![]() Michelle P wrote: You can install a Concorde www.concordebattery.com CB-25, CB-25XC, RG-25 or RG-25XC. Are any of these going to give him more cranking power than the Gill? George Patterson Great discoveries are not announced with "Eureka!". What's usually said is "Hummmmm... That's interesting...." |
Wow...thanks.
Michelle P wrote: Sami, You can install a Concorde www.concordebattery.com CB-25, CB-25XC, RG-25 or RG-25XC. Gee, I wish my A&P knew this. Growl. 1) Four attempted starts depends on how long you were trying. Most starters have a 30 second continuous limit. using that that is 2 full minutes of cranking. That would just about be the limit for battery capacity. I see. OK. So, it sounds like 4 tries is about all I can expect, no matter what battery I get?! Guess I need to get better at this starting thing! ![]() 2) Has your aircraft had the original battery cable (Aluminum in most models) with the Bogert Copper Cable kit? This improves starting speed and longevity. The new cable kit has been installed. 3) Find a more open minded A&P Concorde recently modified the battery cases so they will fit in the Piper Battery Box. Good to know. Thanks. 4) Place your battery on a Charger for an hour a day. Low current. A standard appliance timer works fine. This may be a bit awkward. My aircarft is in a communal hanger (hmmm, sounds communist) and they need to move it around from time to time to get to other aircraft. 5) Use a battery heater. Hmmm...I had not heard of those. Have you or anyone else on the newsgroup had good experience with those? I wonder if I can somehow link it to my (newly installed....just last week) Tanis heater? Michelle (A&P) |
Sami,
One battery heater supplier is: http://www.reiffpreheat.com/Battery%20Heater.htm Michelle O. Sami Saydjari wrote: Wow...thanks. Michelle P wrote: Sami, You can install a Concorde www.concordebattery.com CB-25, CB-25XC, RG-25 or RG-25XC. Gee, I wish my A&P knew this. Growl. 1) Four attempted starts depends on how long you were trying. Most starters have a 30 second continuous limit. using that that is 2 full minutes of cranking. That would just about be the limit for battery capacity. I see. OK. So, it sounds like 4 tries is about all I can expect, no matter what battery I get?! Guess I need to get better at this starting thing! ![]() 2) Has your aircraft had the original battery cable (Aluminum in most models) with the Bogert Copper Cable kit? This improves starting speed and longevity. The new cable kit has been installed. 3) Find a more open minded A&P Concorde recently modified the battery cases so they will fit in the Piper Battery Box. Good to know. Thanks. 4) Place your battery on a Charger for an hour a day. Low current. A standard appliance timer works fine. This may be a bit awkward. My aircarft is in a communal hanger (hmmm, sounds communist) and they need to move it around from time to time to get to other aircraft. 5) Use a battery heater. Hmmm...I had not heard of those. Have you or anyone else on the newsgroup had good experience with those? I wonder if I can somehow link it to my (newly installed....just last week) Tanis heater? Michelle (A&P) -- Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P "Elisabeth" a Maule M-7-235B (no two are alike) Volunteer Pilot, Angel Flight Mid-Atlantic Volunteer Builder, Habitat for Humanity |
As others have noted, there a number of batteries STCed for your airplane.
I am not sure how your mechanic tested your battery but just testing the specific gravity or voltage is not really an adequate test of starting ability. There was a recent article in Aviation Consumer about the differences between batteries. I hope that you are preheating the engine before starting in the cold and if you have Tanis heaters, you can add a battery heater which will help a lot. Mike MU-2 "O. Sami Saydjari" wrote in message ... I have a Gill G25 battery in my Piper Arrow III (PA28R-201T). I recently had a situation where I ran out of juice after 4 attempted starts. While I am sure that I can improve my starting technique (I am a newbie for this particular plane), I would like to have a bit more power in my battery, especially in very cold conditions such as we have up here in central Wisconsin. An A&P told me recently that I am "stuck" with my G25 battery. He said that he tested it and that it was "fine." Based on a recent article in "Aviation Consumer", I learned that the G25 has only about 225 cold cranking amps. I noted that the G35S has 250 cold cranking amps. (1) Is it true that I am stuck with a G25 battery and that NO OTHER battery in the world can go in my plane? I find that a little hard to believe. (2) If there are other possibilities, can someone recommend one that has better cold cranking amps that the G25? Thanks in advance. -Sami (N2057M, Piper Turbo Arrow III owner) |
![]() There was a recent article in Aviation Consumer about the differences between batteries. Yes, I read the article, but I was a bit confused about which batteries were "equivalent" to mine and could be used in my aircraft. Another responder in this thread answered that question. I hope that you are preheating the engine before starting in the cold and if you have Tanis heaters, you can add a battery heater which will help a lot. I was preheating with forced hot air from an external heater. Last Friday, I added a Tanis heater. Does one "add a battery heater" by getting it from Tanis and having an A&P install it? Mike MU-2 "O. Sami Saydjari" wrote in message ... I have a Gill G25 battery in my Piper Arrow III (PA28R-201T). I recently had a situation where I ran out of juice after 4 attempted starts. While I am sure that I can improve my starting technique (I am a newbie for this particular plane), I would like to have a bit more power in my battery, especially in very cold conditions such as we have up here in central Wisconsin. An A&P told me recently that I am "stuck" with my G25 battery. He said that he tested it and that it was "fine." Based on a recent article in "Aviation Consumer", I learned that the G25 has only about 225 cold cranking amps. I noted that the G35S has 250 cold cranking amps. (1) Is it true that I am stuck with a G25 battery and that NO OTHER battery in the world can go in my plane? I find that a little hard to believe. (2) If there are other possibilities, can someone recommend one that has better cold cranking amps that the G25? Thanks in advance. -Sami (N2057M, Piper Turbo Arrow III owner) |
![]() "O. Sami Saydjari" wrote in message ... Does one "add a battery heater" by getting it from Tanis and having an A&P install it? Of course everybody needs to get paid.for your battery to be warm. It shouldn't be too difficult though. http://www.tanair.com/accessories.html#BATTERYHEATERS Mike MU-2 |
"Testing" the battery means making sure it is fully charged, then
discharging it using a known load current, timing how long it takes the voltage to reach 11.5V, and then computing the capacity by multiplying the time to reach 11.5V by the load current. According to Gill & the FAA, your battery should be up to delivering a load current representing all the stuff it takes to get safely on the ground for 30 min: this should include engine instruments, fuel gauges, electric gyros, radios, transponder and some lighting. A guess for the essential electrical load on your aircraft would be about 25A. To test the battery, connect a 12V/25A=0.48 Ohm, 12V*25A=300W resistor to the battery, and time how long it takes the battery to reach 11.5V. If your battery wont hold up this load for 30 min, then it should be replaced... Cranking is a separate test. An automotive service-station type of carbon-pile battery tester can be used to put a load of ~225A on the battery for 3 or so minutes. If the battery peters out short of 3 min, then replace it. MikeM O. Sami Saydjari wrote: I have a Gill G25 battery in my Piper Arrow III (PA28R-201T). I recently had a situation where I ran out of juice after 4 attempted starts. While I am sure that I can improve my starting technique (I am a newbie for this particular plane), I would like to have a bit more power in my battery, especially in very cold conditions such as we have up here in central Wisconsin. An A&P told me recently that I am "stuck" with my G25 battery. He said that he tested it and that it was "fine." Based on a recent article in "Aviation Consumer", I learned that the G25 has only about 225 cold cranking amps. I noted that the G35S has 250 cold cranking amps. (1) Is it true that I am stuck with a G25 battery and that NO OTHER battery in the world can go in my plane? I find that a little hard to believe. (2) If there are other possibilities, can someone recommend one that has better cold cranking amps that the G25? Thanks in advance. -Sami (N2057M, Piper Turbo Arrow III owner) |
Great. I am certain that this level of capacity testing was not done. I
will have it done soon and let you know. Thanks. -sami MikeM wrote: "Testing" the battery means making sure it is fully charged, then discharging it using a known load current, timing how long it takes the voltage to reach 11.5V, and then computing the capacity by multiplying the time to reach 11.5V by the load current. According to Gill & the FAA, your battery should be up to delivering a load current representing all the stuff it takes to get safely on the ground for 30 min: this should include engine instruments, fuel gauges, electric gyros, radios, transponder and some lighting. A guess for the essential electrical load on your aircraft would be about 25A. To test the battery, connect a 12V/25A=0.48 Ohm, 12V*25A=300W resistor to the battery, and time how long it takes the battery to reach 11.5V. If your battery wont hold up this load for 30 min, then it should be replaced... Cranking is a separate test. An automotive service-station type of carbon-pile battery tester can be used to put a load of ~225A on the battery for 3 or so minutes. If the battery peters out short of 3 min, then replace it. MikeM O. Sami Saydjari wrote: I have a Gill G25 battery in my Piper Arrow III (PA28R-201T). I recently had a situation where I ran out of juice after 4 attempted starts. While I am sure that I can improve my starting technique (I am a newbie for this particular plane), I would like to have a bit more power in my battery, especially in very cold conditions such as we have up here in central Wisconsin. An A&P told me recently that I am "stuck" with my G25 battery. He said that he tested it and that it was "fine." Based on a recent article in "Aviation Consumer", I learned that the G25 has only about 225 cold cranking amps. I noted that the G35S has 250 cold cranking amps. (1) Is it true that I am stuck with a G25 battery and that NO OTHER battery in the world can go in my plane? I find that a little hard to believe. (2) If there are other possibilities, can someone recommend one that has better cold cranking amps that the G25? Thanks in advance. -Sami (N2057M, Piper Turbo Arrow III owner) |
Often overlooked are the master and starter solenoids. These things
get burned contacts and they begin to present a resistance that shows up as reluctant cranking. A voltmeter placed across the solenoids' big terminals should show 13 volts when the system is off, and NO voltage when it's on (or cranking). Any voltage while the solenoid is closed indicates resistance across the contacts. Even a small amount of resistance at high current flows will cause significant voltage drop (E=I*R; A .02 ohm resistance at 200 amps gives a 4-volt drop). Check the cable connections the same way. Check both the master and starter solenoids with the engine cranking. An ohmmeter isn't really good enough to detect bad solenoid contacts. The resistances are small, and increase with heat caused by electical flow. An ohmmeter won't detect the heated resistance. Dan |
Dan,
No voltage across the contact is unrealistic. O.5 volt is considered to be the acceptable limit. If you replace the master and starter solenoids. Have your A&P install diodes reverse to the flow across the contractor terminals. The will prevent the contact from arcing when they disengage. It is the contact arcing that increases the resistance and causes the voltage drop. 0.5 volts across the contacts is 0.0013 ohms. Michelle Dan Thomas wrote: Often overlooked are the master and starter solenoids. These things get burned contacts and they begin to present a resistance that shows up as reluctant cranking. A voltmeter placed across the solenoids' big terminals should show 13 volts when the system is off, and NO voltage when it's on (or cranking). Any voltage while the solenoid is closed indicates resistance across the contacts. Even a small amount of resistance at high current flows will cause significant voltage drop (E=I*R; A .02 ohm resistance at 200 amps gives a 4-volt drop). Check the cable connections the same way. Check both the master and starter solenoids with the engine cranking. An ohmmeter isn't really good enough to detect bad solenoid contacts. The resistances are small, and increase with heat caused by electical flow. An ohmmeter won't detect the heated resistance. Dan -- Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P "Elisabeth" a Maule M-7-235B (no two are alike) Volunteer Pilot, Angel Flight Mid-Atlantic Volunteer Builder, Habitat for Humanity |
