AVIATIONTOOLBOX: How do you like your maps stitched?
Old November 30th 03, 11:09 PM
Kyler Laird
"Tom Jackson" writes:
What do you mean exactly by "After geo-referencing the map files"?
Well, maybe my terminology is inaccurate, but what I meant to say was, I
load, and calibrate the map image.
Nope, your terminology is dead on.
Basically, I load the map projection
information into the program (i.e., Lambert Conformal Conic, with the
appropriate lat/lon info.) I got this information from one of the HTML files
related to the specific map TIFF.
Stop doing that! The sectionals are already GeoTIFFs. The FAA has already
done all of that work for us. (They guarantee 2 pixels RMS error, but I've
found distortions much greater than that.)
I'm also working on making more easily-digested chunks of data. If you're
in the mood to burn some time and bandwidth, you can watch my progress.
http://aviationtoolbox.org/munge/mosaic.cgi
Just change the extension to ".tif" on any of the images if you want a 5000
by 5000 uncompressed GeoTIFF.
(I need to tweak my edge-detection algorithm. When I do, I'll clear those
images and start over but you're welcome to try it anyway.)
--kyler
Old December 1st 03, 04:13 AM
Tom Jackson
Maybe I'm missing something -- I'll quickly walk you through what I do in
Oziexlporer:
After launching Oziexplorer, I go to the "file" menu, and select "load and
calibrate map image"
This loads the image, but requires that I supply additional data in order to
calibrate the image.
There is an additional menu option to "import map", however, GeoTIFF isn't
an option.
The help screens indicate the following:
*******************help text*****************************
Geotiff
OziExplorer can extract the georeference information from Geotiff files but
it only knows how to decode the information if it is from a known source. At
this stage only the georeference information in the USA USGS DRG Geotiffs
can be decoded.
The ability to decode other sources of georeference information in Geotiff
files will be added on an as need basis where it is possible to do so.
Converting Geotiff Image Files
Some Geotiff Image files are in the 24 bit color format. OziExplorer can
read 24 bit color TIFF files but must load them fully into RAM instead of
paging them from disk as it does with 8 bit color TIFF mages. For large
images this requires a lot of RAM.
If you convert these files to 8 bit color the Geotiff georeference
information is lost.
This document describes a technique to save the georeference information and
to then put it back into the file.
You need
Software to convert the Geotiff image from 24 bit to 8 bit color. Paint Shop
Pro (www.jasc.com) works well.
The Tiff Utilities available from the Utilities section of the OziExplorer
web site (www.oziexplorer.com).
**************end of help text********************
Perhaps the developer of Oziexplorer needs to add these types of files to
its list of "known" types. I will e-mail them.
"Kyler Laird" wrote in message
files
already
I've
5000
--kyler
Old December 1st 03, 02:09 PM
Kyler Laird
Oziexlporer:
It doesn't sound like you're using a TIFF.
an option.
Is "TIFF" an option? A GeoTIFF is just a regular TIFF with some standard
tagged data.
can be decoded.
Oh...hmmm...that's a strange limitation.
O.k., so OziExplorer is kinda dumb right now. Looks like you get to do it
manually for awhile.
The sectional maps from the FAA are 8-bit color (palette). I convert them
to 24-bit (RGB) when I mask them. The chunks I build are 24-bit.
This is just another limitation of OziExplorer. Changing the pixel
representation has little to do with the ability to hold GeoTIFF data.
I'm planning on making 8-bit versions available but it's easier to
manipulate (warp/scale/blend/...) the data without mangling it in 24-bit
mode. My preference is to wait until the last step to create the 8-bit
images.
Oh, well sure. *That* will destroy the GeoTIFF data.
Good luck. I'm sorry I made comments assuming that OziExplorer would
deal with GeoTIFFs sensibly.
--kyler
Old December 5th 03, 02:13 AM
Tom Jackson
Please see below from the developer of Oziexplorer - they fixed the software
after I pointed them to your data. It now works amazingly well!
Hi Tom,
I released a new version of OziExplorer today which should import your FAA
sectional maps without intervention. Use the Import "All DRG maps on a CD or
in a Folder" option.
Regards
Oziexlporer:
and
to
isn't
an option.
tagged data.
but
At
can be decoded.
Geotiff
images.
Shop
--kyler
Old December 5th 03, 04:09 AM
Kyler Laird
Impressive! I'm still puzzled about why they couldn't handle the GeoTIFFs
without special intervention, but I like that they fixed it quickly.
BTW, I've finally completed a "chunking" run of all of the sectionals using
the "blend" algorithm. I still don't like the way it looks, but I hope
others will make suggestions.
(Damn! They sure do try to make P-49 obvious, don't they?)
If you select a chunk, you'll get the full-size (5000x5000) version of it as
a JPEG (in another window - always the same one). Change the extension to
".tif" for the GeoTIFF. (Yes, this is just for testing.)
The TIFFs compress about 40%. I should be able to do even better if I
convert them back to 8-bit (palette) images. More later...
It's fun browsing the sectionals. I'd never had one with the note
"APPROXIMATE LIMIT OF PACK ICE THROUGH MARCH".
http://aviationtoolbox.org/munge/chunked/chunk_8_5.jpg
--kyler
Old December 5th 03, 07:39 AM
Ben Jackson
Wow, I've always wanted one of those. I want to take all the flights I've
ever made and plot them on top.
Shame the colors don't match. Maybe you could use the elevation key that's
on every chart to match between TIFs?
Ben Jackson
http://www.ben.com/
Old December 5th 03, 12:58 PM
Wow... I was thinking of trying to do this a few weeks ago when you made the
sectionals available. The fact that it's all in GeoTIFF seemed pretty cool, but I didn't
quite get around to trying to code something up. How much of a pain will it be to redo
it when new sectionals come up? Will you have to re-edit out the non-map area?
Thanks again,
-Cory
Kyler Laird wrote:
: "Tom Jackson" writes:
:Please see below from the developer of Oziexplorer - they fixed the software
:after I pointed them to your data. It now works amazingly well!
: Impressive! I'm still puzzled about why they couldn't handle the GeoTIFFs
: without special intervention, but I like that they fixed it quickly.
: BTW, I've finally completed a "chunking" run of all of the sectionals using
: the "blend" algorithm. I still don't like the way it looks, but I hope
: others will make suggestions.
: http://aviationtoolbox.org/munge/mosaic
: (Damn! They sure do try to make P-49 obvious, don't they?)
: If you select a chunk, you'll get the full-size (5000x5000) version of it as
: a JPEG (in another window - always the same one). Change the extension to
: ".tif" for the GeoTIFF. (Yes, this is just for testing.)
: The TIFFs compress about 40%. I should be able to do even better if I
: convert them back to 8-bit (palette) images. More later...
: It's fun browsing the sectionals. I'd never had one with the note
: "APPROXIMATE LIMIT OF PACK ICE THROUGH MARCH".
: http://aviationtoolbox.org/munge/chunked/chunk_8_5.jpg
: --kyler
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
Old December 8th 03, 09:37 PM
I saw the other thread... that's how I caught up with it again. I was mainly wondering about the
non-map part... if it changes you'll have to change your map-null list.
Good work! Not sure how to do the "fading" any better than what you've got. Of course, the *real* way to
do this would be to try to get ahold of the vector-based info from the FAA directly. That'd be sweet.
-Cory
Kyler Laird wrote:
: writes:
: Wow... I was thinking of trying to do this a few weeks ago when you made the
:sectionals available. The fact that it's all in GeoTIFF seemed pretty cool, but I didn't
:quite get around to trying to code something up.
: Have at it. Maybe you'll come up with more creative solutions than mine.
: I could really use some different perspectives.
:How much of a pain will it be to redo
:it when new sectionals come up? Will you have to re-edit out the non-map area?
: It's automatic. Once I get the FAA images uploaded, I hit "go" and wait
: a couple days.
: I posted the process in another thread. (Look for the "AVIATIONTOOLBOX"
: keyword. I'd give you the URL but I'm offline in a hospital right now.)
: --kyler
AVIATIONTOOLBOX: moving map script (was PocketEfis & PalmEfis) Darrel Toepfer Home Built 0 August 11th 04 01:34 PM
Nike SAM sites in CONUS: Any Maps? Matt Wiser Military Aviation 1 May 17th 04 03:49 AM
AVIATIONTOOLBOX: I've added your approach plates. Kyler Laird Instrument Flight Rules 20 April 19th 04 12:02 AM
source for edges of FAA sectional maps? Kyler Laird General Aviation 2 November 29th 03 03:09 PM
