On Dec 6, 2:40*pm, shkdriver
wrote: Anyone have any experience/thoughts to share about winch launching a shempp-hirth SHK? My example has CG tost hook on gear leg. Thanks, Scott W. -- shkdriver A caution not specific to the SHK but it may apply. For the first winch launch in any new glider type pay particular attention to seat back and rudder pedal adjustment. There should be no possibility that you will slip backward during the launch. I learned this one the hard way. I had quite a few hours in the Std Jantar, all aero tow. On my first winch launch I slid backward so my feet were not in contact with the pedals. I continued the launch with my elbows frantically clawing for grip on the cockpit side walls but was able to remain in control. Every other glider I had winched had a more upright seating position so I had never seen this problem before. Andy |
On Wed, 08 Dec 2010 06:20:37 -0800, Andy wrote:
A caution not specific to the SHK but it may apply. For the first winch launch in any new glider type pay particular attention to seat back and rudder pedal adjustment. There should be no possibility that you will slip backward during the launch. I've heard this said about the Discus 1 as well, but though I've winched them quite a bit I've not experienced it myself so it must only apply to pilots who prefer a seating position that's different from mine. I can imagine that with the seat fairly well forward the straps would be pretty much horizontal behind your shoulders and so won't to a lot to stop you sliding up the back of the seat. Bottom line: Making quite sure your straps are tight is even more important for winch than aero-tow due to the higher initial acceleration and much steeper climb-out. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Dec 8, 2:20*pm, Andy wrote:
On Dec 6, 2:40*pm, shkdriver wrote: Anyone have any experience/thoughts to share about winch launching a shempp-hirth SHK? My example has CG tost hook on gear leg. Thanks, Scott W. -- shkdriver A caution not specific to the SHK but it may apply. * *For the first winch launch in any new glider type pay particular attention to seat back and rudder pedal adjustment. *There should be no possibility that you will slip backward during the launch. I learned this one the hard way. *I had quite a few hours in the Std Jantar, all aero tow. *On my first winch launch I slid backward so my feet were not in contact with the pedals. *I continued the launch with my elbows frantically clawing for grip on the cockpit side walls but was able to remain in control. *Every other glider I had winched had a more upright seating position so I had never seen this problem before. Andy Same thing happened to me in a DG101 a few years ago. Did a whole winch launch keeping the stick just off the backstop with my fingertips and with my feet nowhere near the rudder pedals. Always do your straps up really tight for a winch launch, and if possible set the rudder pedals a bit closer than normal. Only use firm cushions behind you. Derek C |
On Dec 6, 12:13*pm, Martin Gregorie
wrote: On Mon, 06 Dec 2010 07:40:53 -0800, bildan wrote: http://www.technologyreview.com/blog...6103/?p1=Blogs I smell a certain lack of preliminary research: any RC glider pilot will tell you that pressure sensing TE varios for models have been available for a long time. It would seem to be a lot easier and less power-hungry to sample one of these than to calculate climb rate from GPS output. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | Whether this blogger has a good understanding of thermalling technique or not, it's interesting that UAV makers (Presumably for the military) have an interest in UAV's that automatically find and use thermals. It makes sense they should be interested. Maybe thermal finding instrumentation will come out of it. |
Autonomous Soaring has been around for awhile.
Take a look at: http://soaring.goosetechnologies.com/ Cheers, Andrew |
welding technique for clusters | wright1902glider | Home Built | 26 | March 27th 09 12:49 AM |
Question technique | Patrick R7 | Aviation Photos | 4 | September 30th 08 01:50 PM |
spinner trimming technique | Dick | Home Built | 0 | January 25th 05 11:57 PM |
instructor technique | Mike Stramba | Soaring | 8 | October 3rd 03 09:45 PM |
Flying Technique Question of the Day | Jim Vincent | Soaring | 24 | October 3rd 03 03:29 PM |
