When I installed my EI 14 channel EGT/CHT I used the two free channels
for OAT and carb temp. I have had it for four years and it has worked perfectly. Kind of a gee whiz thing though. Since I fly out here in the west carb ice is not a factor. Montblack wrote: ("Michael 182") I don't think I have one - have an egt and a carb temp. I'll look again when I get in the plane, but I can't picture it. I read my share of posts and this is the first time I've noticed someone mentioning a carb temp gauge. Is it a nice luxury, or not overly necessary? Is it a standard piece of equipment on turbo's? Are they ok in reliability (accuracy) and longevity? Do people, without them, install them because carb temp gauges are on their *someday* list? |
![]() Ron Natalie wrote: "Michael 182" wrote in message news:uR2ab.374025$cF.110854@rwcrnsc53... On the other jand I've been told to maintain CHT of 325-350, which is quite a trick given no cylinder thermometer. One mechanic said to just keep it in the green for the first 20 hours to keep the turbo from generating too much heat. You don't have a CHT or you don't have one on that cylinder? I thought 182's had at least a single point CHT. Bottom left gauge in the six pack. Although there is no temps shown except a middle one and a red line. |
All right, I'm sufficiently embarrassed.
Any clue where 325-350 would reside on the gauge? Michael "Newps" wrote in message news:w86ab.488884$Ho3.82663@sccrnsc03... Ron Natalie wrote: "Michael 182" wrote in message news:uR2ab.374025$cF.110854@rwcrnsc53... On the other jand I've been told to maintain CHT of 325-350, which is quite a trick given no cylinder thermometer. One mechanic said to just keep it in the green for the first 20 hours to keep the turbo from generating too much heat. You don't have a CHT or you don't have one on that cylinder? I thought 182's had at least a single point CHT. Bottom left gauge in the six pack. Although there is no temps shown except a middle one and a red line. |
![]() Michael 182 wrote: All right, I'm sufficiently embarrassed. Any clue where 325-350 would reside on the gauge? Exactly? No, not without pulling it out and putting it in the oven. About 2/3 to the red though. |
![]() "Newps" wrote in message news:w86ab.488884$Ho3.82663@sccrnsc03... .. Bottom left gauge in the six pack. Although there is no temps shown except a middle one and a red line. The operating limitations book probably tells you what the red line is. On my plane, the red line is just the top of the normal operating range. keeping a needles width (knowning the stock cerssna guages) below it is probably fine. |
![]() Ron Natalie wrote: "Newps" wrote in message news:w86ab.488884$Ho3.82663@sccrnsc03... . Bottom left gauge in the six pack. Although there is no temps shown except a middle one and a red line. The operating limitations book probably tells you what the red line is. The book and the gauge list it. |
"Michael 182" wrote:
On one hand I've been told, in capital letters, "DO NOT BABY THE ENGINE" On the other jand I've been told to maintain CHT of 325-350 Both correct. Running at high power is necessary to seat the rings. Low temperature is necessary to prevent glazing the cylinders. Keep the cowl flaps open and the mixture rich. Keep the power high - don't fly so high that power is reduced below 75% until the cylinders are broken in. How come you don't have a CHT gauge? -- Dan C172RG at BFM |
![]() "Dan Luke" c172rgATbellsouthDOTnet wrote in message ... "Michael 182" wrote: Keep the cowl flaps open and the mixture rich. Keep the power high - don't fly so high that power is reduced below 75% until the cylinders are broken in. Here's Mattituck's take on it. http://www.mattituck.com/new/articles/engbrkin.htm |
Just an update - flew a 2.5 hour break in flight today (Longmont to the
South Dakota line and back). What a difference. 5-8 knots greater IAS, better climb with lower MP settings, and just a better feel - kind of more solid feeling in the vibration. Of course, all of this might be rationalization for a 5-6K bill... Michael "Michael 182" wrote in message news:uR2ab.374025$cF.110854@rwcrnsc53... A while ago I posted about an incurable oil leak in my '79 TR-182. Turned out to be rings. Decided to get a top overhaul. Now I am breaking in the new cylinders. On one hand I've been told, in capital letters, "DO NOT BABY THE ENGINE" On the other jand I've been told to maintain CHT of 325-350, which is quite a trick given no cylinder thermometer. One mechanic said to just keep it in the green for the first 20 hours to keep the turbo from generating too much heat. Any comments? Thanks, Michael |
South Dakota line and back). What a difference. 5-8 knots greater IAS, better climb with lower MP settings, and just a better feel - kind of more solid feeling in the vibration. Of course, all of this might be rationalization for a 5-6K bill... Michael, I highly recommend adding a little (in aviation terms!) to your bill at this time, and add a multi-channel engine monitor to your panel. When we put in our rebuilt O-540 last year, I considered it a "must have". As opposed to the old single-channel EGT/CHT meter, our JPI EDM-700 enables us to graphically monitor each cylinder's performance in real-time, and allows us to adjust mixture and throttle settings in order to equalize temperatures between cylinders. It also gives precise oil temperature and fuel flow information. Compared to the cost of an engine, the cost of installation is insignificant. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com |
IO470-E cylinders | gabriel hatch | Aviation Marketplace | 0 | October 24th 04 01:02 PM |
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 07:28 PM |
~ DICK GRILLED FOR CIA LEAK - CAN YOU SAY PRISON?! ~ | ~ THE CHOKING CHIMP ~ | Military Aviation | 0 | June 6th 04 05:34 AM |
0-320 cylinders | Drew Dalgleish | Home Built | 9 | December 8th 03 04:25 PM |
Oil Leak in TR182 | Michael 182 | Owning | 2 | August 17th 03 07:13 PM |
