First Emergency (Long Post)
Old July 20th 03, 08:11 AM
A Lieberman
Default First Emergency (Long Post)
Thought I would share my first emergency....
I was flying from MBO (Madison MS) to L31 (Covington LA) to meet my
sister for dinner, and get some night time hours on the return trip. I
have done this trip many times.
Left Madison at 5:00 p.m. with an expected arrival at 6:15. I am
starting my IFR training, so figured to really focus on holding altitude
and heading working on "precision flying". I was doing great all along
the trip, and looking ahead, saw major buildups in my path. Called
122.00 and asked for an inflight advisory. Weather was moving SSW and
though close, they said I should make my destination. Little did I know
the weather would be the least of my concerns.
15 miles from my destination cruising at 3500, I got a horrible
vibration throughout the engine. First thing I did was put the carb
heat on. Made the vibration even worse. I held the carb heat for about
10 seconds, and turned it off. Immediately saw a "target farm field"
should I need it and never let it leave my sight. Next, switched tanks,
no change in vibration. Next fuel pump, no change. Next, checked my
mags, left, then right, no change in vibration.
Next, turned to 121.5 and said, This is Sundowner 12345L declaring an
emergency, anybody monitoring the frequency. As I am doing this, I am
setting myself up for the "best glide" speed of 78 knots. Guard
responds with Sundowner 12345L, go ahead with your emergency. I replied
back, I have an extremely rough running engine, I am 12 miles from
destination, I have an alternative field in site should I need it, I
will be sqawking 7700. I then turn the transponder to 7700. In this
short time, I lost 500 valuable feet altitude.
As I reduced my power, and enriched the engine, trying different "power"
settings, I noticed the vibration reduced somewhat. I watched my VSI,
and noticed that I was able to "maintain" a 200 foot descent. Quick
math in my head said, I had "15 minutes" flying time if I left my
configuration the way it was, and now I was 10 miles from destination.
121.5 gets New Orleans approach, and New Orleans approach gets on 121.5
and tells me to squawk 4026. I acknowledge New Orleans approach, change
my transponder to 4026, and said to New Orleans approach, that I have a
stable 200 foot descent rate, engine is running rough, and my intentions
is to proceed on to L31. Once I made my decision, I pretty much left
what I had going alone. 4 miles out, I said "New Orleans approach,
Sundowner 12345L request to change to 122.80. New Orleans approach said
frequency change approved, please call FSS to let us know you are safe
on the ground. I said Sundowner 12345. will call FSS after touchdown.
I set the radio to 122.80, called in Unicom and said, St Tamminy
Sundowner 12345L declaring an emergency, inbound for runway 18 straight
in approach. In my nervousnous, New Orleans approach says, Sundowner
12345L, you are still transmitting on 121.5. Duh, helps to change the
button from Com 1 to Com 2. So, I switch coms, and repeat my broadcast.
2 miles out, see that I am way too high for straight in, I decided
instead of a straight in approach, that I would enter on the downwind
leg, and proceed to use runway 36 to lose my altitude. I announce on
122.80, Saint Tamminy, Sundowner 12345L declaring emergency, changing
intentions, entering downwind for 36. I left my power settings the way
I had it, for the first half of downwind, and then abeam the numbers, I
reduced the power ever so slowly, and also enriched the mixture ever so
slowly. Engine got rougher, but kept running. Trimmed for landing,
extended first set of flaps, and the second set of flaps on downwind. I
did this so all I had to do was realy concentrate on flying the plane
for base and final rather then "finess the plane". Kept my downwind
closer to the runway then normal and turn base much sooner then normal.
On final, I was 1200 feet above field elevation. On final, I heard that
little voice say, better to hit the trees at the end of the runway then
the beginning, so I made sure, that I had a higher then normal approach.
Seeing I was way high, I put in full right rudder, full left aileron,
and pretty much turn the plane perpendicular to the runway. Slip worked
great, ears starting popping on descent, and when I cleared the trees,
turned forward. Saw I was still too high, returned to the slip, for
another 5 to 10 seconds, and then straightened out. Cross the numbers
about 25 feet AGL, speed, just above glide speed, cut the throttle to a
fast idle. I get major vibration in the engine Started to lower the
nose, felt my speed increase, and then raised the nose. Hit ground
effect, halfway down the runway, ballooned to about 5 feet above the
ground, I raised the nose to bleed off the speed, landed on the last
third of the runway. Runway is 2999 feet, so I knew I wasn't stopping
at the end of the runway, applied firm brakes, rolled off the runway,
with the yoke clear to my chest. I was able to stop about 50 feet after
leaving the end of the runway in hard ground with about knee high
grass.
Engine was really rough, I turn around and limp back to the ramp,
airframe and gear fully intact. Go to shut down, and the engine did not
want to shut down. It finally shut down. My brother in law was waiting
for me at the airport (he is a pilot), we decide to start up the engine
to see if he could figure out the problem. Engine was rough on idle,
tried to increase RPMs, but the best we could get is 1800, so we shut
down.
We start calling A&P's around the area, and finally found one that could
come out the next day. After describing the symptoms, first thing she
thought was a fuel related problem, and asked me the usual questions,
did I sump, did I see water, and so on. Nothing in the fuel, I told her
runup was absolutely normal.
She pokes around the engine, pulling all fuel related hoses, saw lines
and screens were clear, so next, she pulled the prop through and found
that a cylinder lost all compressions. So, now the obviouse occurred,
now to find why.... She pulled the cylinder out, and after opening the
cylinder, we saw an unbelievable sight. Piston head had shards of metal
pounded in it from the exhuast valve, even more amazing was the cylinder
walls were smooth, and rings remained intact! She suspected that most
of the exhaust valve was ejected out the exhaust pipe as she found
fragments of metal through the exhaust manifold but very little in the
intake portion of the engine. Problem "solved" so we thought, replace
the cylinder, and off I go.
She comes back the next day, installed the cylinder, changed the oil,
leak tested the engine and closed the cowling, she wanted to go up with
me, as she had never been in a Sundowner. It is dark by this time, and
while she was getting her tools together, I preflight. I taxi to the
runway, call unicom to advise that I was backtaxing to 36. The runway
has a runup area at the very end of the runway, I do the runup, all
looks good. I get to the end of 36, and the A&P says, before departing,
I need you to do a full throttle test. I hold the brakes, put the
throttle full forward, and only get 2200 RPM. POH requires 2700. She
says, lean it a tad, see what happens. No change to RPM. Lean it more,
EGT and CHT goes up, engine starts running "normal rough". Needless to
say, not good. She says taxi back to the ramp. No flying tonight. We
taxi back, we pull the cowl. She says, the engine is acting like it is
getting too much hot air for the RPMs not to go full throttle,
reverifies the duct work, and all looks good. Last thing to look at is
the carberator as the engine was purring like a kitten, just could not
get 2700 RPM. We called it the night (11:00 p.m.)
She said, I had a better chance at winning the lotto then what happened
to me. The carberator was the top of the line carberator, and she said
in the 19 years she has been an A&P, she has never pulled one from an
engine. So, today, she pulls the carberator, and she tears it down.
She noticed that the lever to the throttle would not push full forward.
It would go it's full range. She felt that due to the severe vibration,
something in the carberator shook loose, and is preventing the full
extension of the throttle cable. So, now I need a new carberator put
in.
Seeing the forest through the trees, I figure the outcome was as good as
it got, considering the catastropic engine problem I experienced.
One thing I cannot thank my instructor enough was to instill the "what
if scenarios", as when it really happened, I heard him in my mind say,
make a decision, stick to it, but most importantly FLY THE PLANE.
The only thing I could not do during this entire episode is to pull the
POH for emergency procedures. I found as the real thing happens, you
don't have time to pull a book, find the chapter, and go to the list.
My first instinct was to do what I could remember (I studied my POH big
time when I bought the plane, and refer to it frequently, to be sure I
know what to do) and FLY THE PLANE.
I have an emergency checklist seperate, but in reality, the time it
takes to pull the list, get yourself oriented, you lose very valuable
time when you are in the plane by yourself. It may have been different
if I had a passenger, but when I was alone, I relied on my memory.
(which as it turned out was not so bad *smile*.
I could have possibley diverted to another airport in Slidell LA in
"gliding range" with a longer runway, but the thunderstorms that I saw
were over that airport, so I ruled out trying to make it to that
airport.
In "hangar" talk, I asked some pilots, should I file an ASR report. It
was split down the middle, some said yes, some said no. I am leaning on
filing a report.
I have not gotten the final cost in yet, since the carberator needs to
be ordered and installed, but I think I am looking at close to $3000.00
after all is said and done for parts and labor. I may get a small
rebate should the company be able to re-use the cylinder (not likely
from the damage I saw).
Allen
Old July 20th 03, 06:36 AM
I had a stuck valve cause a lot of vibration and power loss once.
Lucky me, I was on the ground when it happened. Thanks for the post.
Glad you made it out safe. $3k is painful but you walked away.
Eric
Old July 21st 03, 08:24 PM
Ron Natalie
wrote in message ...
That's what happened to me as well. I've still got the piston and cylinder
around as a souvenir. Blasted a hole right through the top of the piston.
Old July 20th 03, 06:43 AM
Jay Honeck
Great post, Allen. Glad everything worked out okay.
Just for the heck of it, I'd file the NASA form. Even though you did
absolutely nothing wrong, there is no reason NOT to file one. And, if for
some bizarre reason someone got a bean up their butt about something, you'd
have your "get-out-of-jail-free-card" in your hip pocket.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Allen
Old July 20th 03, 06:47 PM
Peter Gottlieb
There's also the statistical value of a report of a mechanical failure which
did not result in a NTSB reportable incident.
"Jay Honeck" wrote in message
news:86pSa.102464$N7.12511@sccrnsc03...
you'd
Jay Honeck
Iowa City, IA
Pathfinder N56993
Allen
Old July 20th 03, 07:19 PM
G.R. Patterson III
Great job - sounds like you didn't miss a thing!
George Patterson
The optimist feels that we live in the best of all possible worlds. The
pessimist is afraid that he's correct.
James Branch Cavel
Old July 22nd 03, 04:39 AM
clyde woempner
Nice job & thanks for the post.
Clyde
"A Lieberman" wrote in message
grass.
down.
in.
airport.
filing a report.
Allen
Old July 22nd 03, 02:51 PM
Mark
A Lieberman wrote in message ...
grass.
down.
in.
airport.
filing a report.
Allen
Sounds like you did a fine job thinking it through as you handled the
situation. I got my commercial training around there many years ago.
Drop me an email if you have time. I wonder if some of the people I
knew are still there Mark
IO 360 Power down (danger, long, rambling post!) Jim Harper Home Built 24 July 11th 04 01:04 AM
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 06:07 PM
Re; What do you think? Kelsibutt Naval Aviation 0 September 29th 03 07:55 AM
PFC Lynch gets a Bronze Star? Brian Military Aviation 77 August 2nd 03 12:15 PM
