![]() Bob Reed wrote: Damn BOb, you sure are full of CRAP! ;-))))) I'm sure NO ONE here, not even the crotchety old fool himself, will deny that BOb is full of crap (sometimes), *BUT* it was nafod40 whom you (Bob Reed) quoted and not BOb. Russell Kent +++++++++++++++++++++++++++++++++++++++ When I go blind from one too many Muzzleloaders.... You can officially be my replacement eyes on RAH... and in the RV-3, if you don't mind sitting on my lap. Thank you, Russell. Good job. g Barnyard BOb -- |
![]() In article , nafod40 writes: Does a prop turning at 2300 rpm on a 150hp motor produce more thrust than a prop spinning 2300 rpm on a 100 hp motor ? To paraphrase the question... If I put 150 lbs of crap in a 100 lb bag, and 150 lbs of crap in a 150 lb bag, which bag is holding more crap? Damn BOb, you sure are full of CRAP! ;-))))) Bob Reed ++++++++++++++++++++++++++++++++++++++++++ Whoa, Bob. You have corn-fused me with somebody that gives a CRAP. Neither my dog or I would care to be involved in this blivet* fiasco. * blivet /bliv'*t/ n. [allegedly from a World War II military term meaning "ten pounds of manure in a five-pound bag"] Barnyard BOb - - The more people I meet, the more I love my dog and George Carlin humor. |
In article , nafod40 says...
To paraphrase the question... If I put 150 lbs of crap in a 100 lb bag, and 150 lbs of crap in a 150 lb bag, which bag is holding more crap? Depends... Chuck S |
On 8 Dec 2003 20:06:47 -0800, ChuckSlusarczyk
wrote: In article , nafod40 says... To paraphrase the question... If I put 150 lbs of crap in a 100 lb bag, and 150 lbs of crap in a 150 lb bag, which bag is holding more crap? Depends... How much crap does your Depends hold? :-) Ron Wanttaja |
Ron Wanttaja wrote:
ChuckSlusarczyk wrote: In article , nafod40 says... To paraphrase the question... If I put 150 lbs of crap in a 100 lb bag, and 150 lbs of crap in a 150 lb bag, which bag is holding more crap? Depends... How much crap does your Depends hold? :-) Ba-dummm-bump -cymbal- |
In article , Ron Wanttaja says...
If I put 150 lbs of crap in a 100 lb bag, and 150 lbs of crap in a 150 lb bag, which bag is holding more crap? Depends... How much crap does your Depends hold? :-) Depends :-) Chuck(where's the prunes ?) S |
![]() "Mark" wrote in message ... Does a prop turning at 2300 rpm on a 150hp motor produce more thrust than a prop spinning 2300 rpm on a 100 hp motor ? I'm no authority on the subject, mind you, but it seems you get more thrust from the more powerful engine because it will turn a prop with more pitch, thus moves more air, thus more bite. Thus more thrust. |
Mark wrote:
Does a prop turning at 2300 rpm on a 150hp motor produce more thrust than a prop spinning 2300 rpm on a 100 hp motor ? Assuming the same prop on both engines, then no. A spinning prop produces thrust by throwing air backwards. Based upon pitch, diameter and airfoil design, a given prop can throw a given amount of air at a given RPM. It takes a specific amount of power for the prop to do that. If the 150hp motor is at full throttle, then the 100hp motor won't be able to turn the prop at 2300. If the 100hp can turn at 2300, then a 150hp engine will be under-propped with that propeller and will easily redline (either that or the 150hp engine isn't producing 100hp). -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
On 04 Dec 2003 04:24 PM, Mark posted the following:
Does a prop turning at 2300 rpm on a 150hp motor produce more thrust than a prop spinning 2300 rpm on a 100 hp motor ? Yes, unless the 150hp motor is an automotive engine, in which case bolting a prop to it will cause it to violently self destruct before reaching 2300rpm. 8^P ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
![]() On 04 Dec 2003 04:24 PM, Mark posted the following: Does a prop turning at 2300 rpm on a 150hp motor produce more thrust than a prop spinning 2300 rpm on a 100 hp motor ? Yes, unless the 150hp motor is an automotive engine, in which case bolting a prop to it will cause it to violently self destruct before reaching 2300rpm. 8^P Del Rawlins- ++++++++++++++++++ Smoooooch ! Barnyard BOb -- The more people I meet, the more I luv my dawg,,,, and George Carlin humor. |
Stupid super cub question | Robert Loer | Home Built | 9 | November 22nd 03 05:28 PM |
Tecumseh Engine Mounting Question | jlauer | Home Built | 7 | November 16th 03 01:51 AM |
question about EZRocket | David O | Home Built | 6 | October 1st 03 06:03 PM |
Question on Pulsejets/Ramjets??? | DarylG1532 | Home Built | 3 | August 16th 03 03:20 AM |
Question - Regarding Canard Pushers... | Tilt | Home Built | 33 | August 10th 03 11:07 AM |
