![]() Ben Jackson wrote: I found the SCAT tube between the muffler shroud and the defrost vent in the glareshield has some cracks (you can only see them if you flex the tube a certain way, which is why they've been missed). Does this present a carbon monoxide danger? No. It's not the heat exchanger that's cracked, only the tube that carries the warm air to the cabin. I plan to get it replaced soon but I need to know if I should ground the plane in the meantime. No. |
Hi Ben.
I have noted a number of replies saying yes and no to your question. Unfortunately I cannot comment with authority on the 172's system, but on CT-4s small pinprick size holes in both the heated and cool air scatting were normally found to be the cause of higher than allowable levels of carbon monoxide in the cockpit on post maintenance ground runs. I tend to be wary with these matters. You can't just pull over to the side of the road for some fresh air if you start feeling tired. :-) Darryl Gibbs. "Ben Jackson" wrote in message et... I found the SCAT tube between the muffler shroud and the defrost vent in the glareshield has some cracks (you can only see them if you flex the tube a certain way, which is why they've been missed). Does this present a carbon monoxide danger? It's not the heat exchanger that's cracked, only the tube that carries the warm air to the cabin. I plan to get it replaced soon but I need to know if I should ground the plane in the meantime. -- Ben Jackson http://www.ben.com/ |
Thank You, Thank You, Thank You. Now if you can have the pope verify
your post, maybe some of the readers here will believe it. DON'T MONKEY AROUND WITH EXHAUST GASSES, that includes anything that may be lingering around the engine compartment. On Fri, 19 Sep 2003 05:09:29 GMT, "Darryl Gibbs" wrote: Hi Ben. I have noted a number of replies saying yes and no to your question. Unfortunately I cannot comment with authority on the 172's system, but on CT-4s small pinprick size holes in both the heated and cool air scatting were normally found to be the cause of higher than allowable levels of carbon monoxide in the cockpit on post maintenance ground runs. I tend to be wary with these matters. You can't just pull over to the side of the road for some fresh air if you start feeling tired. :-) Darryl Gibbs. "Ben Jackson" wrote in message . net... I found the SCAT tube between the muffler shroud and the defrost vent in the glareshield has some cracks (you can only see them if you flex the tube a certain way, which is why they've been missed). Does this present a carbon monoxide danger? It's not the heat exchanger that's cracked, only the tube that carries the warm air to the cabin. I plan to get it replaced soon but I need to know if I should ground the plane in the meantime. -- Ben Jackson http://www.ben.com/ |
![]() Darryl Gibbs wrote: I tend to be wary with these matters. You can't just pull over to the side of the road for some fresh air if you start feeling tired. :-) In a Cessna you can. It's called opening the window. I could probably route the exhaust pipe into the cabin and not get sick. Four vents and the opening window oughta take care of it. |
"Newps" wrote:
Four vents Five |
![]() I'm just curious, coming in rather late to this discussion... How many answers came from those who do this sort of stuff for a living...with the right initials behind their name? How many came from those who have no direct knowledge other than hearsay or supposition? Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Jim Weir wrote:
I'm just curious, coming in rather late to this discussion... How many answers came from those who do this sort of stuff for a living...with the right initials behind their name? How many came from those who have no direct knowledge other than hearsay or supposition? I'm afraid the initials after my name aren't the ones you're talking about, so I guess that puts me in the "hearsay or supposition" camp. Was I wrong? Russell "almost always willing to learn" Kent |
initials here, along with common sense.
On Fri, 19 Sep 2003 13:03:54 -0700, Jim Weir wrote: I'm just curious, coming in rather late to this discussion... How many answers came from those who do this sort of stuff for a living...with the right initials behind their name? How many came from those who have no direct knowledge other than hearsay or supposition? Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
On Fri, 19 Sep 2003, Jim Weir wrote:
I'm just curious, coming in rather late to this discussion... How many answers came from those who do this sort of stuff for a living...with the right initials behind their name? How many came from those who have no direct knowledge other than hearsay or supposition? The guy that works on my plane is an IA with about 20 years experience and I'm a complete idiot with regard to this stuff. He has no better idea than I do whether or not the air flows into or out of the hole in the hose. He's never mesured the pressure inside a cowling in flight. I say just replace the hose because it's cheap and you don't really know. -- ------------------------------------------------------------------ Say NO to useless over-quoting! Just quote a few lines to get the point across, not the whole goddamn thing, OK? Thanks! :-) ------------------------------------------------------------------ |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 09:10 PM |
