Shop Labor Rates (here and there)
Old September 4th 03, 09:37 AM
Craig Prouse
Default Shop Labor Rates (here and there)
In the SF Bay Area, I've become desensitized to shop labor rates in the
range of $90/hr. Plus or minus $5, this seems to be the going rate at PAO,
SQL, RHV, or SJC. That's after you finally get your plane in the shop,
which can take a day or two or seven.
I recently had a very favorable experience at HAI (Hillsboro Aviation, HIO,
Hillsboro, Oregon) for only $65/hr. In the future I will strongly consider
scheduling some of my periodic maintenance around trips out of the local
area.
Note to local, extortionate Bay Area shops: All Your Base Are Belong to
Suckers.
Old September 4th 03, 02:17 PM
Dan Thompson
Here in Dallas, my A&P charges $60 per hour, my auto mechanic $75 per hour.
"Craig Prouse" wrote in message
PAO,
HIO,
consider
area.
Suckers.
Old September 4th 03, 07:13 PM
Craig
"Dan Thompson" wrote in message m...
The FBO that I used to work for, here in the DFW area charged between
45 and 65$ an hour. The rate was based on if you were a fuel
customer/tennent or fly-in. Routine clients got the lower rate too.
If we could fix the problem in less than 5-10 minutes, a lot of the
time the boss just charged for materials.
A friend's restoration shop just charges labor at a flat rate for the
job plus materials.
Craig C.
Old September 5th 03, 02:28 PM
Rosspilot
Charging by the hour is inherently crooked and creates incentive to work
inefficiently and as slowly as possible. We are the losers under this stupid
system.
I know, I know . . . I'm all alone in this.
www.Rosspilot.com
Old September 5th 03, 03:25 PM
G.R. Patterson III
system.
I don't think so. The auto dealers agree with you.
George Patterson
A friend will help you move. A really good friend will help you move
the body.
Old September 5th 03, 10:32 PM
Stu Gotts
And being paid by the job is an incentive to do shoddy work. Either
way, there are always faults unless YOU manage the work being done.
On 05 Sep 2003 13:28:24 GMT, ospam (Rosspilot)
system.
www.Rosspilot.com
