On Fri, 23 Jan 2004 22:04:41 -0600, "O. Sami Saydjari"
wrote: Does anyone out there have experience with having installed a tanis heater when a engine analyzer is already in place. I have a JPI Classic Scanner (EGT/CHT) that had bayonnet-type probee for CHT. Tanis has a kit designed for this sitation, but after we installed the kit, none of the CHT readings worked at all. The installer called Tanis and JPI and did get very useful advice on what may be going wrong. Has anyone out there faced this problem (and successfully overcome it)? -Sami Piper Arrow III N2057M I did, and I used the Tanis heated intake bolts, instead of the CHT probes, which were being used for my Insight GEM. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
I have both the Tanis and the JPI (mine is an 800 model). The
installation originally had the spark-plug ring type thermocouples and I found them to be terrible. Wildly divergent readings. I bought the combo thermocouple heater elements and thermocouples from Tanis (from memory they are the TAS-100TK) and they have worked just fine. The only problem is that two of them have failed in twelve months. That's a bit annoying at $170 a pop. Jack Sundowner - N6363U "O. Sami Saydjari" wrote in message ... Does anyone out there have experience with having installed a tanis heater when a engine analyzer is already in place. I have a JPI Classic Scanner (EGT/CHT) that had bayonnet-type probee for CHT. Tanis has a kit designed for this sitation, but after we installed the kit, none of the CHT readings worked at all. The installer called Tanis and JPI and did get very useful advice on what may be going wrong. Has anyone out there faced this problem (and successfully overcome it)? -Sami Piper Arrow III N2057M |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
What if the germans... | Charles Gray | Military Aviation | 119 | January 26th 04 11:20 PM |
Objective Engine Discussion | Rick Maddy | Home Built | 26 | October 14th 03 04:46 AM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
