Voltage regulator contacts
Old February 11th 04, 01:04 PM
Ray Andraka
Dan Thomas wrote:
In most airplanes the alternator switch controls only a relay in the
regulator, not the field current itself. The relay connects the
voltage regulator relay to the "A" line, which runs to the alternator
output which in turn is connected to the aircraft's electrical system.
The small current required to run the relay might not be enough to
keep the master/field switch contacts burned clean, and the relay
contacts themselves can get worn.
The voltage regulator contacts can burn and start cutting out or
sticking shut intermittently, too.
Not Piper. Piper's field circuit goes from the master bus, through the field breaker,
through the master switch, thru the OV relay, thru the regulator to the alternator field.
A relay would have been a better design in that the master switch doesn't wear well with
the 12v several amp DC current. Many if not most Pipers have solid state regulators, so
there are no regulator contacts to burn.
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
FA: 12V to 24V DC voltage converter Karl Geng, N1DL Home Built 2 April 21st 05 08:48 PM
Remote Switch for Pointer ELT --- Why Does It Need Voltage? jls Home Built 1 November 22nd 04 09:13 PM
Battery storage? Roger Long Owning 10 January 14th 04 02:35 PM
Skylane Alternator problems MLenoch Owning 7 December 11th 03 09:37 PM
Anyone have experience with InterAv alternator flyer Home Built 6 October 19th 03 03:24 AM
