STec-30 doesn't pass startup test after I shorted something....
Old January 11th 04, 08:27 PM
Dave
Default STec-30 doesn't pass startup test after I shorted something....
Okay, I screwed up. I was relocating the 3 panel switches for my STEC
30. The main power on/off, the nav 1/nav 2 and the alt. hold push
button.
When I relocated them and powered up, the self test succeeded and I
heard the servos testing themselves. But then one of the insulators
covering a lead on the alt. hold button came loose and the contact
touched my metal panel. Now, the AP doesn't work. When I turn it on,
the RDY/ST/HD/LO/HI lights all light up momentarily and then all
indicators go off. Usually, they would come one, and then the trim
up/down lights and alt. hold light would come on and cycle off.
I checked the breakers, but nothing popped out. I don't think there's
a fuse hidden somewhere under the panel, but maybe.....
Could something in the unit have shorted out? Is there anything I can
check before calling my avionics shop?
Old January 11th 04, 09:21 PM
plumb bob
Sounds like you're the same kind of guy who created a hornet's nest under
the panel of my first airplane... all the wiring had to be redone it was so
bad. Now that I am older and wiser, before buying an airplane I look for
signs of any owner (i.e. amateur) wiring (or rewiring) and run from the
airplane if that is the case.
If you really want to save buck then hire a pro to do it right. That is my
opinion.
-- Plumb Bob
"Dave" wrote in message
om...
button.
Old January 11th 04, 11:42 PM
CriticalMass
opinion.
Probably not the "help" he was asking for.
Old January 12th 04, 01:01 AM
plumb bob
"CriticalMass" wrote in message
my
opinion.
I am very sure of that! But, it just happens that I have him the best free
advice he can get :-)
Old January 12th 04, 01:08 AM
BTIZ
but will he accept it..
in the attempt to save a buck.. he now has to pay to remove, ship, repair,
re-install, test, sign paper/logbooks .. by a certified mech..
BT
"plumb bob" wrote in message
news:3mmMb.27794$sv6.81732@attbi_s52...
is
my
opinion.
Old January 12th 04, 01:51 AM
plumb bob
"BTIZ" wrote in message
news:FsmMb.61099$m83.43725@fed1read01...
Yup. Or, he can press ahead and continue to try and save a buck. And one day
when he or some other innocent piliot is in the clag on an approach into
Podunk... the smell of an electrical fire starts filling the air.
"Them people on thah nuze groops just sez I gotta connect dis wire over
here. I saved me a buck 'cos I shortzed the AP!"
Idiot!
Old January 18th 04, 05:47 AM
Martin Kosina
"plumb bob" wrote in message news:47jMb.26810$nt4.51908@attbi_s51...
opinion.
opinion.
That's a gross generalization, some of the truly awful work out there
is done by your so-called "pro's". I don't let anyone work on my
airplane without supervision anymore for this reason. And its not
necessarily your trusted mechanic/av. technician, either, sometimes
they have apprentices that do horrible things to airplanes.
STEC problem (the subject of the OP's message), I would call the
factory and get some documentation (service manual) about what the
lights mean, etc. I doubt modern avionics are built without basic
circuit protection from polarity problems, etc., but perhaps something
needs to be reset after such event. Long shot, but might be worth
little research before spending major troubleshooting $$$. I know the
first reaction after breaking something on the plane is to quickly
throw money at it to make it whole again, but its better to take a
deep breath and analyze the problem. The plane is flyable without this
particular component, so you are in no rush.
Is it really possibe to pass the Instrument test? CFLav8r Instrument Flight Rules 12 October 25th 04 04:16 PM
CONRAC CORP C5A COMPUTER TEST SET Mikel Giles Military Aviation 0 February 7th 04 05:09 PM
Air Force conducts live test of MOAB Otis Willie Military Aviation 0 November 21st 03 10:45 PM
FAA Knowledge Test Results Richard Moore Instrument Flight Rules 4 October 12th 03 07:10 AM
