![]() "Colin Kingsbury" wrote: I'm contemplating two options: Easy: 2. Replace with an IFR GPS/Com. If you fly much IFR in most parts of the country, this is becoming a must, anyway. And if I were you, I'd find a factory recon'd Garmin 430 and make it the #1 NAV/COM. -- Dan C172RG at BFM |
I got a 530 for the 430 price. The shop I use in TN quoted a price for a
430 or 530. The shop I bought the plane thru quoted the 530 in NC at the TN 430 price. 3 guesses on which one I have. I wonder how many reconditioned 530's there are b/c of the newer 530A (higher watt output) being exchanged. -- Thx, {|;-) Victor J. (Jim) Osborne, Jr. take off my shoes to reply |
![]() From what I can tell a GNS-430 (even used) installed will cost around double what a GNC-250xl or UPSAT setup would go for. Considering this is a 50k Skyhawk we're talking about... The only thing I don't like about going this route is losing the second LOC. Of course if I did a 430 rig I'd have double NAVs again... grumble... That's why they calls them "choices." -cwk. "Victor J. Osborne, Jr." wrote in message ... I got a 530 for the 430 price. The shop I use in TN quoted a price for a 430 or 530. The shop I bought the plane thru quoted the 530 in NC at the TN 430 price. 3 guesses on which one I have. I wonder how many reconditioned 530's there are b/c of the newer 530A (higher watt output) being exchanged. -- Thx, {|;-) Victor J. (Jim) Osborne, Jr. take off my shoes to reply |
"Colin Kingsbury" wrote in message link.net...
From what I can tell a GNS-430 (even used) installed will cost around double what a GNC-250xl or UPSAT setup would go for. One thing to consider with UPSAT is how the AFM is written. The UPSAT line reads "the user must verify that approach data is current" The Garmins AFAIK read "the database must be current" Pricy little distinction there. The only thing I don't like about going this route is losing the second LOC. The IFR GPS isn't a bad backup for the loc in practice. Slap "nrst" and choose the LOM or intersection. Input the FAC. Make sure your CDI is set to the most sensitive setting. It's not quite as sensitive as the LOC becomes near DH but it's a good backup. Cheers, Sydney |
I'm contemplating two options: 1. Replace with a slide-in replacement like the TKM series, which will get me a new box and standby freqs (woo-hoo!) Anybody here have those, or suggest others? Advantage here is v. low cost to install versus something like a KX-155 upgrade which would require rewiring, etc. I replaced broken Narco COM121 (or is it 122?) junk with TKM MX11R. Been happy with the choice so far (3 years). This was probably my cheapest option involving new equipment. It's a slide-in replacement, but in my case unlike yours it's com-only (no nav). Jim Rosinski N3825Q |
![]() "Colin Kingsbury" wrote in message news ![]() Because a topic like this never gets too old ![]() 1979 172 with original Cessna (RT-385 IIRC?) radios, the NAV frq display on the #1 box failed and the partners now finally agree it's not worth repairing. I've got a 78 with the same radio. Three years ago the display driver died (also had a few segments burned out). The total tab including changing a few electrolytic caps that were drying out (resulting in low audio volume) was about $175. The radio operates very well now. This was the second time in over 20 years it was in the shop....not great...but not too bad either. So is it really not worth repairing? Of course a new panel would be very nice.... John Severyn LVK N24495 |
![]() 1979 172 with original Cessna (RT-385 IIRC?) radios, the NAV frq display on the #1 box failed and the partners now finally agree it's not worth repairing. I'm contemplating two options: 1. Replace with a slide-in replacement like the TKM series, which will get me a new box and standby freqs (woo-hoo!) Anybody here have those, or suggest others? Advantage here is v. low cost to install versus something like a KX-155 upgrade which would require rewiring, etc. 2. Replace with an IFR GPS/Com. This addresses ADF/DME, but costs us one VOR. I don't think people will go for buying a second nav/com as well so it needs to be a one-box upgrade. Current stack has 2x Nav/Com, 1x ADF, 1x Mode C, Audio panel w/ marker beacon, and an M1 Loran, all original equipment. The audio panel's getting fussy and the ADF won't lock on to the lower-powered beacons until you're on top of them. If it was up to me I'd yank it all but I've got 4 other guys who fly less and almost never fly IFR so they're less picky. Best, Hi, I had a similar dilemma with an upgrade to factory original '76 Cardinal (with a "NavPack II", no less!) I think this comes down to what you are trying to accomplish: if you simply want to rectify a current problem, you have two choices: get another RT-385 ($500-700, may not be the end of it, though) or an MX-385 ($1500 but will likely last a while). If you are using the current situation as an excuse to gain more capability (nothing wrong with that !), then you have to go to an IFR GPS, KX-155's won't let you do an approach or go direct any more than the old ARC radio. Now you are talking some serious dough, however: your -385 may channel a remote glideslope, so that will have to be re-done or moved around to the #2 spot. Otherwise, your "one box" is basically starting to look like a Garmin 430, a $10K+ venture. Legal hair splitting aside, in practical terms, the GPS does fully replace ADF/DME, but you definitely want to keep a VHF glideslope for now, the GPS won't get you as low when it counts. I ended up replacing both RT-328T's with newish MX-300's I bought on ebay, net cost after selling the cores was about $1100 for both units, but this was perhaps an unusually good deal. If I had the $$$ I would go the GPS/Com route, but *I* honestly don't need the capability right now, I don't fly regularly anywhere that's only served by a GPS approach, and cross-country flight around here usually means terrain where the airways represent the only sane route in IMC anyway. But if you fly over to grandma's every Sunday and the airport only has a GPS approach, the cost/benefit equation changes significantly, no doubt about it. Martin |
1979 172 with original Cessna (RT-385 IIRC?) radios, the NAV frq display on the #1 box failed and the partners now finally agree it's not worth repairing. 1. Replace with a slide-in replacement like the TKM series, which will get me a new box and standby freqs (woo-hoo!) No question this would be the cheapest alternative. I have a TKM 170B (slide-in replacement). I know others who have slide-in replacements for the Cessna TKM radios. Generally we're happy with it. It is lower-power than our KX170B; ATC will lose our tranmissions on the MX at distances where we're fine on the KX. The nav radio is fine. Caveat: our other nav/com is the same wiring harness. Thus we were able to swap slots and determine that the antenna and wiring harness were not problematic. If you can do this, fine. If you can't, I would try to get your avionics guy or a fellow Cessna owner to loan you a radio and test the wiring/antenna splitter etc. I know people who say the TKM radios are junk, and I think actually their problem is elsewhere in the system. Don't overlook the issue that you ARE reusing the wiring/antenna etc. 2. Replace with an IFR GPS/Com. This addresses ADF/DME, but costs us one VOR. I don't think people will go for buying a second nav/com as well so it needs to be a one-box upgrade. There's no question that this would get you the most increase in capability. Depending upon where you fly, an approach certified IFR GPS is a real boon. And, if your ADF is flaky, this might even be the most cost-effective alternative, better than repairing/replacing the ADF AND the nav. The GPS can serve as a 2nd VOR just fine -- it will give you more precise identification of intersections as well as a legal substitute for DME and NDB. The flaky audio panel might be a wiring issue. Again, if you can find someone w/ the same make and model, simplest thing to do is to swap it. While yours is out, just look it over with a multitester for signs of bad connections etc. Hit the pins with tuner cleaner and reseat a few times. A little TLC definately improves the performance of old avionics. Cheers, Sydney |
Snowbird wrote:
: I know people who say the TKM radios are junk, and I think actually : their problem is elsewhere in the system. Don't overlook the issue : that you ARE reusing the wiring/antenna etc. Having seen the inside of one, I can say that they are built more like personal computers than middle-aged avionics (like a KX-170B). The old King units are solid, well-potted inside, and built with bullet-proof guts. Their breakage problems are typically dried up caps, cold solder joints from thermal cycles, and physical wearing of switches, etc. The TKM radios have standard ribbon cables, connectors, DIP chips (often socketed)... all of which makes them cheap to build. In a high-vibration environment, however, that can potentially cause more problems with fatigue, chafing, and oxidizing of sockets, in addition to the problems with the old brick-sh!thouse radios. That said, I think you're right that most people with bad experiences with slide-in replacements had bad wiring to begin with. That's the most likely culprit of most avionics problems. -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
their problem is elsewhere in the system. Don't overlook the issue that you ARE reusing the wiring/antenna etc. Avionics shops also regularly badmouth TKM, for obvious reasons... |
1/72 Cessna 300, 400 series scale models | Ale | Owning | 3 | October 22nd 13 03:40 PM |
Cessna buyers in So. Cal. beware ! | Bill Berle | Home Built | 73 | June 25th 04 04:53 AM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Aviation Marketplace | 1 | November 4th 03 12:57 AM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Owning | 1 | November 4th 03 12:57 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
