#11
(JDupre5762) wrote in message
... MS 24694 are flush type structural screws and are available in stainless (MS 24694C). Spruce, Chief, Wicks, and many others have them. That may well be true but when I spoke to D&D supply a couple of years ago they told me that the stainless flush screws were not strong enough for the application and they would not sell them in thier Piper fuel tank kits. I suppose that lots of things can change in two years. I will call them tomorrow and ask again. John Dupre' John, MS 24694C screws are 300 series stainless with an ultimate strength of 85,000 psi. Typical non-structural machine screws have tensile strengths of 55-60,000 psi. Most steel structural screws (MS 27039, AN 525, MS 24694) have tensile strengths of 125,000 psi. The MS 24694C are classified as structural since they have an unthreaded shank portion where any shear load is carried. This unthreaded portion is critical to any structural screw as having threads in shear is a BIG no-no. If you need to have stronger screws that 85 ksi., then they are made but I don't know who sells them. The 85 ksi screws are stronger than the 2024-T3 aluminum they are mounted in for any thickness up to .120 in. for the thinnest flange that the tanks or wing section may have (not the total thickness, for a #10 size screw which is I think the size used in the tanks). If you want to look for them, either NAS 1221E or NAS 8703 are 160,000 psi corrosion resistant alloy, flush structural screws. Gen aircraft hardware does not sell them, but if you call them they may know who does. I spoke to D&D Aircraft Supply today. What they told me is that they try to guarrantee that their stainless screws have the same or better strength as the original cadmium plated steel structural screws. As stated above the type of stainless steel used in MS 24694 screws leaves the screw actually weaker than the original cadmium plated variety. D&D says that the stainless variety may well be strong enough and Piper might admit that but D&D's decision is to market replacement stainless kits that are known to be a direct replacement for the original cad plated steel hardware as specified by Piper, or Cessna etc. John Dupre' |
Working Stainless Steel | Bob Babcock | Home Built | 7 | February 14th 04 04:12 PM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 161 | September 25th 03 07:35 AM |
#1 Jet of World War II | Christopher | Military Aviation | 203 | September 1st 03 03:04 AM |
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 09:14 AM |
