Yes, absolutely, that was my measure. One of my cars
has an electrical fault which runs down the battery in a few days, so it's a good test! :-) Haven't had time to track down the fault yet. Another I let run on empty for a while as I was abroad for a few months a couple of years ago. I thought I was going to be back so I didn't disconnect the battery. They stopped the flights home! So. I came back four months later to a completely dead battery. Normal charging did nothing, it wouldn't keep a charge. I bought a new battery and put the old one on trickle charge for a few weeks (!) after which it was as good as the new one. Paul "Stu Gotts" wrote in message ... The batteries may have come up in voltage, but were they able to take a load and bounce back in a reasonable amount of time? |
On Thu, 20 Nov 2003 21:05:24 GMT, "Mike Rapoport"
wrote: I have recently converted from NiCad to lead acid batteries which are supped to have a life of 2-3 yrs. The batteries cost about $1500 for the pair and I am interested in maximizing their life the extent practical. I have heard about "pulse chargers" that reportedly reduce sulfate on the battery plates. Would using one of these make a meaningful difference in battery life? I plan to connect the charger through the external power recepticle. Any thoughts/ideas/sources? I am also interested in a larger source of DC power so that I can use the cabin lights and have things turned on while cleaning/troubleshooting ect. Again I plan to connect through the external power recepticle. I ahve 120V and 240V availible. I am not looking to spend $000s on a GPU type cart. Thanks for any input! Mike MU-2 I read this and thought I was on the Homepower NG g. I don't know how well the pulse chargers will work on starting type batteries. They are helpful for deep discharge cells, though. For the type of battery you have, they are designed for starting. They can produce a large amount of current for a short period of time. However, they are NOT designed to be deep discharged. So you should take care not to discharge them to any lower than about 20%. In other words, they should always retain at least 80% of their full state of charge, and be maintained at full charge as often as practical -- certainly at least every two weeks. If you are going to run cabin lights and other appliances for any length of time, you really should be using deep discharge batteries. These can tolerate repeated 80% depth of discharge (DOD). Depending on your power requirements (which can be calculated), you may be able to use second hand fork lift or golf cart batteries. These are available inexpensively through Sam's and other discount places, as well as at battery dealers. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
| Thread Tools | |
| Display Modes | |
| RG Battery Charger by Jim Weir in Kitplanes | Kevin O'Brien | Home Built | 4 | January 6th 05 02:19 AM |
| Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 04:07 PM |
| Battery Requirements | jgarner | Home Built | 3 | March 28th 04 07:32 AM |
| FS: Yaesu VXA-100 "Aviator Pilot" Alkaline Battery Case, $20 obo | Jaysen Underhill | General Aviation | 0 | September 3rd 03 06:35 AM |
| WX1000 Stormscope battery | D. J. Gooding | Owning | 2 | August 9th 03 03:25 AM |
