On May 12, 2:18*pm, John Cochrane
wrote: "The Future of rules and classes." This one is published (in German) in this month's Segelfliegen. If you don't speak German (like me), here's the English version http://faculty.chicagobooth.edu/john...Papers/future_... or, more generallyhttp://faculty.chicagobooth.edu/john.cochrane/research/Papers/#misc Ok, this is the last one for a while. John Cochrane As usual, John, a great article. Just one minor nitpick - Top Gun is Navy, not Air Force (AF has the Weapons School, and Red Flag). And the hard deck (it was 10,000' when I flew in F-4s, it's 8000' now for F-15s, I think, due to their better dive recovery capabilities) is in use throughout the Air Force and Navy, and probably all other airforces when practicing air-to-air combat. As you say, it's the simulated ground, so if you punch through it during a fight - you lose. Of course, if you can sucker the guy chasing you below it, he loses! I still think we need to work on some aspects of our starts and finishes. The altitude limit means that on a good day, we have several gliders running around at high speed/high G winding up to pop up through the top when the gate opens or the 2 minutes are up. It shouldn't happen ("why the rush") but it still does. Not sure how to fix this. And the finishes still require too much clock-watching. I do not want to be staring at my altimeter on final glide - I want to be looking out the window! We are getting better with the graduated penalty if below the finish height - ideally it should be a finish window that is points-neutral within a reasonable altitude spread (if lower, then subtract points - or add time - equal to the time that would have been spent in the last thermal to get the height needed, for example). Cheers, Kirk 66 |
snip
*We are getting better with the graduated penalty if below the finish height - ideally it should be a finish window that is points-neutral within a reasonable altitude spread (if lower, then subtract points - or add time - equal to the time that would have been spent in the last thermal to get the height needed, for example). Cheers, Kirk 66 The points neutral window is an interesting idea. Probably requires a bit more number crunching than I am up to but the idea of adding a few points for coming in higher i.e. reverse low finish penalty might have have some merit. The idea being that finishing anywhere within say a 1000 ft altitude window should give you about the same points would like you say be ideal. My concern is that what we would like to be a simple solution starts becoming complex. The strength of the last thermal would probably have an effect on if you should finish High or Low in the window for best points. The scoring software could come up with the points adjustment based on the actual last thermal, but then it becomes very difficult to determine how to write the rule for it and how to determining how you actually scored becomes even more complex. We already complain that it is hard to determine our speeds as it is. It would probably work, but like the adding 15minutes to the time on course rule we tried, we probably wouldn't like it much. Brian HP16T |
new Soaring article | John Cochrane[_2_] | Soaring | 34 | May 18th 11 03:04 PM |
NYT soaring article | Bullwinkle | Soaring | 1 | September 22nd 07 02:15 PM |
NYT Soaring Article | C Koenig | Soaring | 0 | September 21st 07 02:11 PM |
Good Article on Soaring | Jim Vincent | Soaring | 3 | June 27th 06 04:42 PM |
Soaring Article | Mike | Soaring | 1 | June 30th 05 12:58 AM |
