Sport Pilot Glider Rating?
Old January 4th 11, 02:11 PM posted to rec.aviation.soaring
Tony V
Default Sport Pilot Glider Rating?
Mike the Strike wrote:
...... the Sport certificate is only valid for flying light sport
aircraft. I am not aware that any two-seat LSA gliders exist.
Schweizer 2-33, for one.
Tony
Old January 4th 11, 09:40 PM posted to rec.aviation.soaring
Bruce Hoult
On Jan 5, 1:09*am, Mike the Strike wrote:
Except that the Sport certificate is only valid for flying light sport
aircraft. *I am not aware that any two-seat LSA gliders exist.
The only thing stopping most of them is a too-high Vne. There are a
number of older two seat gliders with Vne until 120 knots:
Ka7: 92
ASK13: 108
Janus: 119
It's easy, and I suspect even legal, to simply make up a plate with a
lower Vne than the manufacturer originally specified. There are many
cases where a glider model's Vne has been reduced due to problems
discovered later such as flutter. Can you (or your engineer) reduce a
single glider's placarded Vne because of repairs, or simply because
you feel that it is "old"? It's no great hardship in most glider
flying to lose a few knots off the top speed.
I've definitely seen a powered aircraft operated as a LSA by replacing
the placard with one specifying a lower MTOW (which was then
ignored...).
Adding an airplane rating to private pilot glider gmcd05 Soaring 35 April 25th 08 01:43 AM
Foreign Pilot Getting US Glider Rating Papa3 Soaring 10 April 16th 07 02:27 PM
Sport Pilot and Glider Questions Ralph Steiner Soaring 17 February 22nd 06 11:34 AM
endorsements for private pilot glider rating Joel Taylor Soaring 2 October 2nd 03 06:44 AM
Private Pilot Glider Rating Requirements John Soaring 8 August 21st 03 01:09 AM
