"Jay Honeck" wrote in message news:ci%hb.734179$YN5.656514@sccrnsc01... | Basically, a new 2004 Cessna 182 will compete favorably with a Cirrus | SR-22, | but for about $50,000 less. | | Hmmm. I don't know what you consider "competing favorably", but the specs | sure look weighted in favor of the Cirrus: Well, OK, lets save only about $20,000 and go with the Turbo Skylane with the Nav III package (the price reduction is not yet reflected on Cessna's web site) over a similarly equipped Cirrus SR 22, remembering that the Turbo Skylane uses a 235 hp IO 540 while the Cirrus while the Cirrus has to use 310 hp, and tell me if the Cirrus airframe is really all that more efficient than that of the 182. We can also throw in a few corrected figures for the normal Skylane. | | Cruise Speed | Skylane: 141 knots Turbo Skylane 175 knots Skylane: 145 knots | Cirrus: 180 knots | | Maximum Range | Skylane: 550 nm (697 nm with optional extra fuel tanks) Turbo Skylane: 886 nm Skylane: 968 nm Cirrus: They don't say under what conditions an SR 22 will get 1000+ nm, but either they don't know or they won't admit that you could probably squeeze as much mileage out of a 182. | Cirrus: 1000+ nm | | Climb Rate | Skylane: 980 fpm Turbo Skylane: 1040 fpm Skylane: 924 fpm | Cirrus: 1400 fpm | | The only parameters the Skylane wins are for takeoff & landing distances: | | Takeoff over 50' Obstacle | Skylane: 1205 ft Turbo Skylane: 1385 ft Skylane: 1514 ft | Cirrus: 1575 ft | | Landing over 50' Obstacle | Skylane: 1350 ft. | Cirrus: 2325 ft These stay the same Useful load is better for the Cirrus: Turbo Skylane: 1095 lbs Skylane: 1213 lbs Cirrus: 1150 lbs Then there is the useful life of the airframe: Skylane and Turbo Skylane: unlimited Cirrus: 4030 hours IIRC the Skylane and Turbo Skylane both have longer TBO on their engines than the Cirrus SR 22, too. Nav III Garmin G1000 package vs. Cirrus' Garmin 430 package: um, right. I don't see enough value added in the SR22 to make it worth so much more than either Skylane. Of course, if you want to put your plane on floats or skis, you can forget about the Cirrus entirely. It may be a little unfair to mention that the 182 has one of the best safety records of anything that flies, while the Cirrus has one of the worst. Pilots are still getting used to the Cirrus' quirky handling and the fact that the plane will not recover from even an incipient spin. The parachute system has failed more often than it has worked. While we can blame Cirrus airframes coming apart in the air on improper maintenance, we know that the 182 has never had an airframe failure and almost all mechanics know how to work on them. But perhaps Cirrus will be able to work out its safety problems, given time. |
On Sat, 11 Oct 2003 22:15:36 GMT, "Jay Honeck"
wrote: Basically, a new 2004 Cessna 182 will compete favorably with a Cirrus SR-22, but for about $50,000 less. Hmmm. I don't know what you consider "competing favorably", but the specs sure look weighted in favor of the Cirrus: The Skylane wins in other categories. Efficiency, for one. At 180 knots, the SR-22 burns nearly 19 gph. I didn't think it was possible to have worse fuel economy than a 182, but Cirrus managed to do it. ![]() The Skylane's insurance prices will be cheaper. And the parts availability is better for the 182, with a lot more after market parts. More STCs. More mechanics know how to work on it. The Skylane also has better low speed numbers. Look at the flaps down stall speeds for the 182 and the SR22. It's 59 knots for the SR22, and 49 knots for the 182. The 182 cabin is also larger. I think you had the range wrong for the Skylane--it's 845 nm at 75% power. As you noted, the landing and takeoff distances are better for the 182. Much better, in some cases. Even so, the SR-22 is a very very nice aircraft. I'm not sure it's a fair comparison, though. The SR-22 has an IO-550 putting out 310 horsepower. The Skylane is only putting out 230. If you put a 310 horsepower engine in the Skylane, you'd see the airplane doing closer to 160 knots, maybe a little more with the aerodynamic improvements. Still not SR-22 speed, but a lot more comparable. The SR-20 has a smaller engine--200 hp. It still goes faster than the Skylane, but look at the useful load, and the takeoff and landing distances. It climbs slowly and runs hot. Again, I certainly would love to have one--I'm not trying to dog the Cirrus planes. But the Skylane is a good airplane that still makes sense for many people. And with the new avionics, I believe it improves the 182 that much more. I think you should be a big Skylane proponent, Jay. After all,you've wondered why New Piper doesn't put the Dakota back into production, and that's basically a low-wing equivalent for the Skylane.... --Ron |
After all,you've wondered why New Piper doesn't put the Dakota back into production, and that's basically a low-wing equivalent for the Skylane.... While that's true, I prefer the flight characteristics of the Pathfinder over the Skylane. If Piper did have the Dakota in production, and I were given a choice between it and an SR-22, the Cirrus would win, hand's down. Piper would have to put in a glass cockpit AND price the Dakota WAY lower in order to compete at all. And that won't ever happen. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
C J Campbell wrote:
It is a Garmin 1000 system with battery backup (not certified for part 135 IFR, though). So, if an aircraft has a second electrical source (among the other part 135 requirements - dual vacuum, etc), will an aircraft with this avionics configuration be certified for part 135 IFR, or is there something specific about the Garmin 1000 system that does not allow it to be certified at this time? -- Peter ----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- |
"Peter" wrote in message ... | C J Campbell wrote: | | It is a Garmin 1000 system with battery backup (not certified for part 135 | IFR, though). | | So, if an aircraft has a second electrical source (among the other part | 135 requirements - dual vacuum, etc), will an aircraft with this | avionics configuration be certified for part 135 IFR, or is there | something specific about the Garmin 1000 system that does not allow it | to be certified at this time? | The backup battery is only good for thirty minutes, and Cessna has not applied to certify the backup system for IFR. |
| Thread Tools | |
| Display Modes | |
| 1/72 Cessna 300, 400 series scale models | Ale | Owning | 3 | October 22nd 13 04:40 PM |
| Cessna buyers in So. Cal. beware ! | Bill Berle | Aviation Marketplace | 93 | December 20th 04 03:17 PM |
| Cessna 182T w. G-1000 pirep | C J Campbell | Instrument Flight Rules | 63 | July 22nd 04 08:06 PM |
| FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Aviation Marketplace | 1 | November 4th 03 01:57 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
