Piper Commanche vs Money 201
Old November 22nd 03, 08:27 PM
Chris Kennedy
Stu Gotts wrote:
I guess these claims are correct. I was referring to a no tail wind
situation!!!
So are we. Actually, to be precise in my case, the average speed seen
by flying reciprocal courses to factor wind out of the equation I don't
see any reason to hang an after market mod on the airframe if it doesn't
demonstrate a performance improvement, so if something goes on and
doesn't deliver it comes off again (rudder gap seals come to mind).
It's perfectly possible to make a PA24-250/260 cruise at or above
200MPH, but doing so requires tossing the factory cowl and demands the
Vne stabilator mod that most people haven't bothered to perform.
Old November 22nd 03, 09:22 PM
Jeff
I am referring to no tail wind also.
My t-arrow gets 150-155 KTAS - Not ground speed, and this is at 65% power. 3 days
ago, at 14,000 ft, I had a TAS of 160 kts and a GS of 183 kts.
Everyone I know who flies a t-arrow flight plans at least 150 kts.
Jeff
http://www.turboarrow3.com
Stu Gotts wrote:
On Fri, 21 Nov 2003 23:16:33 -0800, Jeff wrote:
I know a guy with a comanche 260, really nice plane, fast, good useful load.
his will do 160 kts.
Heck my 200 HP Turbo Arrow III typically does 150-155 kts.
situation!!!
Jeff
Stu Gotts wrote:
On Fri, 21 Nov 2003 17:23:27 -0600, "O. Sami Saydjari"
I am looking at buying one of two planes: a 1978 Mooney M20J or a 1965
Piper Commanche PA-24-260. I have test driven both and I like the
handling of both. Both are about the same price. The avionics in the
Mooney are slightly better. This is a tough choice.
(1) Is there anyone out there that has flown both airplanes extensively
and can give me pros and cons of each from their perspective?
(2) Is there any other plane with similar price/performance capabilities
(cruise at better than 160nts, 750+ range) in the same price range
($75K-$100K) that I should consider?
(3) I heard Mooney is teetering on bankruptcy. Is this a real big
downside? Has anyone experienced owning a plane with a manufacturer
went bankrupt. Do parts become impossible to find?
-Sami
1. Bonanza - there is no substitute.
2. Those speeds are vaporware, you'll never see them from either
machine.
3. Mooney seems to be emerging from their financial troubles, and
believe it or not, may own Beechcraft soon. Comanche parts are
becoming a bit difficult to find and added to the fact that the
aircraft is no being produced worries me. Also, a good Comanche
mechanic is a must if you want to keep the aircraft in the air. Good
luck.
Old November 22nd 03, 09:26 PM
Jeff
Your more then welcome to see the performance specs for a T-arrow, they are here
http://www.turboarrow3.com/newplane/specs.html
those are the book values tho and I havnt seen their speeds yet but I only fly at
65% power settings.
Jeff
situation!!!
Jeff
-Sami
machine.
luck.
Old November 22nd 03, 11:17 PM
Tom S.
"Jeff" wrote in message
are here
fly at
65% power settings.
Jeff
Have you/are you going to install GAMI turbo injectors in that thing?
Old November 23rd 03, 12:10 AM
Jeff
I have GamiJectors, wing root fairings, gap seals installed already.
a week ago I had new avionics installed. garmin 430, audio panel, garmin
x-ponder and some other stuff. Wanted the MX20 but that will have to wait
another 6 months.
The gamiJectors say you can run lean of peak, but when I tried it, I seemed to
lose some airspeed, so I lean to 12 gph which is just a tiny bit ROP, thats
seems to be the best mixture setting for me.
are here
fly at
65% power settings.
Jeff
Old November 23rd 03, 01:00 AM
Stu Gotts
Okay, I certainly believe you! ;-)
Jeff
situation!!!
Jeff
-Sami
machine.
luck.
Old November 23rd 03, 01:05 AM
Stu Gotts
Ahem!!!!
another 6 months.
are here
fly at
65% power settings.
Jeff
Old November 23rd 03, 01:06 AM
O. Sami Saydjari
Ben, thank you so much. Your answer has been most helpful!
-sami
I considered buying a Mooney (J or upgraded F) for a long time, but
I ended up buying a 1965 PA-24-260. I've climbed all over an M20J,
and flown one for about an hour. I've got about 50 hours now in PA-24s.
Here are some tradeoffs I can think of:
The Mooney cruises faster.
The Comanche climbs faster.
The Comanche has much more interior room and carries a greater load.
The Comanche's baggage area is more accessible, especially in 260B+
models.
I'm 6'4" and fit in both. The Mooney does it with a lot of legroom
under the instrument panel, while the Comanche has a more typical
upright seating posture.
The Mooney has only 2/3rds as many cylinders to maintain.
The Comanche doesn't have cowl flaps (unless retrofitted with an
aftermarket cowling that requires them) or ram-air (though the M20J
doesn't *need* the ram air as much as the F did).
The Comanche's systems are easier to reach, in general. For example,
the original cowling has two large doors. In contrast, the Mooney is
"build around" some of the flight control torque tubes and avoinics
access may have to be through a panel on the cowling.
Both have reliable gear systems and simple mechanical manual extension
systems. The Mooney's can be tested in flight and then retracted
electrically. The Comanche technically has to be on jacks after a
manual extension, though some claim to do it while airborn.
The Mooney uses shock absorbing pucks of rubber in a trailing-link
configuration, while the Comanche uses struts.
The Comanche has greater prop clearance as well as the better shock
absorbing which makes it more suitable for unimproved strips (though
to be fair some Mooneys regulary fly out of such strips, and neither
is as versatile as a C182, or for that matter a Cub).
The Mooney's landing light is in the cowling, the Comanche's are in
the wings.
The Mooney has an all-flying tail (trim pivots the entire thing) while
the Comanche has a stabilator. Both have very positive trim control at
cruise. The travel on the trim control is excessive at low speeds in
the Comanche, IMO. I haven't flown the M20J enough to recall.
The Mooney has a wet wing which is prone to sealing problems (some have
been retrofitted with bladders which reduce capacity a little and
are better at trapping water) while the Comanche has bladders which
can develop leaks (especially if tied down in the sun without full
fuel). If the Comanche's bladders are original they're also very old.
Most Comanches carry more fuel than most Mooneys, but also need it to
get the same range (~13gph vs ~10gph). You can probably go a little
farther (far far beyond my endurance!) in a 86gal (usable) Mooney than
a 64gal M20J, and there are Comanches with tip tanks for a total of
116gal usable.
Old Mooneys and Comanches both have atrocious panels. Some newer
Mooneys have very nice panels. Some of both have been retrofitted.
It does make them hard to compare. Well equipped examples of both
are available, you just have to shop harder for a Comanche.
Both have a loyal following of owners.
Both were made by companies which have "gone out of business" several
times, but parts availability is still reasonably good for both.
Maybe the Commander 112/114/115. I didn't really hear anything about
them until after I bought my plane, though.
Old November 23rd 03, 01:08 AM
Stu Gotts
On Sat, 22 Nov 2003 06:25:31 -0700, "Tom S."
And the Commander Aircraft Comp. is just about out of business, too. I was
thinking of a 114B recently, but declined when I was made aware of their
financial situation. It might disrupt replacement parts and it might not.
I'd hate to find out the hard way, though.
Now, instead, I'm about 95% sure I'll be picking up an F33A right after New
Years.
That's the spirit! You'll go farther and faster more comfortably on
less fuel, and won't have to worry about stretching the numbers when
bragging to your friends. Good man!
Old November 23rd 03, 03:04 AM
Jeff
LOL...Stu you kill me.
what plane do you own..just out of curiousty...
you know there ways to see the book performance on any airplane, like the f33
is here
http://www.risingup.com/planespecs/i...plane116.shtml
its not that fast of an airplane.
how much money have you lost on the lottery? NOW GET THAT MONEY BACK! shane Home Built 0 February 5th 05 07:54 AM
Start receiving MONEY with this simple system. Guaranteed. Mr Anderson Aviation Marketplace 0 February 2nd 04 11:55 PM
