Ethanol fuel and deteriorating composite fuel tanks
Old November 19th 10, 07:11 AM posted to rec.aviation.soaring
Alan[_6_]
Default Ethanol fuel and deteriorating composite fuel tanks
In article Jim writes:
You spend enough to buy a house on your motorglider and are trying to
save a few bucks on fuel?
Avoiding 100LL is often not about trying to save money.
If you spent that much money on the motorglider, you probably want to feed
it the best fuel for it, which may not be 100LL.
I don't know about the engines used in motorgliders, but the Rotax engines
used in many of the light sport aircraft "prefer" mogas over 100LL, as the
lead content results in shorter service intervals for things like oil changes,
gearbox servicing, and possible engine overhaul.
Alan
Old November 19th 10, 01:29 PM posted to rec.aviation.soaring
Nigel Cottrell[_2_]
Rotax specifically say that 100ll should only be used if 95 ron
unleaded is unavailable due to increased wear and unsuitability
to their 2 stroke engines. We have never used 100ll in our 505
due to this advice from Rotax.
The sooner an unleaded aviation petrol spec is agreed and the
fuel widely available the better.
This would also be of great help to the large number of light
aircraft powered by engines originally designed to use 80/87.
are trying to
probably want to
feed
Rotax
engines
100LL, as the
oil
changes,
Alan
Old November 19th 10, 03:04 PM posted to rec.aviation.soaring
Darryl Ramm
In article *Jim *writes:
are trying to
*Avoiding 100LL is often not about trying to save money.
*If you spent that much money on the motorglider, you
probably want to
feed
*I don't know about the engines used in motorgliders, but the
Rotax
engines
100LL, as the
oil
changes,
* *Alan
Ah the devil is in the details and the question about concerns with
Ethanol blend fuels that are an issue in the USA may not be in the UK.
The real question is what do Rotax or the aircraft manufacture say
about Mogas with Ethanol blends? And what experience do people
actually have operating at high Ethanol blends E10, E15 etc. Its not
just an automatic extrapolation that because non-blended or low-blend
(5%) Mogas is "better" (for some definition of what better means)
than 100LL that all ethanol blends of Mogas will be. In many cases I
suspect that the motorglider manufacturers do not have enough
experience with Ethanol blended fuels to know what the answer should
be.
Let alone the question of what Ethanol blends might do to fuel tanks
and hoses etc. there is the question of whether the Engine and carb
etc. are suitable for higher blend ethanol fuels. To take the example
offered of Rotax/light sport example further Rotax themselves have
qualified some (but not all of their) engines to use up to E10 blends
but no more. Other engines are limited to E5. (see
http://www.rotax-aircraft-engines.co...us/d04851.pdf).
So if you live in the USA in a state where fuel is pushing E15 you
might really want to consider AVGAS.
For example see how Remos handle this issue here
http://www.remos.com/media/news/noti...l-blended-fuel
.... Use Mogas over 100LL but Mogas is not recommended if it contains
Ethanol. Not exactly clear from this at what blend ratio it might be
better to use 100LL.
The rotary engines in Schleicher motogliders run better on Avgas 100LL
than Mogas so its a non-issue. The Solo engines in DG motorgliders and
others have traditionally had Mogas recommended, but again that advice
may not necessarily apply if the Mogas is a high Ethanol blend. Check
with DG or Binder for their advice - and be clear you are asking
specifically about Ethanol blends not conventional Mogas.
Having drained enough water out of AVGAS tanks in light aircraft to
scare me I would be concerned about dissolved water contamination in
high Ethanol blends.
Darryl
Old November 19th 10, 09:44 PM posted to rec.aviation.soaring
are trying to
probably want to
feed
Rotax
engines
100LL, as the
oil
changes,
* *Alan
be.
but no more. Other engines are limited to E5. (seehttp://www.rotax-aircraft-engines.com/portaldata/5/dokus/d04851.pdf).
For example see how Remos handle this issue herehttp://www.remos.com/media/news/notification-use-ethanol-blended-fuel
Darryl- Hide quoted text -
- Show quoted text -
Alan and Nigel are right, several rotax powered motogliders DO prefer
Mogas. Metal tanks in the HK-36.
Lead in 100LL can cause plug and gearbox problems. I know because I
do the support for two HK -36 research birds
aerodyne
Old November 20th 10, 12:35 AM posted to rec.aviation.soaring
Darryl Ramm
are trying to
probably want to
feed
Rotax
engines
100LL, as the
oil
changes,
* *Alan
be.
Lead in 100LL can cause plug and *gearbox problems. *I know because I
aerodyne
BTW I was not disputing that, but the choice is not automatic what you
should do when higher Ethanol blends are involved, e.g. if the choice
is say between E15 mogas and 100LL avgas? Is it? Rotax says not to use
E10 in the 912/914 series engines AFAIK. So what do you do, I expect
you are required to run Avgas if the only other choice was E15? At
least E15 should be labeled at the pump, good luck knowing what
exactly you get in many states in the USA now.
But to the point that is is not just "automatically best" to use Avgas
100LL, that is absolutely correct. Owners better read the manual.
Darryl
It's time to mount the fuel tanks Lou Home Built 1 March 31st 07 07:07 PM
Leaking Fiberglass Fuel Tanks [email protected] Home Built 0 January 2nd 07 01:10 AM
Ethanol & capacitance fuel-level sensors Adam Aulick Home Built 4 May 20th 06 03:28 PM
Fuel Tanks C172 [email protected] Owning 1 May 2nd 06 05:45 AM
Epoxy for Fuel Tanks Doug Palmer Home Built 1 April 12th 06 02:53 AM
