Plug in voltmeter
Old December 27th 03, 02:28 AM
mah
Joining this in mid-thread as an interested onlooker.
Was working a similar problem on my van recently. I'd see a difference
of 1.5 volts depending on where I tapped into the circuit, the ground
location, and load in the system.
That's the one item, load, not mentioned in the previous posts. When
I'd fire up my gps, laptop, and cell phone charger the voltage on that
circuit would become 12.2 volts while it read 13.5 at the battery.
Be thinking of what load you are drawing as the voltage will drop as it
pushes more amps down the wire.
MAH
Old December 27th 03, 01:00 PM
Rich
Yep... that's the issue. I'm attempting to use the readings on the JPI
and the Davtron to ascertain the condition AT THE BATTERY. Because of
these differences (probably due to different grounds; maybe due to
voltage drop from main bus to avionics bus), I need some way to
calibrate JPI readings to battery voltage; best easy way for me is to
measure the main bus, at the cigar lighter.
I got the plug in voltmeter and calibrated it using the HP power supply
and a real nice digital shop multimeter. To my surprise, the plug in
unit was VERY accurate... right on below 10 volts, and maybe 0.1 low at
12 volts (some lag, though... a second or two to stabilise).
Sufficiently close for my purposes.
Too busy (Christmas) and too cold (Michigan) to check it out right now.
Further reports to follow.
Rich
MAH
Old December 18th 03, 09:42 PM
mikem
Bob wrote:
Anybody know of a reasonably priced gadget that will let me monitor the
MAIN bus feeding the cigarette lighter?
If you connect a third voltmeter, you will now have three different
readings. Which are you going to believe? It like wearing three watches,
which one is "closest" to the correct time?
The only thing that really matters is what is the voltage at the battery
terminals. If your batteries are lasting more than three years, and as
long as the starter consistently cranks, then the voltage cant be
too far off.
If you are not consistanly adding water to the battery, then your bus
voltage is not too high.
If your starter is not laboring, and your airplane starts consistantly,
then your bus voltage is not too low.
The "acid test" (pun intended) is to check the Specific Gravity of the
battery with a hydrometer.
MikeM
Skylane '1MM
Pacer '00Z
Helicopter headset plug - help needed NewsGroups Home Built 4 September 8th 04 05:21 PM
Hubble plug to be pulled John Carrier Military Aviation 33 March 19th 04 04:19 AM
OV-10A Bronco Shameless ebay plug DavidG35 Military Aviation 0 November 7th 03 06:17 AM
WTB: Turbine ignition exciter unit, single plug Juan E Jimenez Aviation Marketplace 0 August 25th 03 12:48 AM
spark plug question Bill T. Owning 0 July 3rd 03 07:08 PM
