On Dec 14, 11:03*am, John Cochrane
wrote: Can someone please explain the intent of this: "Rule change to add provision for restricted water to allow ballasting of all gliders up to the weight of the heaviest unballasted glider, in addition to current provision that allows no ballast. For a no-ballast day, the rule is unchanged. “No water contest rules” will not be changed – tail water is the only ballast allowed." Under what circumstances, contest type, class etc, is ballasting to the weight of the heaviest unballasted glider to be allowed? Why does the new rule apply to weight rather than wing loading? thanks Andy This addresses a situation such as Cesar Creek, where full ballast could not be used because of a soft field. However, some pilots had a lot of iron (motors) in the back, giving them a perceived wingloading advantage. So now, everyone can ballast to the same weight as the motorgliders. If it's safe to tow the motorgliders, it's safe to tow everyone at their weight. Newcastle or Parowan might want to do the same thing. Why weight rather than wingloading? Simplicity. Imagine the chaos if we have to find the highest wingloading mortorglider, then everyone else has to figure out how much ballast puts them at the same wingloading, then the scales guy has to verify they did the computation right. Weight is much easier, and we felt the difference in wing area of modern gliders is small enough that the resultant advantage to smaller wing area gliders is not worth worrying about. (And 3/5 of the rules committee flies Schleicher gliders... No, just kidding) The conventional no-ballast rules are still an option. For example, if no water is available, or if there is no time to give everyone a fair chance to water, weigh, and grid, then the CD can call conventional no- ballast rules. Fairness is also a consideration. If it's a clearly marginal 1 knot day and there are other reasons for wanting to limit water (Mifflin, a pain to get the fire trucks out) that argues for no-ballast rules. If it's booming but takeoff or runway considerations are limiting water, that argues for the water-to-same-gross rules. Bottom line, now CDs have two options for limiting water: 1) They can say "everyone can water up to XXX gross weight only" and 2) conventional no-water rules. Which to use depends on the circumstance, safety, fairness, etc. etc. I can see we're in for some interesting pilot meetings.... John Cochrane No water rule is US new wheel invention. If the airport is not safe(soft field ect.) , we should not fly or wait. If there is no water in the field we can bring our own water (Mifflin) If somebody didn't put his glider in the morning together and fill it with water(it was raining) , it is his problem. If was raining after morning briefing we should have no tape day. Same if somebody forgot to charge his battery. Can we make no battery day ?Maybe was no power at the airport last night.Some time ago I did check ride in Estrela and I got really ****ed (they had no airbrake rules),Can I use slip, NO was the respond.Took me 3 trays to stop+/- 50ft from my waiting son. Or maybe some of us are too old for all this hassle ? OK, we have a team ![]() rules. Water rule is aimed against Diana 2 and future Duckhawk fliers. Who is afraid ? Ryszard Before last Grand Prix in Chile there was protest against Diana 2 fliers having bigger wing loading.Both Diana fliers had to reduce water ballast, but it did not help. |
On Dec 17, 12:31*am, RW wrote:
On Dec 14, 11:03*am, John Cochrane wrote: Can someone please explain the intent of this: "Rule change to add provision for restricted water to allow ballasting of all gliders up to the weight of the heaviest unballasted glider, in addition to current provision that allows no ballast. For a no-ballast day, the rule is unchanged. “No water contest rules” will not be changed – tail water is the only ballast allowed." Under what circumstances, contest type, class etc, is ballasting to the weight of the heaviest unballasted glider to be allowed? Why does the new rule apply to weight rather than wing loading? thanks Andy This addresses a situation such as Cesar Creek, where full ballast could not be used because of a soft field. However, some pilots had a lot of iron (motors) in the back, giving them a perceived wingloading advantage. So now, everyone can ballast to the same weight as the motorgliders. If it's safe to tow the motorgliders, it's safe to tow everyone at their weight. Newcastle or Parowan might want to do the same thing. Why weight rather than wingloading? Simplicity. Imagine the chaos if we have to find the highest wingloading mortorglider, then everyone else has to figure out how much ballast puts them at the same wingloading, then the scales guy has to verify they did the computation right. Weight is much easier, and we felt the difference in wing area of modern gliders is small enough that the resultant advantage to smaller wing area gliders is not worth worrying about. (And 3/5 of the rules committee flies Schleicher gliders... No, just kidding) The conventional no-ballast rules are still an option. For example, if no water is available, or if there is no time to give everyone a fair chance to water, weigh, and grid, then the CD can call conventional no- ballast rules. Fairness is also a consideration. If it's a clearly marginal 1 knot day and there are other reasons for wanting to limit water (Mifflin, a pain to get the fire trucks out) that argues for no-ballast rules. If it's booming but takeoff or runway considerations are limiting water, that argues for the water-to-same-gross rules. Bottom line, now CDs have two options for limiting water: 1) They can say "everyone can water up to XXX gross weight only" and 2) conventional no-water rules. Which to use depends on the circumstance, safety, fairness, etc. etc. I can see we're in for some interesting pilot meetings.... John Cochrane No water rule is US new wheel invention. If the airport is not safe(soft field ect.) , we should not fly or wait. If there is no water in the field we can bring our own water (Mifflin) If somebody didn't put his glider in the morning together and fill it with water(it was raining) , it is his problem. If was raining after morning briefing we should have no tape day. Same if somebody forgot to charge his battery. Can we make no battery day ?Maybe was no power at the airport last night.Some time ago I did check ride in Estrela and I got really ****ed (they had no airbrake rules),Can I use slip, NO was the respond.Took me 3 trays to stop+/- 50ft from my waiting son. Or maybe some of us are too old for all this hassle ? OK, we have a team ![]() rules. Water rule is aimed against Diana 2 and future Duckhawk fliers. Who is afraid ? Ryszard Before last Grand Prix in Chile there was protest against Diana 2 fliers having bigger wing loading.Both Diana fliers had to reduce water ballast, * *but it did not help.- Hide quoted text - - Show quoted text - There are conditions such as at Caesar Creek in 2010 where the field was wet enough that towing fully loaded 18M gliders would be marginal enough to seriously consider not flying, yet not so bad when towing dry. 400 lb or so weight difference is significant in launch. In these kinds of situatuions it makes sense for the CD to have this option available so as to keep a good safety margin and not lose a day. The contemplated weight adjustment being looked at would add maybe 60 or 70 lb to "light" gliders to bring them closer to motorized gliders for fairness. This would be at tha option of the CD. This is pretty much a nationals issue in my expectation. Most other contests would not bother. UH |
On Dec 17, 8:42*am, wrote:
On Dec 17, 12:31*am, RW wrote: On Dec 14, 11:03*am, John Cochrane wrote: Can someone please explain the intent of this: "Rule change to add provision for restricted water to allow ballasting of all gliders up to the weight of the heaviest unballasted glider, in addition to current provision that allows no ballast. For a no-ballast day, the rule is unchanged. “No water contest rules” will not be changed – tail water is the only ballast allowed." Under what circumstances, contest type, class etc, is ballasting to the weight of the heaviest unballasted glider to be allowed? Why does the new rule apply to weight rather than wing loading? thanks Andy This addresses a situation such as Cesar Creek, where full ballast could not be used because of a soft field. However, some pilots had a lot of iron (motors) in the back, giving them a perceived wingloading advantage. So now, everyone can ballast to the same weight as the motorgliders. If it's safe to tow the motorgliders, it's safe to tow everyone at their weight. Newcastle or Parowan might want to do the same thing. Why weight rather than wingloading? Simplicity. Imagine the chaos if we have to find the highest wingloading mortorglider, then everyone else has to figure out how much ballast puts them at the same wingloading, then the scales guy has to verify they did the computation right. Weight is much easier, and we felt the difference in wing area of modern gliders is small enough that the resultant advantage to smaller wing area gliders is not worth worrying about. (And 3/5 of the rules committee flies Schleicher gliders... No, just kidding) The conventional no-ballast rules are still an option. For example, if no water is available, or if there is no time to give everyone a fair chance to water, weigh, and grid, then the CD can call conventional no- ballast rules. Fairness is also a consideration. If it's a clearly marginal 1 knot day and there are other reasons for wanting to limit water (Mifflin, a pain to get the fire trucks out) that argues for no-ballast rules. If it's booming but takeoff or runway considerations are limiting water, that argues for the water-to-same-gross rules. Bottom line, now CDs have two options for limiting water: 1) They can say "everyone can water up to XXX gross weight only" and 2) conventional no-water rules. Which to use depends on the circumstance, safety, fairness, etc. etc. I can see we're in for some interesting pilot meetings.... John Cochrane No water rule is US new wheel invention. If the airport is not safe(soft field ect.) , we should not fly or wait. If there is no water in the field we can bring our own water (Mifflin) If somebody didn't put his glider in the morning together and fill it with water(it was raining) , it is his problem. If was raining after morning briefing we should have no tape day. Same if somebody forgot to charge his battery. Can we make no battery day ?Maybe was no power at the airport last night.Some time ago I did check ride in Estrela and I got really ****ed (they had no airbrake rules),Can I use slip, NO was the respond.Took me 3 trays to stop+/- 50ft from my waiting son. Or maybe some of us are too old for all this hassle ? OK, we have a team ![]() rules. Water rule is aimed against Diana 2 and future Duckhawk fliers. Who is afraid ? Ryszard Before last Grand Prix in Chile there was protest against Diana 2 fliers having bigger wing loading.Both Diana fliers had to reduce water ballast, * *but it did not help.- Hide quoted text - - Show quoted text - There are conditions such as at Caesar Creek in 2010 where the field was wet enough that towing fully loaded 18M gliders would be marginal enough to seriously consider not flying, yet not so bad when towing dry. 400 lb or so weight difference is significant in launch. In these kinds of situatuions it makes sense for the CD to have this option available so as to keep a good safety margin and not lose a day. The contemplated weight adjustment being looked at would add maybe 60 or 70 lb to "light" gliders to bring them closer to motorized gliders for fairness. This would be at tha option of the CD. This is pretty much a nationals issue in my expectation. Most other contests would not bother. UH In this specific situation old rule (CD could only propose no water(or quits) and all pilots have to agree) would get same results. Especially if we would let get everybody to same the weight(part of newest rule) it is hard to imagine opposition. PW5-ers do it every contest(they have option to bring their PW5 to the heaviest PW5 glider) Ryszard |
On Dec 14, 9:51*am, "John Godfrey (QT)"
wrote: http://www.ssa.org/files/member/2010...e%20Meeting%20... John Godfrey (QT) Anyone care to provide a good explanation of the new 'long landout vs early finisher' scoring rule? TA |
On Dec 16, 3:48*pm, Frank wrote:
On Dec 14, 9:51*am, "John Godfrey (QT)" wrote: http://www.ssa.org/files/member/2010...e%20Meeting%20... John Godfrey (QT) Anyone care to provide a good explanation of the new 'long landout vs early finisher' scoring rule? TA If I recall correctly this is a recurring topic of where to set max distance points versus min speed points. It was polled again this year. You may remember a rule change a few years ago increased max distance points to 600 from 400 so that an outlanding was less likely to mean the end of your contest. The result was that speed points became compressed because finishers frequently post speeds that are less than 60% of the winners speed. The 2011 change allows competitors who fly long tasks but just miss getting home to score more points than competitors who fly the shortest possible task just to get home. It changes the long-held philosophy that every speed finisher should get more points than any landout. It will primarily apply in cases where there were exceptionally long landout flights along with significantly under time finishers. I think I got that right. 9B |
On Dec 16, 8:19*pm, Andy wrote:
On Dec 16, 3:48*pm, Frank wrote: On Dec 14, 9:51*am, "John Godfrey (QT)" wrote: http://www.ssa.org/files/member/2010...e%20Meeting%20.... John Godfrey (QT) Anyone care to provide a good explanation of the new 'long landout vs early finisher' scoring rule? TA If I recall correctly this is a recurring topic of where to set max distance points versus min speed points. *It was polled again this year. You may remember a rule change a few years ago increased max distance points to 600 from 400 so that an outlanding was less likely to mean the end of your contest. The result was that speed points became compressed because finishers frequently post speeds that are less than 60% of the winners speed. The 2011 change allows competitors who fly long tasks but just miss getting home to score more points than competitors who fly the shortest possible task just to get home. It changes the long-held philosophy that every speed finisher should get more points than any landout. It will primarily apply in cases where there were exceptionally long landout flights along with significantly under time finishers. I think I got that right. 9B Yes, that's what I understand too. However, I haven't heard any details about exactly how the scoring would be changed - i.e. how the current scoring formulas for MDP (Max Distance Points), MSP (Max Speed Points), "Points for Finishers" and "Points for Non-Finishers" would be modified. Stating the philosophy is one thing, but the devil is in the details (and the unintended consequences, whatever they turn out to be ;-). Just my luck that I'm giving a talk on the nuances of the U.S. contest scoring rules, and there is a potentially game-changer looming on the horizon ;-). TA TA |
On Dec 16, 6:39*pm, Frank wrote:
On Dec 16, 8:19*pm, Andy wrote: On Dec 16, 3:48*pm, Frank wrote: On Dec 14, 9:51*am, "John Godfrey (QT)" wrote: http://www.ssa.org/files/member/2010...e%20Meeting%20... John Godfrey (QT) Anyone care to provide a good explanation of the new 'long landout vs early finisher' scoring rule? TA If I recall correctly this is a recurring topic of where to set max distance points versus min speed points. *It was polled again this year. You may remember a rule change a few years ago increased max distance points to 600 from 400 so that an outlanding was less likely to mean the end of your contest. The result was that speed points became compressed because finishers frequently post speeds that are less than 60% of the winners speed. The 2011 change allows competitors who fly long tasks but just miss getting home to score more points than competitors who fly the shortest possible task just to get home. It changes the long-held philosophy that every speed finisher should get more points than any landout. It will primarily apply in cases where there were exceptionally long landout flights along with significantly under time finishers. I think I got that right. 9B Yes, that's what I understand too. *However, I haven't heard any details about exactly how the scoring would be changed - i.e. how the current scoring formulas for MDP (Max Distance Points), MSP (Max Speed Points), "Points for Finishers" and "Points for Non-Finishers" would be modified. *Stating the philosophy is one thing, but the devil is in the details (and the unintended consequences, whatever they turn out to be ;-). Just my luck that I'm giving a talk on the nuances of the U.S. contest scoring rules, and there is a potentially game-changer looming on the horizon ;-). TA TA The specific formula change is described in the pilot poll. 9B |
On Dec 16, 3:48*pm, Frank wrote: On Dec 14, 9:51*am, "John Godfrey (QT)" wrote: http://www.ssa.org/files/member/2010...e%20Meeting%20.... John Godfrey (QT) Anyone care to provide a good explanation of the new 'long landout vs early finisher' scoring rule? TA If I recall correctly this is a recurring topic of where to set max distance points versus min speed points. *It was polled again this year. You may remember a rule change a few years ago increased max distance points to 600 from 400 so that an outlanding was less likely to mean the end of your contest. The result was that speed points became compressed because finishers frequently post speeds that are less than 60% of the winners speed. The 2011 change allows competitors who fly long tasks but just miss getting home to score more points than competitors who fly the shortest possible task just to get home. It changes the long-held philosophy that every speed finisher should get more points than any landout. It will primarily apply in cases where there were exceptionally long landout flights along with significantly under time finishers. I think I got that right. 9B That is correct. The only exception occurs when only one person finishes and they are a "min distancer." In that case the finisher gets the gold, but its a very chancy strategy to bet on being the only finisher. On the weight / handicap issue(s), the RC continues to try an find "fairness" solutions to problems that all have their base in the decreasing number of competitors and the need to to avoid contests with classes made up of only 3 or 4 ships. It is not an easy task and all the solutions found so far are imperfect. Ongoing thoughtful discussion is really helpful. John Godfrey (QT) Rules Committee |
On Dec 16, 3:48*pm, Frank wrote: On Dec 14, 9:51*am, "John Godfrey (QT)" wrote: http://www.ssa.org/files/member/2010...e%20Meeting%20.... John Godfrey (QT) Anyone care to provide a good explanation of the new 'long landout vs early finisher' scoring rule? TA If I recall correctly this is a recurring topic of where to set max distance points versus min speed points. *It was polled again this year. You may remember a rule change a few years ago increased max distance points to 600 from 400 so that an outlanding was less likely to mean the end of your contest. The result was that speed points became compressed because finishers frequently post speeds that are less than 60% of the winners speed. The 2011 change allows competitors who fly long tasks but just miss getting home to score more points than competitors who fly the shortest possible task just to get home. It changes the long-held philosophy that every speed finisher should get more points than any landout. It will primarily apply in cases where there were exceptionally long landout flights along with significantly under time finishers. I think I got that right. 9B I like the long landout rule change. It encourages trying to create a nice flight utilizing the most of each day without feeling that a landout is going to severely punish your standing. In Perry last year I flew what for me was a very nice flight. I landed 1.5 miles short of the home airport. Competitors that flew 60% of my distance punished me in the daily points. I planned my flight poorly for the conditions but I sure was proud of all those miles! Lane XF |
![]() Anyone care to provide a good explanation of the new 'long landout vs early finisher' scoring rule? TA Take a look at the poll, question 4, which tries to explain it all compactly. http://www.ssa.org/files/member/2010...%20Results.pdf Come back if that isn't clear John Cochrane |
Proposed US Competition Rules Changes for 2010 | [email protected] | Soaring | 1 | December 17th 09 05:20 PM |
SSA Competition Rules Meeting Minutes | [email protected] | Soaring | 3 | December 4th 09 08:04 PM |
US Competition Rules Poll and Committee Election | [email protected] | Soaring | 6 | October 13th 09 01:37 PM |
SSA Competition Rules Committee Nominations and Poll | [email protected] | Soaring | 0 | June 3rd 09 02:16 PM |
2005 SSA Rules Committee Meeting Minutes Posted | Ken Kochanski (KK) | Soaring | 1 | December 20th 05 05:38 PM |
