On Jun 3, 1:50*am, Chris Donovan wrote:
On May 17, 9:52*pm, Blake Miller wrote: Thanks to all for such thoughtful responses. Blake I was stuck once...without 501 or some of the other products...used crest, didn't have a choice, bad hazing right in front driving me nuts...took about 6 hours over two days for a section about 12 x 12 inch's...still looks great...not for the feighnt of heart. years later tried the headlight stuff...all of em...not worth the time of day based on the results a month later. Found out the headlight cleaners spread various chemicals and acylics...crest just filled with "marble" dust from some place in Vermont...would trust the crest approach before I would use the headlight things again. Check out sportys or the pilot shop for the complete list of products...know in advance the three step products use crest... ![]() water and clean rags, a steady supply of clean rags ...I can not emphasise enough... clean rags. *Be very, very, carefull with the products that rely on the foam cups and pads, just don't work as well. It is so easy to make things worse with micromesh esp the pro kit and a hand drill or power tool...learned from experience. Sonata or whatever ...just as easy to use clean rags and use the rag once...I mean for one wipe... till all the surface stuff is gone. then start in with some joy or something really really mild, till the second layer of crud is gone...I guess my main point here is NO shortcuts and any product that says fast in the literature...run away from. *Good luck. You guys seem to have confused the Meguiars PlastX I mentioned above for the old school Mirror Glaze products. PlastX is a polish, i.e. abrasive, silica gel by the look/smell/feel of it, in the same family as 3M "Finesse It" see here http://www.meguiarsdirect.com/detail/MEG+G12310. |
On May 17, 9:52*pm, Blake Miller wrote: Thanks to all for such thoughtful responses. Blake I was stuck once...without 501 or some of the other products...used crest, didn't have a choice, bad hazing right in front driving me nuts...took about 6 hours over two days for a section about 12 x 12 inch's...still looks great...not for the feighnt of heart. years later tried the headlight stuff...all of em...not worth the time of day based on the results a month later. Found out the headlight cleaners spread various chemicals and acylics...crest just filled with "marble" dust from some place in Vermont...would trust the crest approach before I would use the headlight things again. Check out sportys or the pilot shop for the complete list of products...know in advance the three step products use crest... ![]() water and clean rags, a steady supply of clean rags ...I can not emphasise enough... clean rags. *Be very, very, carefull with the products that rely on the foam cups and pads, just don't work as well. It is so easy to make things worse with micromesh esp the pro kit and a hand drill or power tool...learned from experience. Sonata or whatever ...just as easy to use clean rags and use the rag once...I mean for one wipe... till all the surface stuff is gone. then start in with some joy or something really really mild, till the second layer of crud is gone...I guess my main point here is NO shortcuts and any product that says fast in the literature...run away from. *Good luck. If it's a disaster see the EAA video...I checked and the crest toothpast is about 5000 - 10000 grit,... but boy does it take a long time... |
"Chris Donovan" wrote in message
: On Jun 3, 1:50*am, Chris Donovan wrote: On May 17, 9:52*pm, Blake Miller wrote: Thanks to all for such thoughtful responses. Blake I was stuck once...without 501 or some of the other products...used crest, didn't have a choice, bad hazing right in front driving me nuts...took about 6 hours over two days for a section about 12 x 12 inch's...still looks great...not for the feighnt of heart. years later tried the headlight stuff...all of em...not worth the time of day based on the results a month later. Found out the headlight cleaners spread various chemicals and acylics...crest just filled with "marble" dust from some place in Vermont...would trust the crest approach before I would use the headlight things again. Check out sportys or the pilot shop for the complete list of products...know in advance the three step products use crest... ![]() water and clean rags, a steady supply of clean rags ...I can not emphasise enough... clean rags. *Be very, very, carefull with the products that rely on the foam cups and pads, just don't work as well. It is so easy to make things worse with micromesh esp the pro kit and a hand drill or power tool...learned from experience. Sonata or whatever ...just as easy to use clean rags and use the rag once...I mean for one wipe... till all the surface stuff is gone. then start in with some joy or something really really mild, till the second layer of crud is gone...I guess my main point here is NO shortcuts and any product that says fast in the literature...run away from. *Good luck. If it's a disaster see the EAA video...I checked and the crest toothpast is about 5000 - 10000 grit,... but boy does it take a long time... I just refinished some badly hazed headlights last week (about 80 sq. inches each) with Mothers PowerBall 4Lights Headlight Restoration Kit. Dead simple to use. Just abrade with the 4 stages of abrasive pads and then polish with the foam ball and special polishing liquid. Took maybe 10 minutes total time per headlight!!! Looks perfect. Would not hesitate to use on a glider canopy. My $0.02 Larry |
Airbus 380 and White Knight 2 at Oshkosh - July 31 2009 White Knight 2 on July 31 02.JPG (1/1) | Just Plane Noise[_2_] | Aviation Photos | 2 | August 1st 09 07:56 PM |
Airbus 380 and White Knight 2 at Oshkosh - July 31 2009 White Knight 2 on July 31 01.JPG (1/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | August 1st 09 01:43 AM |
How to Remove Piston from Cylinder | Paul Dow (Remove Caps in mail address) | Owning | 20 | October 6th 08 10:01 PM |
Remove references etc... | Andy Davey | Soaring | 0 | October 24th 04 10:49 PM |
White over white is alright? | Ron Natalie | Piloting | 3 | July 16th 03 05:24 PM |
