Possible remote thermal finder?
Old January 23rd 11, 07:00 AM posted to rec.aviation.soaring
Alan[_6_]
Default Possible remote thermal finder?
In article mpcehand writes:
On Jan 21, 6:16=A0pm, John Cochrane
On Jan 21, 2:04=A0pm, bildan wrote:
http://www.newscientist.com/blogs/on...lephoto-lens-s...
Yes! It's always struck me that a little signal processing on the
shimmer you see in telephoto lenses might work to show thermals.
A bit of signal processing would also show birds, gliders, cornstalks,
cu development, and other stuff that the naked eye tends to miss.
Darn day job...
John Cochrane
Hmmm. I had a different idea of how a remote thermal finder might be made,
but no time to work on it, as it would take a bunch of effort to learn the
details of actual implementation to try it.
The idea of a remote thermal finder is already being worked on by a
very distinguished scientist who lives and fly's @ the best soaring
center on the planet earth.
My money is on him.
Why would he be the one to do it? If the soaring is so good there, he
probably has no trouble finding lift.
My money would be on someone who flys in a marginal area, who needs
a thermal finder.
Alan
Old January 23rd 11, 04:51 PM posted to rec.aviation.soaring
bildan
http://www.newscientist.com/blogs/on...lephoto-lens-s....
Darn day job...
John Cochrane
* Hmmm. *I had a different idea of how a remote thermal finder might be made,
My money is on him.
* Why would he be the one to do it? *If the soaring is so good there, he
* My money would be on someone who flys in a marginal area, who needs
a thermal finder.
* * * * Alan
My guess (possibly wrong) is the biggest value of a remote thermal
detector, at least at first, will be sort of a short-range "thermal
centering aid". Knowing there is strong core 300 meters away is
"highly actionable" data. Cruising along while searching a 1 km wide
path will eliminate passing close by a strong thermal without knowing
about it. Knowing there is a thermal 10 km away is interesting but
it's a good bet it will dissipate before you can get there and chasing
after it may not be the best strategy.
Old January 23rd 11, 05:35 PM posted to rec.aviation.soaring
John Cochrane[_2_]
* * * * Alan
centering aid". *Knowing there is strong core 300 meters away is
"highly actionable" data. * Cruising along while searching a 1 km wide
about it. *Knowing there is a thermal 10 km away is interesting but
The next biggest value will be that even 1 km range thermal detectors
will eliminate the start gate roulette, gaggling and leeching in
contests. Why go through all that when you can reliably find the
thermals on your own?
That is, after the first guy to bring one destroys the competition at
the world championships! ..
In addition to camera signal processing to see light refraction, same
to see birds/gliders, lidar to see dust concentration, doppler lidar
to see dust movements, active or passive (listen to weather/FAA) radar
to see bugs, birds, and gliders, infrared to see moisture
concentration, infra red to see heat, would all work. Most of these
are used now in ground-based or large aircraft form for various other
purposes -- doppler lidar to study storms pollution plumes and wind
profilers, bird/bug radar to study former, FLIR in the military,
They need only a bit of miniaturization. Lots of winter projects for
the technically inclined!
More speculation on thermal detectors:
http://faculty.chicagobooth.edu/john..._detectors.mht
http://faculty.chicagobooth.edu/john...s/barnaby.html
John Cochrane
Thermal Forcasting -Thermal index gldrgidr Soaring 6 November 27th 10 10:26 PM
National Rental Aircraft Finder Larry Dighera Piloting 5 September 4th 07 11:23 PM
Hole Finder [email protected] Home Built 2 March 6th 06 02:32 PM
Thermal Data Files Thermal Mapping Project Australia Mal Soaring 0 December 2nd 05 11:14 PM
cheap fuel finder? [email protected] Owning 11 May 7th 05 12:58 AM
