How to check functionality of solar vent on Cobra trailer?
Old September 27th 10, 03:57 AM posted to rec.aviation.soaring
Andy[_10_]
Default How to check functionality of solar vent on Cobra trailer?
On Sep 26, 4:18*pm, Andy wrote:
On Sep 26, 8:42*am, John Cochrane
On Sep 26, 8:35*am, brianDG303 wrote:
On Sep 25, 10:13*pm, "Matt Herron Jr." wrote:
So these things are designed to run continuously? *They don't kick on
when the temp is above a set point?
Nope. They just run whenever there is power (sun or battery)
available, as long as the push-button switch (which some don't have)
is ON.
Now, with winter coming, is a great time to hear the assembled wisdom
(and random opinions!) of r.a.s. on the trailer vent issue. It's been
nagging me for years.
Most trailers are left outside. Go look at your glider at 6 am. It's
covered with condensation. Bad. The sun comes out, the condensation
dries, and the vent sucks it all out. Well, that's better than no
vent, in which case it would stay dripping all day and the gel coat
would peel off in your hands after a few months. I bought a little
recording hygrometer to test all this, and the result is frightening
-- 100% relative humidity for the early morning hours.
So, I got a battery powered vent that sucks all night too. But am I
doing any good? I'm just sucking in more humid air. I stack the thing
with drying crystals, but who knows if that is helping. Sure, they
soak up a lot of moisture, but since I'm also venting perhaps they are
just drying air that I then promptly pump outside.
The right answer is to hook it up to power and throw in a
dehumidifier. This works like a charm... but there is no power at my
trailer. A small heater works well too, and I use one over the winter.
But there is no power at my trailer. An even better answer of course
is to store it inside in a humidity controlled environment. Note: The
average hangar can be worse than outside. They leak, the solar vent no
longer works, and that huge concrete slab below you is a humidity
magnet in the springtime; it also keeps the glider from warming up and
drying out.
Sooo. Does anyone have hard data or anything other than obvious
opinions on what works best? *Vents were solution 1.0 to this problem..
Are battery powered vents better or worse? What's solution 2.0? Some
solar powered heating or dehumidifier system seems to be the way to
go, but it has to cost less than a hangar.
John Cochrane
You could buy about 100 of these:
http://tinyurl.com/254daal
If your trailer is well sealed maybe you won't have to dry them out on
a regular basis.
I think traditional dehumidifiers draw 3-5 amps - too much for solar
or battery.
9B
I take it back apparently these things can absorb up to 8-10 ounces of
water, which is about half the amount of water contained in the air
inside your trailer if it's saturated at 60 degrees F (at least
according to Wikipedia). So it kind of depends how quickly moisture
creeps in through the cracks. Might be worth buying a couple and
seeing if they have any effect - they're only $20 or so.
9B
COBRA TRAILER Gordon Schubert[_2_] Soaring 0 February 10th 09 04:15 AM
Cobra Trailer [email protected] Soaring 22 December 7th 06 11:38 PM
Solar vents delivered on Cobra trailers Dan Dunkel Soaring 7 April 4th 04 08:38 PM
Cobra Trailer Soaring 1 September 28th 03 01:14 PM
FS: Cobra Trailer Ed Byars Soaring 0 September 22nd 03 04:47 PM
