carbon fiber wing wheel dolly
Old July 28th 10, 03:42 PM posted to rec.aviation.soaring
Tim Taylor
Default carbon fiber wing wheel dolly
On Jul 28, 8:37*am, Bob Kuykendall wrote:
On Jul 27, 10:14*pm, Brad wrote:
ya know, that is a pretty cool looking contraption, but from a
homebuilder point of view, making it out of aluminum tubing, extrusion
and flat sheet is much easier and less labor intensive. might be a bit
heavier, but not much. of course the wing cuff would be composite!
Actually, the carbon has some pretty compelling advantages. It is a
lot lighter, so that it is easier to stow, carry, and attach.
I think that carbon sleeve over EPS or EPP rod would indeed do the
trick for the arm. If you were serious about it, you'd have a high-
pressure female mold, and mold the part by inflating a plastic bladder
inside the sleeve material, but the male molded part would be almost
as stiff and easier and cheaper to make for just one or two.
As Dave points out, it can be made springier, so that the goofy steel
spring and shock absorber isn't required. The way it grabs the axle on
only one side of the wheel is a neat trick, but the greater bending
loads makes the axle heavier than if the arm were forked.
As Andy points out, the leading arm might be divergent, but I don't
think that it is actually unstable except at very high speeds and
loads.
Thanks, Bob K.
I like the whole concept except the fact I then will need to add
weight to the wingwheel or tip on that side to prevent the other wing
from hitting the ground. Similar to when you tow out with water.
Sometimes lighter is not better.
Old July 28th 10, 04:52 PM posted to rec.aviation.soaring
bildan
loads.
Thanks, Bob K.
from hitting the ground. *Similar to when you tow out with water.
Take something you're going to carry out with the glider anyway - like
a parachute - and make a way to securely lay it atop the wing glove.
Make it short enough the glider tilts toward the wheel.
Old July 28th 10, 06:35 PM posted to rec.aviation.soaring
Andy[_1_]
All far too complicated!
When I built my wing wheel I prototyped the legs with 3/4 inch
schedule 40 pvc pipe. The idea was to get the geometry right then
make to final legs from aluminium square tube. It turned out the sched
40 pvc was perfect for the job. It is dimensionally stable, has just
the right amount of spring, and does no damage anything it bangs or
rubs against. The protype legs have lasted 8 years. They will be
changed this winter for a design that allows height adjustment but
I'll use the same material.
Andy (GY)
Old July 28th 10, 08:32 PM posted to rec.aviation.soaring
SoaringXCellence
schedule 40 pvc pipe. *The idea was to get the geometry right then
40 pvc was perfect for the job. *It is dimensionally stable, has just
rubs against. *The protype legs have lasted 8 years. *They will be
Andy (GY)
How about pictures Andy, Any place you could post them for others to
view?
Old July 29th 10, 03:12 AM posted to rec.aviation.soaring
flyingmr2
Windward performance makes a wing wheel for the Sparrowhawk that uses
two skate wheels. It's really neat and has a natural spring arc made
out of carbon fiber and fiberglass with two skate wheels on the
bottom. It pivots 360 deg for which every way you drag the
sailplane. Yes the wing is only 42 lbs so it might not scale up to
full weighted sailplanes. Sorry I have no photos but I thought it
might be an interesting idea out there for those entrepreneurs. It
does not fold but stores well as it is small. Just an idea that you
don't have to use a bike tire like every one else.
JOhn
Old July 29th 10, 05:24 AM posted to rec.aviation.soaring
Grider Pirate
On Jul 28, 7:12*pm, flyingmr2 wrote:
Windward performance makes a wing wheel *for the Sparrowhawk that uses
two skate wheels. *It's really neat and has a natural spring arc made
bottom. *It pivots 360 deg for which every way you drag the
sailplane. *Yes the wing is only 42 lbs so it might not scale up to
full weighted sailplanes. * Sorry I have no photos but I thought it
does not fold but stores well as it is small. *Just an idea that you
JOhn
I love the Windward wing wheel setup. I saw it at Mountain Valley
(Tehachapi) and it handled the gopher holes just fine!
Old July 29th 10, 02:58 PM posted to rec.aviation.soaring
Andy[_1_]
On Jul 28, 12:32*pm, SoaringXCellence wrote:
How about pictures Andy, *Any place you could post them for others to
view?
I dug out a couple of photos and will send them to you if you email
me. My RAS address is valid.
I don't have a photo sharing account.
Andy
Old July 29th 10, 03:26 PM posted to rec.aviation.soaring
bumper[_3_]
JOhn
But like Tom says, there's a problem when it's too light.
I "kludge" repaired a Sparrowhawk wing wheel. Owner added weight to
top of wing to keep it down. This caused composite to slowly grind
away near radius and further weaken. At least for moving the glider on
pavement in stronger conditions, the composite spring isn't strong
enough to allow adding the needed weight,
bumper
MKIV & QV
Minden
Old July 29th 10, 05:01 PM posted to rec.aviation.soaring
mattm[_2_]
view?
me. *My RAS address is valid.
Andy
I'd love to see some pictures, too. Unfortunately, I don't have
anywhere
to post them either.
Last year at Cordele the guy parked next to me had a homemade wing
wheel.
He'd used a couple of pieces of copper tubing bent into a U-shape and
flattened
at the ends so he could run the bicycle wheel axle through them. He
attached
the bottom part of the U's to an old skateboard. The whole
contraption got
put on the wing with some bungy cords. It worked fine for him,
although
it didn't hold the plane level. That would have been a problem if he
wasn't
flying club class (no ballast).
-- Matt
Old July 29th 10, 05:47 PM posted to rec.aviation.soaring
Andy[_1_]
On Jul 29, 9:01*am, mattm wrote:
I'd love to see some pictures, too. *
I posted them to SSA where they can be seen by non members as well as
members.
Go to SSA home page http://www.ssa.org/
then select "About Soaring" / "Photo Gallery"
They currently show at the top of the page.
Members can find me and then go to my gallery
One photo is a duplicate. I have not yet found out how to delete a
photo I posted or how to edit the text after posting.
Andy
Duo Discus Wing Wheel -- not Dolly [email protected] Soaring 0 November 1st 07 03:57 AM
Carbon fiber shortage? [email protected] Home Built 3 December 11th 05 07:24 AM
Composite & Carbon Fiber NW_PILOT Home Built 11 September 21st 04 06:21 PM
carbon fiber dutchpilot Home Built 0 June 16th 04 12:20 PM
Carbon fiber vs. antennas [email protected] Owning 2 January 2nd 04 01:40 PM
