On Oct 10, 9:09*pm, Andy wrote:
On Oct 10, 4:39*pm, Paul Cordell wrote: The rule as discussed is to address proof of the mode the unit was operating in during the flight. *It must be in Competition mode so as to not provide an unfair advantage to the pilot. Yes Paul that's clear. *What is not clear is the consequence of not being able to prove that FLARM was operating during the flight. Do you believe that a competitor should be disqualified from a contest because his FLARM failed to produce a log? Do you believe that a contestant should be disqualified from a contest because his FLARM failed? No other US contest rule so harshly penalizes a contestant for an event outside his control. Andy I am strongly in favor of mandatory use of flarms in contests - ultimately (and soon). And I am a strong believer that a pool of rental units will speed the adoption. That said, the devil (as usual) is in the details of how to get there safely. I don't think we can say "the only valid log for a contest flight is a Flarm log" which is what the suggested rule effectively does. Even though Flarm is a proven technology, the PowerFlarm is a new box and needs a track record. I also don't want to see the workload of the scorer increased by having to process two logs per flight. While organizers can require impact activated ELTs, there is no requirement for contestants to prove they are working correctly and I don't see the clear necessity for this WRT Flarm. There are also a couple of (to me) worrisome safety details to work out related to the introduction of rental/loaner/borrowed units: 1. The position of the transmitting antenna is important, especially so in carbon ships. If you don't get this right, you effectively don't have the device on board making it useless to both you and others. There will need to be a knowledge base of what works and what doesn't developed (and adopted from European experience). 2. I am not comfortable with the idea of pilot having a new piece of equipment on the first contest day that they have never seen before and are trying to learn and that is making noises/visual cues at them. This problem goes away over time, but it is a serious concern to me in seeing the technology introduced without unintended negative safety consequences. Any you can't just say "turn down the volume and put it in the back out of sight because that creates the problem of (1). Keep the discussion going. John Godfrey (QT) US Rules Committee |
On Oct 10, 6:09*pm, Andy wrote:
On Oct 10, 4:39*pm, Paul Cordell wrote: The rule as discussed is to address proof of the mode the unit was operating in during the flight. *It must be in Competition mode so as to not provide an unfair advantage to the pilot. Yes Paul that's clear. *What is not clear is the consequence of not being able to prove that FLARM was operating during the flight. Do you believe that a competitor should be disqualified from a contest because his FLARM failed to produce a log? Do you believe that a contestant should be disqualified from a contest because his FLARM failed? No other US contest rule so harshly penalizes a contestant for an event outside his control. Andy Andy, I believe in not jumping to conclusions before all the facts and details are in. The rules as currently written do not address the needs of a new technology. They didn't when GPS was introduced and I'm sure that with a sensible discussion the rules with adapt. Maybe allowing the capabilities of the Flarm to be used by all is an easier solution. |
| Thread Tools | |
| Display Modes | |
| Substandard Italian workmanship renders first 787s unsafe | Mxsmanic | Piloting | 75 | July 4th 10 09:59 PM |
| "Aircraft Unsafe, Do Not Fly" | T8 | Soaring | 2 | April 13th 10 09:24 PM |
| Relief Tube Housing - Unsafe | Tim Taylor | Soaring | 12 | June 18th 09 10:30 PM |
| Flarm | Mal | Soaring | 4 | October 19th 05 09:44 AM |
| Delta plus ATL equals huge waste | DrunkKlingon | Instrument Flight Rules | 2 | April 18th 05 10:08 PM |
