"G.R. Patterson III" wrote:
Gilan wrote: if you are looking for opinions then I have to say I think if Sport Pilot ever becomes a reality then a Cessna 150 or 152 will get very cheap. Why? George Patterson A man who carries a cat by the tail learns something that cannot be learned any other way. Samuel Clemens If Sport Pilot and Light Sport Aircraft reach their full potential, then we should have reasonably priced aircraft with the payload of the 150/152 and the speed (forgive the misuse of the word) and range of the 172. That is certainly not a given; since I think that the gross weight limit is about 250 to 350 pounds lower than it should be, and that the average LSA will frequently operate over gross. Peter |
![]() "Peter Dohm" wrote in message If Sport Pilot and Light Sport Aircraft reach their full potential, then we should have reasonably priced aircraft with the payload of the 150/152 and the speed (forgive the misuse of the word) and range of the 172. For a flyable aircraft, new, roughly 1/3rd the cost of a new aircraft from Cessna or Piper. That is certainly not a given; since I think that the gross weight limit is about 250 to 350 pounds lower than it should be, and that the average LSA will frequently operate over gross. Actually, that's not quite true. It would be true if we were talking about existing certified aircraft. A Cessna 150 weighs 1600 lbs. I am disappointed that LSA does not cover the Cessna 150 or Piper Tomahawk. However, for homebuilt planes, the weight is okay. My only disappointment there was the Murphy Rebel which is too heavy; the Murphy Maverick fits because it was designed for the overseas microlight market. Almost all of the aircraft from Fisher fit the category although they perform more like a Piper Cub than a 172. There are aircraft from Capella, Rans, and Zenith that fit the class. It should also be noted that even EAA only recommended an increase to 1300 lbs even and that was only to allow additional (heavier) engines. As it currently stands, the primary engines would be either Rotax or Jabiru (perhaps Hirth). With an additional 78 lbs, Suburu conversions, Continental O-200s and Lycoming 235's as well as the smallest Franklin are usable. As far as the weight being a problem, again a Cessna 150 at 1600 lbs only has a 600lb payload. A Zenith 601 at 1200lbs has the same 600lb payload. My feeling was that they should have put in a waver for certified aircraft to allow light trainers to exceed the weight limit. However, it won't be a problem for homebuilts. |
On Sat, 20 Sep 2003 04:40:23 +0000, Brent Rehmel wrote:
As far as the weight being a problem, again a Cessna 150 at 1600 lbs only has a 600lb payload. A Zenith 601 at 1200lbs has the same 600lb payload. My feeling was that they should have put in a waver for certified aircraft to allow light trainers to exceed the weight limit. However, it won't be a problem for homebuilts. Quoting the FAA's page on LSA... Light-sport aircraft means an aircraft, other than a helicopter or powered-lift, that is limited to: 1. A maximum takeoff weight of 1,232 pounds (560 kilograms) or, for lighter-than-air aircraft, a maximum gross weight of 660 pounds (300 kilograms); 2. A maximum airspeed in level flight with maximum continuous power (VH) of 115 knots CAS under standard atmospheric conditions; 3. A maximum never-exceed speed (VNE) of 115 knots CAS for a glider; 4. A maximum stalling speed or minimum steady flight speed in the landing configuration (VS0) of 39 knots CAS; 5. A maximum stalling speed or minimum steady flight speed without the use of lift-enhancing devices (VS1) of 44 knots CAS; 6. A maximum seating capacity of two persons, including the pilot; 7. A single, non-turbine engine, if powered; 8. A fixed or ground-adjustable propeller, if powered; 9. A fixed-pitch, semi-rigid, teetering, two-blade rotor system, if a gyroplane; 10. A non-pressurized cabin, if equipped with a cabin; and 11. Fixed landing gear, or for seaplanes, repositionable landing gear. The planes you mentioned have a higher gross weight than 1,232 lbs and exceed the VNE as well. If you look at it as I am, the limitations will be so severe that you will fly single seat as you would have to fly an ultralight otherwise. Take 2 190 lbs adults, that 380 lbs, subtracted from 1,232 gives 852 lbs for the aircraft and fuel. Assume 26 gal of fuel, subtract 156 lbs from 852 giving 696 lbs for you plane. That doesn't give you a whole lot of plane. My numbers are derived from the newer 190 lb average weight now, 26 gallons of fuel being what the 150 has and usually the smaller amount in certified aircraft. The 1,232 lb gross weight from the NPRM from the FAA's website. The rest being basic math. You'll notice on line 1 from their site there is the word "or" before the 660 lbs gross weight, so it does not apply to planes, those being limited to 1,232 lbs total. The only thing I see that could change this would be how maximum takeoff weight is interpreted. If it means the weight of the plane and passengers, then this new rule will not hurt any existing aircraft, be it a 150 or a Cub, they all have more capability than the limitations listed above which came from the FAA's page on the nprm for the sport pilot. Anybody who thinks a 150 will drop in value has their head in the clouds because PP's will continue to fly it over the lower performing category until such time as they can't. |
Charles,
The cost of aviating is increasing and made a major increase after 9/11. The result is that most people have had to move down one notch in plane ownership: - Doctors who used to buy new bonanza's are now getting used ones, - (Lawyers are too scared to fly) - Engineers that use to have Mooney's now get Cessna's or cherokees. - Blue collar workers who used to get 182/172's now get 150/2s. Also, more people are looking at total cost of ownership, which favors the lower maintenance cost of single engine, fixed pitch, fixed gear simple planes. The result is: - more demand at the bottom end and solid pricing for 150/2. - Less demand for the older bo's and Mooneys. Mitch - That my $0.02...Businessmen buy jets "Charles Talleyrand" wrote in message ... Anyone want to guess the medium term price trends for a C-150? By medium term I mean the next five-ish years. My guess would be "more of the same" meaning increases of a few percent a year with mild year-to-year variations. The only effects I can see are whatever's left of the upward bounce-back from the 9-11 price drops, any price drops that might occur becuase of the current political trends against general aviation, and the possible coming influx of "Sport Light Airplanes". |
David Megginson wrote in message
I'd be surprised to see too many people buying a 150/2 for financial reasons -- a Cherokee 140 costs about the same to purchase, fuel, and maintain, but it has two more seats and flies faster. I think that people who buy the 150/2 do it because of personal preferences for style or handling. Partner and I purchased a '67 150G in late June. Why? 1. It's what we're most familiar with; 2. First time ownership meant K.I.S.S.; 3. It fits our mission profile & it fits our wives' expense profile. Best, Greg Hopp N4691X |
1. It's what we're most familiar with; 2. First time ownership meant K.I.S.S.; 3. It fits our mission profile & it fits our wives' expense profile. Best, Greg Hopp N4691X AND, you'll never find a Cherokee that can legally do loops and spins like the A150/152! |
Floridians Are Hit With Price Gouging | X98 | Military Aviation | 0 | August 18th 04 04:07 PM |
Cessna buyers in So. Cal. beware ! | Bill Berle | Home Built | 73 | June 25th 04 04:53 AM |
1977 Cessna 182 Special Price | Bill Davidson | Aviation Marketplace | 0 | June 7th 04 11:25 PM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Aviation Marketplace | 1 | November 4th 03 12:57 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
