#11
Meanwhile, anyone have any ideas on how to apply Vaseline to a valve seat located some distance up an 8 mm tube? Know any pilots who are gynecologists? How about a syringe thing that is used to give babies an oral dose of liquid medication? Hot glue a small stir stick or small tube of some type, and it should be able to get up there to the source. I also might make a suggestion to use air tool O-ring grease. It is a long chain grease that acts almost like it has long fibers in it. It should stay around much longer than Vaseline. -- Jim in NC |
Paul,
I'm not too comfortable with using CLR. It says not to use on plastic laminates or Formica, and my tail tank is plastic. What I'm more worried about is the valve. I suspect it's got rubber in it, and there's nothing on the label that says CLR is safe for rubber. But thanks for your idea. I'm not convinced that the drip is due to crud build up. This drip suddenly appeared, after a summer and fall with no problems. That's why I have a suspicion that it may be due to an overly tight cable, which contracted slightly more in the cold to cause the drip. I'll check the cable tension this weekend to rule the cable in or out. -John On Nov 25, 3:15 pm, sisu1a wrote: Is there anything that would be destroyed by putting a CLR solution in the tank and letting it soak? By your and others descriptions my guess is that there are water deposit/oxidation buildups preventing the valve from being able to completely seat, which could be dissolved with a CLR treatment. Among other materialsn it's list of materials it's rated safe to use on is fiberglass, and there are even directions for using it in coffee makers so it's not terribly caustic although it is very effective at dissolving the stuff it was designed for -Calcium/ Lime/Rust. -Paul |
Jim,
I'm not familiar with the syringe you speak of. It would have to be small in both diameter and length to work, as the tube is only 0.375 inches inside diameter and is probably 12 inches long (and turns 90 degrees, too). I was thinking more along the lines of a cut down Q-tip bonded to the end of a wire. I'm also not familiar with air tool O-ring grease. I'll talk to a mechanic friend about getting some. Thanks for the idea. -John On Nov 25, 4:49 pm, "Morgans" wrote: How about a syringe thing that is used to give babies an oral dose of liquid medication? Hot glue a small stir stick or small tube of some type, and it should be able to get up there to the source. I also might make a suggestion to use air tool O-ring grease. It is a long chain grease that acts almost like it has long fibers in it. It should stay around much longer than Vaseline. -- Jim in NC |
"jcarlyle" wrote Jim, I'm not familiar with the syringe you speak of. It would have to be small in both diameter and length to work, as the tube is only 0.375 inches inside diameter and is probably 12 inches long (and turns 90 degrees, too). I was thinking more along the lines of a cut down Q-tip bonded to the end of a wire. I'm also not familiar with air tool O-ring grease. I'll talk to a mechanic friend about getting some. Thanks for the idea. Go to the drug store, and ask for devices for giving a baby liquid medicine. There probably are a few different things there hanging together for doing that. The syringe diameter is not important. The only thing being stuck into the tube would be a small diameter tube stuck onto the syringe. Find something for that, that is flexible enough to go up your tube. Fish tank air hose, small engine gas line, medical IV tubing, medical tubing for oxygen, all come to mind as possibilities. -- Jim in NC |
I understand now. Thanks!
-John On Nov 26, 8:51 am, "Morgans" wrote: Go to the drug store, and ask for devices for giving a baby liquid medicine. There probably are a few different things there hanging together for doing that. The syringe diameter is not important. The only thing being stuck into the tube would be a small diameter tube stuck onto the syringe. Find something for that, that is flexible enough to go up your tube. Fish tank air hose, small engine gas line, medical IV tubing, medical tubing for oxygen, all come to mind as possibilities. -- Jim in NC |
"jcarlyle" wrote I understand now. Thanks! Welcome, and come back and tell us how it worked. -- Jim in NC |
| Thread Tools | |
| Display Modes | |
| Pawnee fuel tank vent drip | Mike McCarron[_2_] | Soaring | 1 | November 3rd 08 02:56 AM |
| LS6-b tail tank leak fix | kirk.stant | Soaring | 2 | August 19th 08 02:39 AM |
| Saturn V S-IC-T (static test stage) fuel tank assembly is mated to the liquid oxygen (LOX) tank 6416666.jpg | [email protected] | Aviation Photos | 0 | April 12th 07 02:33 AM |
| Ventus B tail tank add on | Cliff Hilty | Soaring | 1 | October 7th 04 04:53 PM |
| ASW20 tail tank mod | goneill | Soaring | 4 | February 21st 04 07:16 PM |
