Hydraulic brake problems
Old March 28th 11, 10:54 AM posted to rec.aviation.soaring
Brian Liddiard
Default Hydraulic brake problems
Hi Dick.
If you have checked everything, check it again! I think Mike is going in
the right direction and you still have air in the system.
If everything is ok then try this when bleeding the system.
With two people pump the handle to get maximum pressure, your assistant
then opens the bleed nipple forcing the fluid out, hold the leaver until
the nipple is closed then slowly release the leaver, wait 30 seconds then
repeat. Hopefully you will feel it improving after 4 or 5 pumps and don't
forget to top up as you do this.
Regards
Brian
Old March 28th 11, 04:37 PM posted to rec.aviation.soaring
Andy[_1_]
On Mar 27, 9:34*am, Dick wrote:
We have sucked the system dry by vacuum applied, also to the
same nipple.
I assume you actually didn't mean that since sucking the system dry
ensures that it is totally filled with air unless you used a high
vacuum pump.
Getting a high flow rate using either suction or pressure usually
works but you need a fluid reservoir large enough to sustain the
flow. My PA28-180 has 5 master cylinders and 2 slave cylinders and is
a real bitch to bleed after the system has been opened. I used a pump
up garden sprayer to feed fluid to the caliper bleed nipples and used
a large bottle to catch the overflow from the reservoir.
So far I've had no problem with the hydraulic brake on my 28 so no
experience with that yet.
Andy
Old March 28th 11, 04:50 PM posted to rec.aviation.soaring
Grider Pirate
same nipple.
vacuum pump.
flow. *My PA28-180 has 5 master cylinders and 2 slave cylinders and is
a real bitch to bleed after the system has been opened. *I used a pump
Andy
3U hit the nail on the head for 'cause'. Automotive brake fluid, used
as we do (infrequently, by automotive standards) really needs to be
fully cycled out annually to prevent excessive water absorbtion and
the attendant corrosion. I've been changing out brake fluild in my
cars on a bi-annual basis since the 70's, and haven't had to replace
or rebuild a caliper, slave, or master cylinder since that time (and I
tend to keep vehicles for decades).
Old March 28th 11, 09:54 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
On 3/28/2011 7:50 AM, Grider Pirate wrote:
On Mar 28, 7:37 am, wrote:
same nipple.
vacuum pump.
Andy
This sounds like you think all our Cleveland brake systems use
automotive brake fluid. Just in case you or someone else thinks that,
let me mention my ASH 26E maintenance manual is adamant "that only
MINERAL OIL BASED" brake fluid is used in it's Cleveland system, and
definitely NOT automotive fluid, which "will quickly destroy gaskets and
hoses".
So, always check your manual first.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old March 29th 11, 05:35 AM posted to rec.aviation.soaring
Andy[_1_]
On Mar 28, 7:37 am, *wrote:
same nipple.
vacuum pump.
Andy
hoses".
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarmhttp://tinyurl.com/yb3xywl
Same for the ASW-28. I know some glider manufacturers chose to abuse
a perfectly good aircraft braking system by use of auto style brake
fluids but not all of them did.
Andy
Old March 29th 11, 07:31 AM posted to rec.aviation.soaring
bumper[_4_]
The Cleveland caliper was originally intended for use with Mil Spec
5606 brake fluid (the red petroleum based stuff). The caliper piston
was plain aluminum and the O-ring and seals Buna-N.
When using automotive brake fluid, as some glider manufacturers do, O-
rings and seals are changed to EPDM rubber. The hygroscopic nature of
automotive brake fluid can cause corrosion of the caliper piston and
bore. Later Cleveland pistons (late 90's ?)were anodized* (relatively
easy to do aftermarket as well) and this, along with brass lining the
caliper bore, eleminates further problems. http://www.brakecylinder.com/
does a good job brass lining bores.
*Easy to check to see if your piston is anodized. Touch the leads of
an ohm meter to the piston. If it's anodized, it won't conduct as the
anodize (aluminum oxide) layer is an insulator.
As someone previously mentioned, it's important to insure the caliper
hose inlet is at the top while bleeding. If you have to dismount the
caliper, use a C-clamp or similar to hold piston in while bleeding. I
recommend a pressure pot (one can be cobbled together from a small
garden sprayer) to get a good robust flow going. This will remove air
trapped in any high spots in the plumbing.
bumper
Bleeding LS4 wheel brake hydraulic system David Starer[_3_] Soaring 1 April 3rd 10 05:06 PM
hydraulic brake actuation Brad[_2_] Soaring 15 January 9th 09 06:46 AM
Hydraulic trailer surge brakes means no parking brake? [email protected] Soaring 11 March 18th 08 05:19 AM
Hydraulic Pump [email protected] General Aviation 2 March 28th 06 06:09 AM
AP: Navy Jet Has Severe Brake Problems Otis Willie Naval Aviation 0 August 6th 05 01:20 AM
