"Sandy Mustard" wrote
If your warrior has the braided grounding strap at the battery box, I'd spring for the Bogert battery box mod also. It's about $50. Bogert is faxing the instructions to my A&P for consideration. Meanwhile, I went flying today. Same old thing, first blade fails to turn, so I let it back off and bump it again to get it over the 'hump'. This produces the usual labored rotations, but then, something new. Electrical power quit, just as if I had turned off the master switch, in mid start. Now, I had asked my A&P to check every connection for excessive voltage drop while cranking, for the purpose of ruling out other issues than the aluminum cables themselves. He indicated that the check had been performed by his 'electrical system Guru' and they had found no excessive delta V while cranking. Imagine my surprise when I inspect the positive battery terminal and find that the fastener nut is loose. After tightening, the starter spins like a top! We'll see how this holds up over time and hold off on the copper cable installation. -Bud N235PA San Diego MYF To reply via email, remove B4FLIGHT |
Bud Patterson wrote:
Imagine my surprise when I inspect the positive battery terminal and find that the fastener nut is loose. After tightening, the starter spins like a top! We'll see how this holds up over time and hold off on the copper cable installation. If that terminal has been loose for several flights, it may have been arcing a bit. You might want take it apart and clean the terminals really well. -- Jay __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino/ ! ! ! Checkout http://www.oc-adolfos.com/ for the best Italian food in Ocean City, MD and... Checkout http://www.brolow.com/ for authentic Blues music on Delmarva |
"Jay Masino" wrote
If that terminal has been loose for several flights, it may have been arcing a bit. You might want take it apart and clean the terminals really well. -- Jay Good point Jay. Thanks, -Bud |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | Home Built | 6 | October 15th 04 08:51 PM |
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | General Aviation | 0 | October 12th 04 05:11 PM |
Space Elevator | Big John | Home Built | 111 | July 21st 04 04:31 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
