#11
On May 17, 1:05*pm, Tony wrote:
On May 17, 12:47*pm, "kirk.stant" wrote: On May 17, 11:53*am, Jim wrote: I have a friend looking at rebuilding an IS-29 lark. Are parts available? Does it have a life limit like the 28? Thanks, Jim Not sure if parts are available (though Blanik parts may fit in some cases) but it definitely has a life limit, and a factory approved inspection method for life extension. Kirk really? i found a pdf of the flight and maintenance manual online as well as the faa type certificate and didn't see anything about a life limit. *there are no AD's against the IS-29 that I can find in the FAA database. My mistake, I was thinking IS- 28. Good luck, the 29 looks like an interesting ship. Kirk 66 |
On 5/17/2011 7:28 PM, Jim wrote:
really? i found a pdf of the flight and maintenance manual online as well as the faa type certificate and didn't see anything about a life limit. there are no AD's against the IS-29 that I can find in the FAA database. Thanks for the comments, do you have a link to the online manuals? I owned an IS-28 years ago when the life limit issue became a big deal but don’t remember anything being said about the 29. Has anybody that’s flown one want to comment on flying qualities? Thanks, Jim If you haven't already searched for such, I seem to remember at least one RAS thread involving some 1st-hand feedback about IS-29 flying traits, specifically a quirk involving the all-flying tail (which my Zuni also exhibited). As with all 'flying qualities related' input, it's up to the savvy reader to put it into some sensible context. Example: 'Over the years' I'd heard/read about IS-28's being 'abrupt stallers' and 'eager spinners.' When I eventually got some time in one, I didn't find either ship-trait to be abbie-normal or alarming or worrisome. This particular one communicated (in the usual manners), long before serious wing flow separation occurred, that Joe Pilot was asking it to fly near the slower end/higher AOA portion of its flight envelope. But then I've found the 2-32's I've asked to do the same to be good communicators, beforehand, too. Never spun an IS-28, though both 2-32's I'd experience with *required* properly-sequenced, positive, anti-spin control inputs in order to break their spins...definitely not the case (say) for any 1-26s I spun. Regards, Bob W. |
On May 18, 11:32*am, BobW wrote:
If you haven't already searched for such, I seem to remember at least one RAS thread involving some 1st-hand feedback about IS-29 flying traits, specifically a quirk involving the all-flying tail (which my Zuni also exhibited). Regards, Bob W. Not all IS-29s have the all flying tail. The IS-29d2 version has a conventional stabilizer/elevator setup. The access to inspect wing connections (similar style to the Foka 4, by the way, complete with the adjustable width drag fitting connection at the front, at least on the IS-29) is much improved on the d2 version with the large, removable over-wing fairing. On the 29d2, they fittings were out in the open and easy to see. On the 29, the spars slip into boxes and your only view is straight down into the hole. There have been both variants at Sunflower, and I have flown neither. So, I can't give a first hand account of either. Other than to say that the pilots of both have landed with smiles. Steve Leonard |
On 5/17/2011 7:28 PM, Jim wrote: If you haven't already searched for such, I seem to remember at least one RAS thread involving some 1st-hand feedback about IS-29 flying traits, specifically a quirk involving the all-flying tail (which my Zuni also exhibited). Except, of course, that neither the IS-28 or IS-29 has an all-flying tail... (see other RAS thread about changing light bulbs, etc.) Kirk 66 |
On 5/18/2011 11:13 AM, kirk.stant wrote:
On May 18, 11:32 am, wrote: On 5/17/2011 7:28 PM, Jim wrote: If you haven't already searched for such, I seem to remember at least one RAS thread involving some 1st-hand feedback about IS-29 flying traits, specifically a quirk involving the all-flying tail (which my Zuni also exhibited). Except, of course, that neither the IS-28 or IS-29 has an all-flying tail... (see other RAS thread about changing light bulbs, etc.) Kirk 66 http://groups.google.com/group/rec.a...q=%22IS+29%22# http://groups.google.com/group/rec.a...&q=%22Zuni%22# (See Richard Friday's comment...) Regards, Bob W. |
On May 18, 2:01*pm, BobW wrote:
On 5/18/2011 11:13 AM, kirk.stant wrote: On May 18, 11:32 am, *wrote: On 5/17/2011 7:28 PM, Jim wrote: If you haven't already searched for such, I seem to remember at least one RAS thread involving some 1st-hand feedback about IS-29 flying traits, specifically a quirk involving the all-flying tail (which my Zuni also exhibited). Except, of course, that neither the IS-28 or IS-29 has an all-flying tail... (see other RAS thread about changing light bulbs, etc.) Kirk 66 http://groups.google.com/group/rec.a...wse_thread/thr... http://groups.google.com/group/rec.a...wse_thread/thr... (See Richard Friday's comment...) Regards, Bob W. Interesting threads, those - thanks. I had forgotten (if I had even known) that there was an IS-29D with an all-flying tail. This discussion was initially about the IS-29B, which does not. Cheers, Kirk |
On May 18, 4:10*pm, "kirk.stant" wrote:
On May 18, 2:01*pm, BobW wrote: On 5/18/2011 11:13 AM, kirk.stant wrote: On May 18, 11:32 am, *wrote: On 5/17/2011 7:28 PM, Jim wrote: If you haven't already searched for such, I seem to remember at least one RAS thread involving some 1st-hand feedback about IS-29 flying traits, specifically a quirk involving the all-flying tail (which my Zuni also exhibited). Except, of course, that neither the IS-28 or IS-29 has an all-flying tail... (see other RAS thread about changing light bulbs, etc.) Kirk 66 http://groups.google.com/group/rec.a...wse_thread/thr... http://groups.google.com/group/rec.a...wse_thread/thr... (See Richard Friday's comment...) Regards, Bob W. Interesting threads, those - thanks. I had forgotten (if I had even known) that there was an IS-29D with an all-flying tail. *This discussion was initially about the IS-29B, which does not. Cheers, Kirk- Hide quoted text - - Show quoted text - And again, my reading comprehension is not doing too well today! At least, the link to the IS-29 manual was for a B model with the conventional tail. Kirk |
This bulletin comes up when an A.D. search is done for Canada. It
seems to reference a manufacturer's mandatory service bulletin: S-29D2-EO-06 16.02.1985 MANDATORY SERVICE BULLETIN IS-29D2/EO-06 APPROVED BY : DEPARTMENT OF CIVIL AVIATION with no. 2639/06.03.1985 PRODUCT : IS-29D2 glider OBJECT : Safe life and service life increase COMPLIANCE : Endurance studies of the manufacturing plant and servicing experience. 1. PLANNING INFORMATION A. Applicability This bulletin is applied to all the IS-29D2 gliders. B. Reason Increase of gliders safe life. C. Description The bulletin modifies the total safe and service life of the glider, as follows: - total safe life : 3750 flight hours (15,000 landings) - total service Iife : 20 years - safe life until the first general revision and between general revisions : 750 flight hours (3000 landings) - service life until the first gen.rev. and between general revisions: 6 years. Link to bulletin: http://wwwapps3.tc.gc.ca/Saf-Sec-Sur...-29D2-EO-6.htm Despite what it says about calendar life I noticed that the IS-29D2's in Canada are more than 20 years old. |
So I know this is an old thread, but I'm looking for some info for fatique testing on mine.
If anyone has some info that would help (I'm having some Non-destructive testing done, but there are no procedures published for it) it would be appreciated. Also, if you have some questions about flying it, feel free. Cheers |
