![]() "Mike Rapoport" wrote in message nk.net... The truck would be stored outside on a hanger apron. Mike, I believe that EPA has or is in the process of mandating containment for mobile refuelers. A few other points to consider: Jet-A loves water and allows bacterial growth. Prist, in addition to being an antifreeze, is an anti-bacterial. Jet in storage needs to be circulated to keep the Prist properly mixed. Additionally, there are fairly rigid standards regarding filtration of Jet fuel. These standards are insurance driven, which brings up another point. If your FBO's arrangement is typical, they carry liability insurance for the first part of a claim. Excess liability coverage is provided by the fuel supplier. This coverage is contingent on the proper storage and conditioning of the fuel. Ours refused to sell us fuel unless the system met their standards. Look at the Jet fuel system sometime. Note the filters and valving. It is set up to be able to circulate and filter the fuel in the tank. As the fuel is off-loaded from the delivery truck, it is filtered. As it is delivered into your plane, it is also filtered. Any tanker that stores fuel should have the same capability. The tanker will also have to be epoxy coated in the inside to prevent rust. If you buy a jet refueler, it should already be set up correctly with epoxy and filtration, but that should be verified. Your FBO's fuel supplier should be happy to explain their requirements for fuel handling. You probably would want to "donate" the truck to the FBO in return for low fuel rates, just to avoid the hassles and potential liability. Alternatively, a variation on the "Mighty Grape" might better fit your needs, even if it took a couple of trips to fuel the plane. I had to research this 3 years ago when the company I work for bought a Citation Bravo. We ultimately abandoned the refueler idea, and opted to buy a 10,000 gallon Jet system, which we donated to the city. In return, we buy fuel at a deep discount for a specific length of time. Avgas systems are dirt simple in comparison. If you're still looking at refuelers, Aero-Trader has a 2,000 gallon truck in the current issue. 817 area code puts it in the Ft. Worth area. Hope this is helpful, Dick Meade |
![]() "Dick Meade" wrote in message ... Jet-A loves water and allows bacterial growth. Prist, in addition to being an antifreeze, is an anti-bacterial. Of course, Prist can no longer make this claim because the EPA has made it commercially prohibitive to certify something as a pesticide. It's officially an anti-icing additive...if you no longer have to worry about crud growing in your fuel, all the better. While bacteria will grow in the fuel, it's actually fungus (Hormoconis Resinae) that's the real problem. It's not just the water but the fact that this bugger likes to eat the fuel. The bacteria tends to stay with the water and thus is removed by the normal water traps...and filling up with fresh fuel alleviates the problem. The fungus likes to hang out on the surfaces in your tank and you'll continue to have an infestation until you actively put something in to kill it. |
Thanks, I was aware of most of these issues but not the containment one. I
agree that the best approach is to lease or donate the truck in return for low cost fuel. I am also considering a fixed site system but then I would need to buy the land and pay property taxes on it forever as well as maintain the system. Mike MU-2 "Dick Meade" wrote in message ... "Mike Rapoport" wrote in message nk.net... The truck would be stored outside on a hanger apron. Mike, I believe that EPA has or is in the process of mandating containment for mobile refuelers. A few other points to consider: Jet-A loves water and allows bacterial growth. Prist, in addition to being an antifreeze, is an anti-bacterial. Jet in storage needs to be circulated to keep the Prist properly mixed. Additionally, there are fairly rigid standards regarding filtration of Jet fuel. These standards are insurance driven, which brings up another point. If your FBO's arrangement is typical, they carry liability insurance for the first part of a claim. Excess liability coverage is provided by the fuel supplier. This coverage is contingent on the proper storage and conditioning of the fuel. Ours refused to sell us fuel unless the system met their standards. Look at the Jet fuel system sometime. Note the filters and valving. It is set up to be able to circulate and filter the fuel in the tank. As the fuel is off-loaded from the delivery truck, it is filtered. As it is delivered into your plane, it is also filtered. Any tanker that stores fuel should have the same capability. The tanker will also have to be epoxy coated in the inside to prevent rust. If you buy a jet refueler, it should already be set up correctly with epoxy and filtration, but that should be verified. Your FBO's fuel supplier should be happy to explain their requirements for fuel handling. You probably would want to "donate" the truck to the FBO in return for low fuel rates, just to avoid the hassles and potential liability. Alternatively, a variation on the "Mighty Grape" might better fit your needs, even if it took a couple of trips to fuel the plane. I had to research this 3 years ago when the company I work for bought a Citation Bravo. We ultimately abandoned the refueler idea, and opted to buy a 10,000 gallon Jet system, which we donated to the city. In return, we buy fuel at a deep discount for a specific length of time. Avgas systems are dirt simple in comparison. If you're still looking at refuelers, Aero-Trader has a 2,000 gallon truck in the current issue. 817 area code puts it in the Ft. Worth area. Hope this is helpful, Dick Meade |
![]() "Mike Rapoport" wrote in message nk.net... I would like to buy a fuel truck! 5,000 to 10,000 gallon preferred. I have been watching ebay and rbauction.com and I was wondering if anyone knew of other sources? How can I find out if the government is selling one? Thanks! Always some in Trade-A-Plane each month. |
On Tue, 13 Jan 2004 14:57:37 GMT, "Mike Rapoport"
wrote: I would like to buy a fuel truck! 5,000 to 10,000 gallon preferred. I have been watching ebay and rbauction.com and I was wondering if anyone knew of other sources? How can I find out if the government is selling one? Thanks! For fueling the MU2? That's a creative way to save some bucks. Morris airport in Illinois just added huge self-serve tanks to the field. Not sure if they are keeping their trucks, but it might be worth a phone call as they appear to be relatively new and in good condition). Morris airport is at: 815-942-1600 You can see a picture of the trucks in the background of this photo: http://www.needlescentered.com/needl...is_800x600.jpg Hell, I'd drive the thing out to Utah or Idaho, or wherever you live, if you fly me back to Chicago in the MU2. -Nathan |
![]() "Nathan Young" wrote in message ... On Tue, 13 Jan 2004 14:57:37 GMT, "Mike Rapoport" wrote: I would like to buy a fuel truck! 5,000 to 10,000 gallon preferred. I have been watching ebay and rbauction.com and I was wondering if anyone knew of other sources? How can I find out if the government is selling one? Thanks! For fueling the MU2? That's a creative way to save some bucks. Morris airport in Illinois just added huge self-serve tanks to the field. Not sure if they are keeping their trucks, but it might be worth a phone call as they appear to be relatively new and in good condition). Morris airport is at: 815-942-1600 You can see a picture of the trucks in the background of this photo: http://www.needlescentered.com/needl...is_800x600.jpg Hell, I'd drive the thing out to Utah or Idaho, or wherever you live, if you fly me back to Chicago in the MU2. You got it! Is that your Cessna in the picture? Mike MU-2 -Nathan |
On Tue, 13 Jan 2004 18:22:17 GMT, "Mike Rapoport"
wrote: "Nathan Young" wrote in message You can see a picture of the trucks in the background of this photo: http://www.needlescentered.com/needl...is_800x600.jpg Hell, I'd drive the thing out to Utah or Idaho, or wherever you live, if you fly me back to Chicago in the MU2. You got it! Is that your Cessna in the picture? Nope, but I thought it was a nice looking 170, so I took the picture last time I flew into Morris for lunch. -Nathan |
In article et,
Mike Rapoport wrote: I would like to buy a fuel truck! 5,000 to 10,000 gallon preferred. You're just fueling one plane, right? Why not a stationary tank? If it can't be a permanent structure, you could just get a semi trailer tank and park it. Hire a trucking company if you ever need to move it. -- Ben Jackson http://www.ben.com/ |
![]() "Ben Jackson" wrote in message news:UiVMb.44612$8H.98932@attbi_s03... In article et, Mike Rapoport wrote: I would like to buy a fuel truck! 5,000 to 10,000 gallon preferred. You're just fueling one plane, right? Why not a stationary tank? If it can't be a permanent structure, you could just get a semi trailer tank and park it. Hire a trucking company if you ever need to move it. There will actually be a couple of planes and owners. I have thought about a trailer but does a tailer have a pump? A trailer has a lot of advantages such as being able to hire a trucker to take it to be filled. Mike MU-2 -- Ben Jackson http://www.ben.com/ |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
Jet A / JP-4 ?? | CVBreard | General Aviation | 7 | December 8th 03 03:44 PM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
C210 fuel tank vents | Eric Brown | Owning | 2 | September 27th 03 02:59 AM |
