Push-Pull propeller combinations.
Old September 3rd 10, 07:35 AM posted to rec.aviation.military,rec.aviation.military.naval
David E. Powell
Default Push-Pull propeller combinations.
On Sep 2, 9:15*pm, Eunometic wrote:
On Sep 3, 6:19*am, Peter Twydell wrote:
In message
Eunometic writes
Several aircraft have been built with both a pull (or tractor)
propeller and a push (or rear) propeller aligned with each other.
Supposedly the arrangment is inefficient, yet the some of the Dornier
aircraft were record breakers.
Given that some aircraft were ruined or delayed by the problem of
combining gearboxes (He 177, Northrop XB-35 and if it ever came to it
the B-29 with its backup V-3420) * it looks like an attractive
proposition.
What's going on here?
List of such aircraft:
Cessna 337 Skymaster
Rutan Model 76 Vogager
Adam A500
Dornier Wal
Dornier Do X
Dornier Do 18 Seaplane, the German PPY Catalina.
Dornier Do 26K Seaplane, possibly the longer ranged seaplane ever
built.
Dornier Do 335 Pfeil (arrow) *perhaps one of the fastest piston
engined aircraft ever built.
Dornier Seawings Seastar, modern Seaplane of composites.
Savoia-Marchetti S.55
LeO H-242
And the Fokker D.XXIII, of course.http://www.aviastar.org/air/holland/fokker_d-23.php
Peter
I like this aircraft, a 6500lb, 324mph speed one a pair of 520hp
engines means it matches aircraft of the same weighyt with the same
power in a larger single engine.
And the Hungarian Marton X/V looking like a sort of push pull Me 109.http://www.whatifmodelers.com/index....c,24457.0.html
That just looks like a Speed machine. Maybe some video game like
Crimson Skies will use it someday.
Old September 3rd 10, 02:20 PM posted to rec.aviation.military,rec.aviation.military.naval
Ken S. Tucker
the B-29 with its backup V-3420) it looks like an attractive
proposition.
Overall the Puller-Pusher is complicated.
1) the Pusher needs serious clearance for landing and takeoff.
2) if it's a twin engine, a strong structure is required to connect
the engines, (wing based twins use the existing spar).
3) a single engine P-P needs a long horizontal shaft.
4) the inertial moment is greater if a passenger bay is between
the engines.
5) there is an unpredictable airstream for the Pusher.
....and more.
Ken
Adam A500
Dornier Wal
Dornier Do X
built.
Dornier Do 335 Pfeil (arrow) perhaps one of the fastest piston
LeO H-242
Old September 3rd 10, 02:24 PM posted to rec.aviation.military,rec.aviation.military.naval
Peter Skelton
On Thu, 2 Sep 2010 18:22:49 -0700 (PDT), Eunometic
proposition.
Adam A500
Dornier Wal
Dornier Do X
built.
LeO H-242
I don't know about the others but my understanding is that the
Skymaster was an attempt to design a twin engined plane that would
have the same overall dimensions as a single engine aircraft and be
safer to fly since it would eliminate asymetric thrust during engine
failure. *The ironic thing is that the Skymaster safety record is no
better than a conventional twin.- Hide quoted text -
- Show quoted text -
Possibly psychological "a single engined failure isn't dangerous so I
won't maintain the aircraft factor" and ofcourse perhaps engine
failure isn't the major cause of light plane crashes.
A single engined turbo prop is safer than a twin engine piston and
possibly even safer than a twin turbo since the pilots inabiility to
handle asymetrical thrust may be worse than his abillity to handle a
glide/crash landing.
Famously some singles have crashed and smashed through brick walls
and the pilot walked free unscathed, the engine acting as a battering
ram and protection.
That a single piston is safer than a twin is a classic of
probability theory, taugh in junior high around here (not back in
the day though).
Peter Skelton
Old September 3rd 10, 09:05 PM posted to rec.aviation.military,rec.aviation.military.naval
David E. Powell
proposition.
Adam A500
Dornier Wal
Dornier Do X
built.
LeO H-242
Famously some singles *have crashed and smashed through brick walls
ram and protection.
the day though).
Peter Skelton
Twice the number of things to go wrong?
Old September 3rd 10, 09:59 PM posted to rec.aviation.military,rec.aviation.military.naval
Peter Skelton
On Fri, 3 Sep 2010 12:05:31 -0700 (PDT), "David E. Powell"
proposition.
Adam A500
Dornier Wal
Dornier Do X
built.
LeO H-242
ram and protection.
the day though).
Peter Skelton
That and a non zero probability of crash as the result of a
single failure. The number was worked out sometime around the end
or WWII, aircraft with higher power reserves might show different
results.
Peter Skelton
Old September 3rd 10, 10:52 PM posted to rec.aviation.military,rec.aviation.military.naval
vaughn[_3_]
"Peter Skelton" wrote in message
failure. The ironic thing is that the Skymaster safety record is no
Yes. One of the classic crash modes of the Skymaster is when the pilot attempts
a takeoff after failing to notice that the rear prop is not turning. The
procedure developed to detect that simple condition is to lead with the rear
engine throttle. If you push in the throttle and the noise level remains
unchanges, it is time to abort the takeoff and investigate!
results.
Of course, the biggest danger is loss of an engine on takeoff, but even a
single-engine *landing* can come to grief in various ways. We had a twin
fatally crash into our neighborhood from exactly that event.
One situation where twins are considered inherently safer is night IFR. The
classic advice for a forced landing at night is to maintain control of the
airplane; in particular maintain a safe airspeed. At 300 feet, turn on the
landing lights. If you don't like what you see, turn them off!
Vaughn
Old September 4th 10, 07:04 AM posted to rec.aviation.military,rec.aviation.military.naval
Eunometic
proposition.
Overall I agree with what you say, however the conventional arrangment
also has some problems.
Also in the case of only having a limited horsepower the push-pull
arrangment does have a record of outperforming the side by side wing
arrangment it seems to me.
Yes, but no so bad with a tricycle undercarriage.
But the by mounting engines on the wing the spar exeperiences twist,
also a problem
Yes, but can be reduced with a snall engine.
the engines.
Definit stabillity issues but countered by the intrinsic contra
rotation and gyroscopic stabalistation of the props.
...and more.
Pushers can be slightly more efficient IF the structure ahead of the
pusher is kept small and streamlined.
Ken
I was thinking more along the lines of wing mounting of inline tandem
push-pull pairs in the fashion of this aircraft:
http://en.wikipedia.org/wiki/Dornier_Do_26
http://www.historicaircraft.org/Othe...nier-26-2.html
An arrangment that had been used succesfully for decades on Dornier
aircraft and these aircraft seemed to give nothing away in terms of
speed or range.
At one point it looked like being transfered to land based:
http://www.luft46.com/prototyp/me264.html
(Right at the bottom, youy see an illustraion of an Me P.1075 )
Old September 4th 10, 01:36 PM posted to rec.aviation.military,rec.aviation.military.naval
Bill Kambic[_2_]
On Fri, 03 Sep 2010 08:24:47 -0400, Peter Skelton
the day though).
Peter Skelton
As a general rule you put multiple engines on an aircraft 'cause you
want to haul a bigger load. The safety issue is more complex because
just how you add the additional engines can have significant
consequences if one (or more) fail.
There's also, however, a question of environment. Aircraft that
operate almost exclusively over land are going to have some different
considerations than those that operate almost exclusively over water.
There the that junior high principle might not be so clear. :-)
On my one flight in a Skymaster the "rear engine first" technique was
used. Of course if you watch the gauges you can also tell if the rear
engine is producing rated power.
One place that the push-pull system might just work out well is the
seaplane/amphibian. I note that Dornier says it's going to produce a
new one in Canada starting later this year (IIRC). It looks like an
interesting machine. We'll see how well it does in a very depressed
market.
Old September 4th 10, 06:54 PM posted to rec.aviation.military,rec.aviation.military.naval
Ken S. Tucker
Euno...
There are counterpoints to your counterpoints etc. especially true in
engineering, so I'll cut to the chase, more below...
proposition.
also a problem
the engines.
...and more.
Ken
push-pull pairs in the fashion of this aircraft:http://en.wikipedia.org/wiki/Dornier...pages/Dornier-...
speed or range.
At one point it looked like being transfered to land based:http://www.luft46.com/prototyp/me264.html
Nice pics, (me likes Do-26 too), I think the science of operating a
Pusher prop in the the prop wash of a Puller is difficult mainly at
slow speeds such as landing and take-off, that's beyond theory.
Additionally is the Pusher hub suction and cooling, given that one
can work those problems to near irrelevence then it looks like a
heck of good design to me.
Ken
Old September 4th 10, 08:25 PM posted to rec.aviation.military,rec.aviation.military.naval
Ken S. Tucker
the day though).
Peter Skelton
market.
Good, thanks for the notice...
http://en.wikipedia.org/wiki/Dornier_Seastar
The economy is always cyclic, canucks will need that type of thing
for commodity developement, of course the Twin Otter is a good deal,
we'll need to see the price.
Ken
Just pull the little red handle! JJ Sinclair Soaring 65 September 5th 10 12:57 PM
Propeller or jet to push an in-line skater? John Doe[_4_] Home Built 33 July 28th 10 10:28 PM
PUSH START stanley adelson Aviation Photos 0 July 15th 08 02:16 AM
Question about center-line push-pull engine configuration Shin Gou Home Built 4 June 7th 04 06:57 PM
Nasal cannula, flowmeter combinations. Lord Struthers Soaring 0 May 5th 04 06:04 PM
