Spar gluing
Old November 20th 03, 06:21 AM
- Barnyard BOb -
"Lou Parker" piped up:
Anyone know of any downfalls to using liquid nails to glue spars together?
And yes, I expect the usual ignorant smart asses, who really don't have an
answer.
Lou
I built a bird feeder with liquid nails. It lasted six months and then fell
apart.
Rich "ISA" S.
I used only Liquid Nails and a smile.....
to hold 2 x 4 foot sheet styrofoam panels of
insulation to my raw concrete basement walls.
None of it rests on the floor for support.
No idea how long it will stay glued.......
it's only been up 20 years to date without
a single panel coming loose.
Barnyard BOb -- well known smart, smart ass.
Old November 20th 03, 12:37 PM
Stealth Pilot
And yes, I expect the usual ignorant smart asses, who really don't have an answer.
Lou
maybe I'll be the only one to give you a serious answer.
aircraft wood glues have a number of requirements on them that the
usual off the shelf glues cant satisfy.
wings out in the sun get quite hot and they may be in the air under
load in this condition. this means that thermo softening glues, such
as liquid nails, pva etc cant be used because they WILL fail under
load when hot.
wood will expand and shrink slightly with different moisture
conditions, sometimes one side of the joint can be moist and one side
relatively dry. this may seem insignificant but in actual fact is one
situation which anything but the best of joints will be destroyed by
over time. the differential wood expansion sets up large sheer
stresses across the glue joint. if you have a weak glue you may just
end up with only half of it remaining and half of it showing cracking
from the stresses. for this reason varnishing to water proof the wood
is essential for any glue, as is making the glue joint with wood that
has the same moisture content.
aeroplanes (wonderful word that) last quite a while so it is essential
that the glue last longer than the life of the aircraft. Acid
catalysed phenolics (like Selleys 308 in australia ) use formic acid
applied to one side of the joint to set off the resin mix applied to
the other side of the joint (it sets off when they are put together)
this acid catalyst has been found to continue working as an acid after
the cure and has led to wood failures beside the glue joint. people
have died in structural breakups of aircraft because of it.
currently there are two basic wood glues that have stood the test of
time in aircraft structures. they are Resorcinol Formaldehyde which
was developed all the way back in the 1930's and wood compatible epoxy
resin. (not all epoxys are suitable)
It doesnt cost anything more to use a wood glue that will last the
distance so I would implore you to use a proper, tested by time, wood
glue.
Both of the glues I mentioned as suitable have little factors in their
use which need to be understood. I'll leave it to you to research
those.
Btw I asked Australia's CSIRO about modern glue research a few years
ago for my work with the SAAA. "yeah we're doing lots of it but under
contract so I cant show you the results of the tests. I will tell you
that Queensland Hoop Pine is exceptionally easy to glue (it's not much
different from spruce) and in all of our tests to destruction
Resorcinol Formaldehyde glues have outlasted the wood."
I should mention casein glue in passing. it works but is eaten by
bacteria if it ever gets moist an is unreliable over the life of the
vaerage aircraft.
Hope that helps.
simple as it is it is critical that you get glueing right.
Stealth Pilot
Old November 20th 03, 06:43 PM
Lou Parker
Stealth Pilot wrote in message . ..
Lou
load when hot.
glue.
those.
vaerage aircraft.
Hope that helps.
Stealth Pilot
Thank you. It looks like we have a couple of winners. Just for your
piece of mind, I have used nothing but T-88 on my project, but once in
a while a question like this comes my way.
Thanks
Lou
Old November 20th 03, 07:49 PM
Bob Kuykendall
Earlier, Stealth Pilot wrote:
Acid catalysed phenolics (like Selleys
308 in australia ) use formic acid ...
...this acid catalyst has been found
beside the glue joint. people have
The issue of acid-catalyzed urea-formaldehyde glues in Australia is
explored somewhat in the article I cited earlier in this thread. Not
being a wood enthusiast I don't really care one way or the other, but
I think that folks who do care should know that there is more than a
single side to this particular story.
Bob K.
http://www.hpaircraft.com/hp-24
Old November 20th 03, 10:51 PM
Gig Giacona
"Bob Kuykendall" wrote
...like 99-cent deer nuts being under
a buck....
You owe me a keyboard Bob.
Old November 20th 03, 11:57 PM
Fred the Red Shirt
- Barnyard BOb - wrote in message . .
That doesn't really surprise me. The solvent in
the liquid nails probably melted the styrofoam a
bit creating a good bond. Those panels are not
subjected to any significant stresses, certainly
no aerodynamic stresses nor do I imagine, does
your basement get as warm as an aircraft on a
hot day in teh sun. Probably not much exposure
to moisture or cold temperatures either.
Besides, those panels didn't weigh dick in the
first place.
For spars *I* would only use epoxy or a urethane glue
like Gorilla glue. Resourcinol glue, used in boat
building might be good too.
I suggest that you only rely on something that
a siginifacnt number of other folks have used
and survived. Learn from other people's mistakes.
FF
Old November 21st 03, 12:13 AM
Fred the Red Shirt
Got any info on urethane glues like Gorilla glue?
They're supposed to be good for outdoor wood projects.
Also a note on varnishing:
All film finishes for wood, paint, varnish, laquer, shellac (I think
that is all) will allow water vapor diffusion so that changes in
humidity will still cause the wood to expand and contract. What
these finishes do for the structure is to SLOW the rate of
diffusion so that any moisture gradient within the wood is
minimized. This in turn minimizes warping, but not the
overall dimensional change.
The expansion and contraction of wood with moisture content is
anisotropic. Wood expands and contracts the most along the
grain boundaries. This will be accross the fact of most boards
that you get by sawing the log through and through, that is
in the direction that was tangent to the circumfrence of the
tree. Wood expands and contracts less accross the grain, that
is in the direction that was radial in the tree trunk. It
hardly expands and contracts at all in length.
I have read that Doug Fir is uniquely stable among woods in
that it expands and contracts equally in both the radial and
circumferential directions and so it is the only wood commonly
sold as dimensional lumber while still green (others will usually
be kiln dried to 12 % MC) However, I have seen Doug Fir boards
cup and uncup with variations in humidity, indicating to me
that this is not true.
FF
Old November 21st 03, 02:23 AM
Bob Kuykendall
I'm sure glad somebody got that one.
Here's the full riddle:
What's the difference between beer nuts and deer nuts?
Beer nuts are $1.39, but deer nuts are under a buck.
Thanks, and best regards to all
Bob K.
Old November 21st 03, 05:23 AM
- Barnyard BOb -
You've got my vote, Fred.
However, there is a core of wannabees hell bent on
re-inventing the wheel in some ridiculous manner, at
least with their keyboards most every day - all under the
guise of *EXPERIMENTING*. Anyone that poo-poos
their nutty notions without great care are labeled as
anti-experimenters or worse and are subject to very
hostile and denigrating attacks. You know the drill...
KILL THE MESSENGER
Barnyard BOb - over 50 years of successful flight
Marske spar workshop Marske Flying Wings Home Built 0 October 14th 03 04:53 PM
FS: Wing spar angle extrusions Bob Kuykendall Home Built 0 September 25th 03 08:23 PM
Carbon Spar design and construction workshop Marske Flying Wings Home Built 0 September 18th 03 05:47 PM
Wood questions - Public Lumber Company, determining species at the lumberyard Corrie Home Built 17 September 17th 03 06:51 PM
