#11
Jess Lurkin ha pensato forte :
Fabio wrote in news:4cb329f5$0$23145 : Content-Type: text/plain; charset="iso-8859-15"; format=flowed Content-Transfer-Encoding: 8bit prova Attachment decoded: Meteor p1 08.JPG ------=mesnews_0_1011101717-- Thanks Fabio Interesting design. from the pics you've posted and the others found elsewhere, your pic is the only Meteor with a rocket-assist pack. I saw a pic with a steam catapult, and what appeared to be some high tension spring system. As noted by another poster, some of them had props to big for the skid position. This pic with the RATO looks just about right for recovery without *too much* damage. The Usually from 1965 onward they used the booster assisted launch from a short catapult. There was no skid at all so no problem for the props. The aluminum variable pitch propellers in the last versions used to bend when entering the water at sea. A parachute and a self inflating device underneath the engine helped to facilitate recovery without damage. ciao Fabio |
Nel suo scritto precedente, Jess Lurkin ha sostenuto :
Fabio wrote in news:4cb329f5$0$23145 : Content-Type: text/plain; charset="iso-8859-15"; format=flowed Content-Transfer-Encoding: 8bit prova Attachment decoded: untitled-2.txt ------=mesnews_0_1011101717 Content-Type: image/jpeg; name="Meteor p1 08.JPG" Content-Transfer-Encoding: base64 Attachment decoded: Meteor p1 08.JPG ------=mesnews_0_1011101717-- Thanks Fabio Interesting design. from the pics you've posted and the others found elsewhere, your pic is the only Meteor with a rocket-assist pack. I saw a pic with a steam catapult, and what appeared to be some high tension spring system. As noted by another poster, some of them had props to big for the skid position. This pic with the RATO looks just about right for recovery without *too much* damage. This is one of the earliest models ciao Fabio |
Jess Lurkin scriveva il 12/10/2010 :
Fabio wrote in news:4cb329f5$0$23145 : Content-Type: text/plain; charset="iso-8859-15"; format=flowed Content-Transfer-Encoding: 8bit prova Attachment decoded: untitled-2.txt ------=mesnews_0_1011101717 Content-Type: image/jpeg; name="Meteor p1 08.JPG" Content-Transfer-Encoding: base64 Attachment decoded: Meteor p1 08.JPG ------=mesnews_0_1011101717-- Thanks Fabio Interesting design. from the pics you've posted and the others found elsewhere, your pic is the only Meteor with a rocket-assist pack. I saw a pic with a steam catapult, and what appeared to be some high tension spring system. As noted by another poster, some of them had props to big for the skid position. This pic with the RATO looks just about right for recovery without *too much* damage. here a pic of the model with the variable pitch prop ciao Fabio |
"Dave Kearton" wrote in
: "Fabio" wrote in message ... prova http://www.probertencyclopaedia.com/I_METEOR_P1.HTM It's a target drone, quite fascinating. I'm curious as it has a ventral skid, as if it could be used to land on - but the prop clearance, even when stopped, wouldn't prevent damage on landing. Looking at all the photoa, it my opinion that its part of the launching cradle,or rear support, not part or the aircraft.. |
Jess Lurkin NULL wrote in news:Xns9E0F986446DF5IPHIDEinuseALERT@
74.209.136.93: Fabio wrote in news:4cb329f5$0$23145 : Content-Type: text/plain; charset="iso-8859-15"; format=flowed Content-Transfer-Encoding: 8bit prova Attachment decoded: untitled-2.txt ------=mesnews_0_1011101717 Content-Type: image/jpeg; name="Meteor p1 08.JPG" Content-Transfer-Encoding: base64 Attachment decoded: Meteor p1 08.JPG ------=mesnews_0_1011101717-- Thanks Fabio Interesting design. from the pics you've posted and the others found elsewhere, your pic is the only Meteor with a rocket-assist pack. I saw a pic with a steam catapult, and what appeared to be some high tension spring system. As noted by another poster, some of them had props to big for the skid position. This pic with the RATO looks just about right for recovery without *too much* damage. I worked with drone contractors at 35mm, 40mm, Blowpipe, Javelin and ADATS firings. All had two-bladed airscrews. The modus operandi was to fly them until they ran out of fuel and when the prop stopped, it would be in a horizontal position, and they would belly-land on either grass or snow. Props were often damaged, typically when a launch went wrong, but easily replaced. -- Andrew Chaplin SIT MIHI GLADIUS SICUT SANCTO MARTINO (If you're going to e-mail me, you'll have to get "yourfinger." out.) |
prova | Fabio | Aviation Photos | 11 | October 13th 10 07:23 PM |
