. Aluminum structures require careful consideration of fatigue and service life, since there is no level of stress below which fatigue does not accumulate. If you take an aluminum wing designed to a 5.3g limit load and load cycle it from 0g to 1g and back a relatively large number of times, it will eventually break without ever having been stressed over 1g. That is one of the reasons that there is some margin (usually 50%) between limit load and ultimate load. The key, question, of course, is how many cycles does it take? The extreme example I cite above will probably take many, many times the number of cycles equivalent to the flight hours in the planned service life. Given greater loads, the number of cycles to failure is reduced. And of course, given lower loads, the number of cycles is increased. But the important thing is that, for aluminum at least, there is no level of loading at which the cycle count goes to infinity. An infinitesimal loading, repeated enough times, will result in eventual failure. Thanks, Bob K. |
On Wed, 23 Jun 2010 16:35:56 -0700 (PDT), Judah Milgram
wrote: snip Most modern gliders are stressed to take at least +5.3/-2 g without damage. A winch launch comes nowhere near this as long as the correct weak link is fitted, which will break well before the glider does. I believe that the glider that failed had being doing aerobatics immediately before, which is a more likely cause of any overstressing. Derek C If I recall correctly, the concern was with fatigue damage accumulating at loads below the limit load. If fatigue cracks do form, you could get a static failure below limit load - and not necessarily during a winch launch. How serious this concern should be in the case of the L-13 I couldn't say but given that they think it might have been a fatigue crack, the AD seems pretty reasonable. JM. Actually and AD has not been issued by the FAA. A mandatory bulletin from the manufacture has been issued. There is a huge difference. An AD is mandatory in the US. A mandatory bulletin by the manufacture is optional. |
On Jun 23, 9:31*pm, harold wrote:
On Wed, 23 Jun 2010 16:35:56 -0700 (PDT), Judah Milgram wrote: snip Most modern gliders are stressed to take at least +5.3/-2 g without damage. A winch launch comes nowhere near this as long as the correct weak link is fitted, which will break well before the glider does. I believe that the glider that failed had being doing aerobatics immediately before, which is a more likely cause of any overstressing. Derek C If I recall correctly, the concern was with fatigue damage accumulating at loads below the limit load. If fatigue cracks do form, you could get a static failure below limit load - and not necessarily during a winch launch. How serious this concern should be in the case of the L-13 I couldn't say but given that they think it might have been a fatigue crack, the AD seems pretty reasonable. JM. Actually and AD has not been issued by the FAA. *A mandatory bulletin from the manufacture has been issued. *There is a huge difference. *An AD is mandatory in the US. *A mandatory bulletin by the manufacture is optional. You're right, the subject AD was issued by EASA, not FAA. But given that a wing just failed due to a possible fatigue crack, most US owners will probably want to comply anyway (just guessing here). Judah Milgram |
On Jun 23, 9:58*pm, "Morgans" wrote:
If that is indeed the case, the glider in question is improperly rated. An aircraft should be rated to take the stated load, of say 6G positive, to 4G negative, _PLUS_ a safety factor, usually from 125% to 150% *of the maximum load. (and here is the big kicker in this case) *_WITHOUT_ doing permanent damage at the rated load. *NEVER doing damage. *Not even fatigue damage after "X" number of cycles. If it is being flown at or under the rated loads and fatigue cracking or other damage is happening, it is not designed to the load that was stated, IMHO. *It should be de-rated or strengthened. Well, that pretty much rules out every aircraft with aluminum structure, no matter how stout. As I wrote previously, with aluminum there is absolutely no level of stress that is so low that it does not cause fatigue. An infinitesimal deflection repeated an infinite number of times will cause fatigue failure. Please don't misconstrue, I am not saying that aluminum structures are inherently unsafe. They can be designed and engineered so that they provide very good safety over perfectly reasonable service lives. However, they cannot be made immune from fatigue. That is why they have established (or at least estimated) service lives. As a practical matter, the more structural margin an aircraft has, the greater its resistance to fatigue. However, extra margin means extra weight and decreased performance and utility. As with everything in aircraft design and engineering, it is a compromise and a balancing act. As a regulatory matter, if I recall correctly, service life limits were not specifically required under the old CAR 3 regulations under which vast numbers of aircraft, including many sailplanes and training gliders still in service, were certificated up through the 1950s and perhaps 1960s. However, the more modern 14CFR Part 23, and very similar JAR22 do require an evaluation of the structure to determine that fatigue damage will not occur within the operational life of the aircraft. One example I know of where service life is an issue in general aviation airplanes is the center and outboard main wing spars of the AA1 and AA5 series of small airplanes built by Grumman, Gulfstream, and others. The aircraft type certificate specifically limits the service lives of these components to 12000 and 12500 hours respectively, and many examples of the type have come up against these limits. Thanks, Bob K. |
On 6/23/2010 9:58 PM, Morgans wrote:
An aircraft should be rated to take the stated load, of say 6G positive, to 4G negative,_PLUS_ a safety factor, usually from 125% to 150% of the maximum load. (and here is the big kicker in this case)_WITHOUT_ doing permanent damage at the rated load. NEVER doing damage. Not even fatigue damage after "X" number of cycles. Isn't this true only until the maximum service life has been reached? Paul ZZ |
On Jun 24, 9:40*am, Bob Kuykendall wrote:
On Jun 23, 9:58*pm, "Morgans" wrote: If that is indeed the case, the glider in question is improperly rated. An aircraft should be rated to take the stated load, of say 6G positive, to 4G negative, _PLUS_ a safety factor, usually from 125% to 150% *of the maximum load. (and here is the big kicker in this case) *_WITHOUT_ doing permanent damage at the rated load. *NEVER doing damage. *Not even fatigue damage after "X" number of cycles. If it is being flown at or under the rated loads and fatigue cracking or other damage is happening, it is not designed to the load that was stated, IMHO. *It should be de-rated or strengthened. Well, that pretty much rules out every aircraft with aluminum structure, no matter how stout. As I wrote previously, with aluminum there is absolutely no level of stress that is so low that it does not cause fatigue. An infinitesimal deflection repeated an infinite number of times will cause fatigue failure. Please don't misconstrue, I am not saying that aluminum structures are inherently unsafe. They can be designed and engineered so that they provide very good safety over perfectly reasonable service lives. However, they cannot be made immune from fatigue. That is why they have established (or at least estimated) service lives. As a practical matter, the more structural margin an aircraft has, the greater its resistance to fatigue. However, extra margin means extra weight and decreased performance and utility. As with everything in aircraft design and engineering, it is a compromise and a balancing act. As a regulatory matter, if I recall correctly, service life limits were not specifically required under the old CAR 3 regulations under which vast numbers of aircraft, including many sailplanes and training gliders still in service, were certificated up through the 1950s and perhaps 1960s. However, the more modern 14CFR Part 23, and very similar JAR22 do require an evaluation of the structure to determine that fatigue damage will not occur within the operational life of the aircraft. One example I know of where service life is an issue in general aviation airplanes is the center and outboard main wing spars of the AA1 and AA5 series of small airplanes built by Grumman, Gulfstream, and others. The aircraft type certificate specifically limits the service lives of these components to 12000 and 12500 hours respectively, and many examples of the type have come up against these limits. Thanks, Bob K. Bob, You've stated this about as clearly as it can be stated and you're perfectly correct. Bend metal and it fatigues - keep bending it and it will eventually fail. The damage starts at zero hours and gets worse from there. Stated or not, there's always a life limit for metal aircraft. There's just no way around it. Any old, high-time metal glider is suspect. If they've spent years out in the weather where corrosion can start in those tiny fatigue cracks, they're even more suspect. Something to think about when you hear the boink! boink! of "oil-canning" aluminum skins. The way it usually works is sometime, somewhere, a wing falls off and the aviation authorities order every owner/operator of that type to take a really good look inside their wings. If the results are ugly, there will be an AD ordering replacement of the fatigued metal. The owner/operator gets to decide whether its economic to do so. Sometimes it isn't and the aircraft gets scrapped. We're all a little bit of a test pilot. |
Blanik L-23 Super Blanik Manual -F.C.F.S. | Joel Flamenbaum | Soaring | 2 | April 14th 10 03:29 PM |
Mandatory ELT | [email protected] | Soaring | 9 | March 8th 05 03:01 PM |
ELT Mandatory ? | Jim Culp | Soaring | 20 | June 19th 04 06:40 PM |
New security bulletin | gatt | Piloting | 28 | June 9th 04 10:33 PM |
Grob 103 bulletin becomes AD | Mike Borgelt | Soaring | 0 | October 3rd 03 12:47 AM |
