wings came off
Old September 21st 10, 07:56 PM posted to rec.aviation.soaring
Ramy
Default wings came off
On Sep 21, 11:21*am, sisu1a wrote:
If they use weak links instead of spar pins, the aircraft could even
be reused!
Shear humor! *
Another video showing the deployment:
http://www.youtube.com/watch?v=-j5N9...ayer_embedded#
It took only 6 seconds from breakup to full canopy!! Try this with a
conventional backpack chute...
Another proof of the value of integrated ballistic chute.
Ramy
Old September 21st 10, 08:51 PM posted to rec.aviation.soaring
Larry Goddard
"Westbender" wrote in message
On Sep 20, 5:42*pm, Markus Graeber wrote:
It was the new Archaeopteryx high tech hang glider/microlift glider
(http://www.ruppert-composite.ch/english/index.html):
L/D 28:1, VNE 130 kph, + 5.3 g/- 2.65 g, and, as demonstrated, a
balistic recovery chute :-) *Very interesting concept that puts it
between a hang glider and a full fledged glider as we know it.
The pilot was doing acro, after some spinning he was coming out of his
second loop and must have pulled a little too hard on the stick during
recovery... Here a better view of the sequence of events:
http://www.youtube.com/watch?v=AgOR5PLTn84
Markus
On Sep 20, 5:11*pm, Berry wrote:
*"hinterland" wrote:
http://www.ledauphine.com/isere-sud/...are-un-planeur...
que-en-plein-vol
What sort of glider was that? Wings looked sort of like an Lo-100, but
the fuselage looked like a pod-and-boom affair. One of the wings
appeared to chop off the tailboom as the fuselage was tumbling.
Good thing it was equipped with a ballistic chute. I think it might have
been hard to get out of with it tumbling like that and not too high
either.- Hide quoted text -
- Show quoted text -
Looks to me like the first loop would have been pulling more G's than
the second. Higher speed, harder pull. Perhaps the damage was done on
the first one.
Before the loops, I noticed that he did a rather significant negative
pushover.... Wonder if that might have weakened something...
Larry
Old September 22nd 10, 06:52 AM
tienshanman tienshanman is offline
Member
First recorded activity by AviationBanter: Jan 2009
Quote:
Originally Posted by hinterland View Post
This embarrassing aerial crack up is not a very good advertisement for any glider, but especially not for an UL that sells for $85,000.....(basic glider + fairing for enclosed cockpit) http://www.ruppert-composite.ch/down...sliste2010.pdf
Old September 22nd 10, 08:33 AM posted to rec.aviation.soaring
John Smith
You can break *any* aircraft by pulling too many Gs.
Old September 22nd 10, 08:52 AM posted to rec.aviation.soaring
Bruce Hoult
It's got to be especially tricky when you've only got a 70 knot Vne to
work with.
We think we have to be careful when we're in a glider with only a 108
or 119 knot Vne!
Old September 22nd 10, 12:05 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
I think you might find that most of the modern gliders we fly are capable
of withstanding more "G" than the human body can take.
Overstressing a modern glider is unlikely to result in a catastrophic
failure unless there is already damage.
Remember the placarded limits have nothing to do with the design limits of
the glider. Most are placarded to +3.5 and -1 which was an arbitary figure
set by the LBA. Most gliders of the type we now fly exceed this level.
That is not to say that people should fly outside the placarded limits.
Old September 22nd 10, 12:24 PM posted to rec.aviation.soaring
Derek C
Markus
que-en-plein-vol
the first one.
Larry- Hide quoted text -
Just looked like a normal push over to gain speed for an aerobatic
manouevre to me. This is a foot launched glider, so must be much more
lightly built than a normal glider.
Derek C
Old September 22nd 10, 01:29 PM posted to rec.aviation.soaring
kirk.stant
Curious statement. Cite, please? Humans can take a lot of Gs,
especially when reclined - I've done over 9 g instantaneous in a Swift
and sustained 9 g for 20 some odd seconds in a centrifuge and wouldn't
want to try it in my LS6!
I'm pretty sure a hard pull at VNE in just about any glider (Swift or
Fox excepted, maybe) has a good chance of causing catastrophic
failure.
Kirk
Old September 22nd 10, 02:54 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
At 12:29 22 September 2010, kirk.stant wrote:
for
capable
limits
o=
f
figur=
e
limits.
failure.
Kirk
Prevalence of G-induced loss of consciousness (G-LOC)in the United
Kingdom Royal Air Force (RAF) was found to be 19.3% in 1987. With the
introduction of the Typhoon, a fourth generation aircraft, the prevalence
of G-LOC has been re-assessed to determine the effectiveness of current G
tolerance training. Method: A survey was sent to 4018 RAF aircrew,
irrespective of their current role. Information was requested on G-LOC,
role and aircraft type, experience, and attitudes toward G-LOC prevention.
Results: Responses were received from 2259 (56.2%) individuals, 882 (39%)
of whom were current fast jet aircrew. At least one episode of G-LOC was
reported by 20.1% of all respondents. In front line aircraft, prevalence
of G-LOC among the 882 fast jet aircrew who responded was 6%. In the whole
group, G-LOC was reported most commonly in aircrew under training (70.9%),
and was most prevalent in training aircraft (77.4% of G-LOC events). At
the time of the G-LOC, 64% of aircrew had less than 100 h total flying
time. G-LOC was reported most frequently between +5 to +5.9 Gz, and
“push-pull” maneuvers were associated with 31.3% of G-LOC events.
G-LOC was reported most frequently between +5 to +5.9 Gz.
Studies have shown that prone positioning has little effect, the only
remedy is a G suit and training, not often found in gliders.
The USAF require F16 pilots to demonstrate an ability to withstand a
maximum of 9 Gz and this can only be achieved through training and the
wearing of a G suit.
I am left wondering how sufficient acceleration could be maintained in a
LS6 to load the aircraft, in controlled flight, to sustain 9 G or indeed
more than 6G, ignoring that the pilot is going to become rapidly
unconsious if it were to be achieved. I am at a loss to understand why
anyone would want to do that anyway.
Old September 22nd 10, 03:20 PM posted to rec.aviation.soaring
150flivver
for
capable
limits
o=
f
figur=
e
limits.
Curious statement. *Cite, please? *Humans can take a lot of Gs,
failure.
Kirk
*Prevalence of G-induced loss of consciousness (G-LOC)in the United
tolerance training. *Method: *A survey was sent to 4018 RAF aircrew,
role and aircraft type, experience, and attitudes toward G-LOC prevention..
*Results: *Responses were received from 2259 (56.2%) individuals, 882 (39%)
“push-pull” maneuvers were associated with 31.3% of G-LOC events. *
G-LOC and structural deformity are two different issues. You can
snatch the stick and pull an instantaneous g-load that will snap the
wings off before your body reacts and you g-loc.
hey Bob, don't look. There are no wings :-) Glenn[_2_] Aviation Photos 2 May 19th 08 04:43 PM
PC-9 with all the wings :-) Glenn[_2_] Aviation Photos 1 August 19th 07 01:52 AM
X-Wings and Canard Rotor Wings. Charles Gray Rotorcraft 1 March 22nd 05 12:26 AM
wings mark Owning 18 February 7th 04 10:07 AM
What it took to get wings in WW II. ArtKramr Military Aviation 29 July 16th 03 07:42 AM
