Roy Smith writes:
The GC route is indeed the shortest distance between two points. Try plugging 38N/77W to 38N/122W into http://www.aeroplanner.com/calculators/avcalcrhumb.cfm to get the rhumbline of 2128 nm, and into http://www.csgnetwork.com/marinegrcircalc.html to get the GC of 2099 nm. And http://gc.kls2.com/ as it makes nice visuals. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
![]() "Roy Smith" wrote in message ... In article , (Paul Tomblin) wrote: snip You've got to go pretty big distances before GC errors start to become significant. For example, to go from 38N/77W to 38N/122W (roughly Washington, DC to San Francisco, CA), the rhumbline is 270 and the GC is 284. 14 degrees on a coast to coast trip. If you're flying it nonstop in a jet, it makes sense to take that into account. For most of us flying spam cans, we just can't fly long enough legs for it to become significant. And it is all moot anyhow, since you'd be IFR and not using VFR charts... |
![]() "Kyler Laird" wrote in message news:h2sei1- So...anyone know the answer? Pilots are certainly accustomed to drawing straight lines on a sectional to find the shortest path As a technical matter, the only chart projection on which a drawn straight line is a great circle is a gnomonic. These are rarely used, particularly over large areas, as they show about as much distortion as the standard Mercator we all grew up with (remember thinking that Greenland was about twice the size of the US?). The Lambert Conformal projection, however, is made such that a straight line, while not precisely a great circle, is so close that the differences are inconsequential. Oceanic plotting charts used in aviation to monitor navigation progress are Lamberts. The standard oceanic enroute chart is a Mercator, but the plotting chart is Lambert. Sectional charts are also Lamberts,iirc. So, the short answer to your question is, just lay out the line, and go. Note, though, that the straight line on your patched sectionals will require you to alter heading periodically. JG |
![]() "John Gaquin" wrote in message ... "Kyler Laird" wrote in message news:h2sei1- So...anyone know the answer? Pilots are certainly accustomed to drawing straight lines on a sectional to find the shortest path As a technical matter, the only chart projection on which a drawn straight line is a great circle is a gnomonic. These are rarely used, particularly over large areas, as they show about as much distortion as the standard Mercator we all grew up with (remember thinking that Greenland was about twice the size of the US?). The Lambert Conformal projection, however, is made such that a straight line, while not precisely a great circle, is so close that the differences are inconsequential. Oceanic plotting charts used in aviation to monitor navigation progress are Lamberts. The standard oceanic enroute chart is a Mercator, but the plotting chart is Lambert. Sectional charts are also Lamberts,iirc. So, the short answer to your question is, just lay out the line, and go. Note, though, that the straight line on your patched sectionals will require you to alter heading periodically. JG "the straight line on your patched sectionals will require you to alter heading periodically" precisely because you will be flying close to a great circle route, which requires a constantly changing heading. Harvey |
![]() "John Gaquin" wrote in message ... As a technical matter, the only chart projection on which a drawn straight line is a great circle is a gnomonic. A straight north-south line is a great circle on all the common chart projections. |
![]() "Steven P. McNicoll" wrote in message A straight north-south line is a great circle on all the common chart projections. Correct. Those are the two [possibly rare] exceptions to my post -- if you happen to be flying a course of true north or south anywhere, or a course of true east or west on the equator, then your course will layout as a straight line and will be a great circle on any chart projection. I probably should have mentioned it, lest someone get lost and run out of fuel. |
Kyler Laird wrote in message ...
Awhile ago I pointed out in rec.aviation.piloting that one of my tools will generate a map using stitched sectionals for a given route. http://groups.google.com/groups?hl=e....edu.au#link10 Ben Jackson mentioned that it didn't look correct to just draw a straight line between two points so far away (across multiple sectionals). I have looked into it a few times but I haven't come up with a definitive answer. So...anyone know the answer? Pilots are certainly accustomed to drawing straight lines on a sectional to find the shortest path between two points, and I've never been taught to do anything other than align sectionals by sight to plan multi-sectional flights. Does this not work over long distances? One path I know fairly well is LAF-MER. The Great Circle path happens to go right near Denver (where I usually stop). If that path is plotted as a straight line on the sectionals https://aviationtoolbox.org/Members/...selected.x=411 it appears to follow the path I'd expect. https://aviationtoolbox.org/Members/...selected.x=427 Also, there's an easily-identified area on that path where Iowa, Illinois, and Missouri meet. Take a look at the Great Circle route. http://gc.kls2.com/cgi-bin/gcmap?PAT....380N+120.568W Again, this seems to match the area on the straight-line path drawn on the sectional. https://aviationtoolbox.org/members/...selected.y=324 Anyone know for sure whether or not this is an accurate way of depicting Great Circle paths in the conUS? Thank you. --kyler As a rule of thumb: Use this equation to draw the bow. It gives the distance offset from a straight line for the circle route. A: Lat A: Longitude B: Lat B: Longitude A and B are the two locations. C: km of rhumb line. Nathanial Bowdich has an equation there for this method and is forgotten, but available from his Navigation Book. Except his method is to find the equation that fits the geometer's rhumb line, meaning Bowdich only has a method of navigation and not the true rhumbline solution. Making my equation a constant for the earth sphere type, where only the geometry of all spheres allows the applied line!! That is geometer talk btw. C*1.3 seconds= Alat C*1.3 seconds= Blat Two simulatanous equations to solve for C, the rhumbline. Longitude is the reason for the 1.3 seconds of time arc, as a constant. Meaning just take the time of the trip and lengthen until the A and the B are equal latitudes! That is it. Douglas Eagleson Gaithersburg, MD USA |
Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 12:18 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
AVIATIONTOOLBOX: how I convert sectional maps to map chunks | Kyler Laird | General Aviation | 2 | December 4th 03 01:09 AM |
