Critical Contest Safety Procedures Checklist
Old April 13th 11, 07:56 PM posted to rec.aviation.soaring
Mike the Strike
Default Critical Contest Safety Procedures Checklist
On Apr 13, 9:58*am, ContestID67 wrote:
Great document. *Thanks.
Concerning "Spratt guidelines of 2500’ AGL to launch, 3300’ AGL to
start, should be followed unless there is a good reason."
This is ambiguous as to what is being referenced for the AGL height.
Cloudbase? *Critical updraft height? *BL height? *Sniffer max height?
Beer fumes from the bacchanalia the night before? *;-)
Thanks.
I'm pretty sure this is top of the lift actually achieved by gliders
in the air. 3300 ft AGL is probably workable for many eastern sites
and possibly Hobbs but I would hesitate to start a task in Arizona
this low. Contestants are likely to be soon on the ground at local
strips or eating cactus! I personally would recommend a minimum of
5,000 ft AGL here.
Old April 13th 11, 08:32 PM posted to rec.aviation.soaring
Thanks.
this low. *Contestants are likely to be soon on the ground at local
strips or eating cactus! *I personally would recommend a minimum of
5,000 ft AGL here.
Spratt 2500 to launch is derived from a "standard" 2000 ft AGL tow
and, of course, we don't fly closer than 500 vertically from clouds.
3300 AGL is min recommended to open task. That does not say CD and
advisors must open at that. Local situations may dictate higher.
Example in the East- at new Castle 3300 above airport is only 800 or
so above some important local terrain. as result, the "go" there is
set higher.
I hope this clarifies a bit.
UH
Old April 13th 11, 10:18 PM posted to rec.aviation.soaring
Andy[_1_]
Thanks.
I think the amswers are - launch if sniffer reports reaching 2,500agl
and Task open if task adviser in that class reports reaching 3,300
agl.
The CD may, or may not, ask other pilots what height they have
achieved before opening the task. Who is asked may depend on who was
nice to the CD the evening before.
Andy
Old April 13th 11, 10:30 PM posted to rec.aviation.soaring
Tony[_5_]
5,000 ft AGL here.
just because the task is open doesn't mean you have to start, right?
Old April 14th 11, 03:04 AM posted to rec.aviation.soaring
mattm[_2_]
5,000 ft AGL here.
Right; check your rules. The gate doesn't actually close until local
sunset.
-- Matt
Old April 14th 11, 10:21 PM posted to rec.aviation.soaring
ContestID67[_2_]
So the "Spratt" (God rest his soul) line might be changed to;
OLD: "Spratt guidelines of 2500’ AGL to launch, 3300’ AGL to start,
NEW: "Spratt guidelines of sniffer reporting 2500’ AGL to launch,
contestants/sniffer reporting 3300’ AGL to start, should be followed
unless there is a good reason for higher minimums."
Old April 15th 11, 04:58 PM posted to rec.aviation.soaring
John Cochrane[_2_]
This is not a rule, it's a guideline, and "unless there is a good
reason" is there for a reason! Yes, if you're in the boondocks, set a
higher limit. If you're in extremely hospitable farm country and have
a small number of gliders at the contest, lower limits are
appropriate.
The main point is, it is good practice to set some sort of
quantitative guidance for launch and task open in any given contest,
and at least consider it while making these tough decisions.
John Cochrane
USA / The Soaring Safety Foundation (SSF) Safety Seminars 2008 [email protected] Soaring 0 November 8th 07 11:15 PM
A Critical Evaluation of the F22 john smith[_2_] Piloting 10 May 27th 07 06:02 AM
FOR ALL SAFETY AND HUMAN LIFE CRITICAL FUNCTIONS IN THE,UNITED STATESGOVERNMENT BiffClinton Piloting 2 May 4th 07 01:41 AM
The Soaring Safety Foundation (SSF) Safety Seminars Hit The Road in the USA [email protected] Soaring 0 September 11th 06 03:48 AM
Contest Safety birddog bob Soaring 32 August 15th 05 01:00 AM
