Rotating Beacon vs. Flashing Beacon
Old February 4th 04, 12:21 AM
Jim Weir
Hint...Jameco Electronics has DOZENS of different gearhead DC motors for not a
lot of money. Of course, **I'd** never use an unapproved part in **MY**
airplane, but...
Ron Rosenfeld
-I'm still rebuilding the Grimes every two or three years.
-Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA)
http://www.rst-engr.com
Old February 4th 04, 04:02 AM
Abafon Goula
airplane, but...
And if I were wanting to look for Jameco Electronics for some type of
hobby motor, where might I find them?
Old February 4th 04, 04:09 AM
G.R. Patterson III
http://www.jameco.com
George Patterson
Love, n.: A form of temporary insanity afflicting the young. It is curable
either by marriage or by removal of the afflicted from the circumstances
under which he incurred the condition. It is sometimes fatal, but more
often to the physician than to the patient.
Old February 4th 04, 11:56 AM
Abafon Goula
On Wed, 04 Feb 2004 04:09:47 GMT, "G.R. Patterson III"
Doh!
Old February 4th 04, 02:40 PM
Viperdoc
I replaced my old rotating beacon with a Whelen strobe unit and have been
very happy. There was no electrical interference, and with the comet flash
the visibility is much better.
Old February 4th 04, 06:38 PM
Ron Natalie
"Abafon Goula" wrote in message ...
airplane, but...
I wouldn't put a Jameco motor in my Grimes beacon. First off, the thing that's
there, even before it's geared down has a decent amount of torque. Second,
unless something real bad has happened like it got struck by lightening, it's easier
to just rebuild the blasted thing. The thing is dirt simple and designed to come
apart and be worked on. All you need is a screwdriver, some solvent, some
oil, and if you really want to be fancy a source of DC current to test the thing with.
Old February 6th 04, 11:05 PM
Nathan Young
Mike,
You may want to see if you can get the old one overhauled. My
mechanic saves old beacons and cobbles enough parts together to get
them working again.
When mine stopped rotating - I opened it up and found a plastic gear
had been worn down by the metal gear that meshed with it.
My mechanic installed a new plastic gear, and voila, it worked.
Total cost: 1/2 hour of labor, part was free.
-Nathan
On Mon, 02 Feb 2004 14:49:50 GMT, "Mike Rapoport"
My upper rotating beacon has stopped rotating and I am debating whether to
overhaul it or replace it with one of the new Whelen flashing beacons. The
flashing beacons are all solid state with no moving parts but cost $800 and
I am also concerned about noise since the beacon is located a few inches
from the COM1 antenna. Has anyone replaced a beacon with the new flashing
type? How far from your COM antenna is it? Is there any noise on the COM?
A question for the electronics gurus: Do I even need to be concerned with
noise?
Thanks in advance!
MU-2
Counter rotating propellers Raoul Military Aviation 24 September 21st 04 05:59 AM
B-52 crew blamed for friendly fire death Paul Hirose Military Aviation 0 March 16th 04 12:49 AM
replacement rotating beacon for 64 piper cherokee Patrick Mathews Owning 2 October 1st 03 01:55 PM
Marker Beacon Tones Ron Natalie Owning 1 July 4th 03 03:27 PM
